Question about Toshiba 50H13 50" Rear Projection Television
My picture shacks vary fast from side to side toshiba 42H83
I have had this fixed before (twice) while under warrenty.
My TV have this problem with shaking picture ,all chanells but the HD . Is this a easy fix
Posted on Feb 20, 2010
  • 167 Answers
You could have a bad color wheel or there is a Factory Service Bulletin from Toshiba that says: Remove the MVUP14 Hyper Module from the TV chassis, remove
the top shield and replace the 10uf, 16v capacitors using Part Number
24619040 as shown in Figure 1. It’s recommended that all of the
capacitors identified in Figure 1 be replaced. (Note: These capacitors are
low impedance surface mounted aluminum electrolytic capacitors. Care
should be taken to avoid damaging the PCB while replacing these
capacitors.) You should call a good TV Tech to do this repair.
Posted on Aug 02, 2009
Solucion al problema 33 64 de la lexmark 340
This is a issue with the power brick, I would recommend servicing the device if under warrenty. If not under warrenty, then invest in a new printer. It will be cheaper then fixing it out of warrenty.
Oct 19, 2013 | Office Equipment & Supplies
I have a 07 XL7 and I've changed the seals on it twice in less than 5 months, but its still leaking. The dealership took care of it twice under warrenty but its still not fixed. What do I do? It only has...
if you are not getting any satisfaction from the dealer ring the manufacturers head office and complain lots and tell them that you want it fixed if they don't you will take it further.
Apr 14, 2011 | 2007 Suzuki XL-7
I purchased a (LN32B360F) 32" 720p Series 3 High Definition LCD TV [B717Z] , it won't turn off and it's still under warrenty, Can I get a replacement or do I have to get it repaired
As long as you didn't damage it. Its covered by warrenty. Warrenties cover internal malfunctions. But if you break a button or break the screen, your screwed. On a extended warrenty, A they fix it for free ( well exception of the warrenty price if u bought an extended warrenty). or B they replace it if it can't be fixed. If you got the extended warranty you can take it back to the store you bought it from ( the dealer).
If on the one year manufacture warranty
You will haft to contact the manufacture and find the nearest authorised repair place. Then you will probly haft to take it to that location or mail it in. You will haft to pay some money in some way to get it fixed. But not much like est. $20-50.
Oct 25, 2010 | Samsung Televison & Video
Xbox 360 power supply light turns yellow when xbox 360 is off (usually i think) and turns green when on, I've had one red ring on my xbox to,twice
make sure your xbox is in an open area where it can breathe, otherwise the one red ring means there is a hardware failure, if it is under warrenty send it back into xbox, otherwise there are some diy fixes on youtube
Mar 02, 2010 | Microsoft Xbox 360 Console
Engine rolls over does not start
I had this problem. Twice! It sounded like it wanted to turn over but couldn't. Your engine may be flooded. I had to have mine towed to the mazda dealer (if under 100,000 miles it is under warrenty) so they could fix it. The second time they had to replace my engine because of a bad compression ring.
Jan 30, 2010 | 2004 Mazda RX-8
FI ligth blinks twice CBR 600RR 2008
take it to a honda dealer the bike is still under warrenty
Nov 03, 2009 | 2008 Honda CBR 600 RR
Windows won't auto up or go up that 1/2'' when you close door
Because you had it back to the dealer for the same problem whilst it was in warrenty,the warrenty is still valid.Its called a warrenty ongoing problem.The dealer must fix the problem and if you run into problems ask the dealer for the manufacturers warrenty complaint number.They will probably try a bit harder to fix the problem because it puts a blotch on their dealership if you complain to a higher level.Don't let them NOT fix it.Hope this helps
Oct 24, 2009 | 2006 Ford Mustang
My xbox 360 has a red ring around the power indicator, how do i fix it?
Red ring is covered under microsoft warrenty of 3 years just call 1-800-4my-xbox to see if your still in warrenty.
Oct 15, 2009 | Microsoft Xbox 360 Console
Camera frozen
The autofocus motor is stuck. It's a Samsung common problem and can't be fixed by the user. If it's still under warrenty you can send it to the the listed repair facility in NYC, otherwise you might wind up paying aa much as what you bought if for. BTW, they fixed mine while it was still under warrenty and three months later, it's broken again with the same problem. My advice? DON'T BUY ANOTHER SAMSUNG PRODUCT AS LONG AS YOU LIVE!!
Dec 21, 2007 | Samsung Digimax S500 Digital Camera
No power at all
I would first make sure that the capacitor and the diode going to the case is not bad. many problems with these parts. And No, the manufacturers will only let an authorized repair dealer do the job for the warranty. Good Luck
Mar 28, 2007 | Samsung SMH7174BC Microwave Oven
Toshiba 50H13 50" Rear Projection Television Logo
242 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
