Error lavadora F21 - Washing Machines
  • miguelcruz Aug 02, 2009
    Como selecciono 2 veces STOP, ya que ahora está en STOP y si intento seleccionar algún programa me aparece el error referido. El modelo exacto es WAE24471EP.
    President:
  • 1,734 Answers
“F21” aparece en la pantalla (problema de desagüe)
Seleccione Parada (STOP) dos veces para anular el ciclo.
Desenchufe la lavadora o desconecte el suministro de
energía.
Verifique lo siguiente:
¿Está retorcida la manguera de desagüe?
¿Se ha congelado la manguera de desagüe?
¿Está obstruida la manguera de desagüe?
¿Está la manguera de desagüe a una altura mayor de 96"
(2,4 m) del piso?
If this is not true, then f- 21 is an error code for a communications error between the touchpad and the ccu (main computer) check that all leds light up when selected . if so disconnect power from machine for 30 secs. try again. still a problem? check wiring for loose connections. have also seen this once with drain pump not plugger in. basically you have to find out what unit is not talking to the ccu. as for the noise when you remove "filter" the hole to the right is the impellar see if something in there. it is safe to seperate the two halves of the pump and reassemble.
Posted on Aug 02, 2009
  • Washing Mach... Master
  • 19,396 Answers
Esso depende del modelo de lavadora. Por favor indique el modelo de su lavadora, posibilmente incluyendo el numero de modelo impresso en la place de servicio.
Gracias.
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
It washes fine just doesn't spin or drain
Hi. For general electric. Desenchufar la lavadora por 2 minutos volver a enchufar inmediatamente realizar 6 aperturas y cierre de la tapa superior dentro de los primeros 15 segundos despu?s de haber enchufado nuevamente la lavadora. Con esto de realiza un reset. Del sistemas se borran los c?digos de error.
Jul 28, 2013 | Washing Machines
Union de cables en el motor de lavadora whirlpool
hola tengo una lavadora duet sport de whirlpool y me aparece el error f 25, aveces termina de lavar o simplemente lava y luego no enjuagua, y hace ruido como traka traka gracias.. karina reynoso
Feb 18, 2012 | Whirlpool Washing Machines
Yo tengo en la lavadora el codigo f-21 what is this
F21 de error se muestra cuando la lavadora no se puede drenar, pulse Pausa / Cancelar dos veces para borrar la pantalla. Despu?s de esto, por favor revice la manguera de drenaje y filtro de la bomba de drenaje para los bloqueos y asegurarse de que no est? obstruido con part?culas extra?as. Tambi?n puede consultar la bomba de drenaje para verificar que su funcionamiento.
Si necesita m?s ayuda, consulta otros consejos en este enlace: won_39_t_finish_cycle_21_f_flashing
Esperamos que esta ayuda le sirva (recuerda votar y comentar esta respuesta).
Jul 25, 2011 | Kenmore HE2 Plus Front Load Washer
Lavadora maytag mlg 2000 aww la inicio en lavar esta lllenando a los 20 segundos se apaga , la pongo a exprimir tira el agua pero a loa 20 segundos se apaga doy gracias
hola por que cuando encho ropa a la lavora y le pongo el ciclo adecuado y a los 20 min o segundos me aparece un error f20 mi lavadora es maytag frontal ke puedo hacer????????
Jan 12, 2011 | Maytag Neptune MLG2000A Front Load Stacked...
La maquina cuando esta lavando sale f21 y no escurre el agua
F21 DRENAJE DE LARGO
Si el tiempo de drenaje supera los 8 minutos, el apagar las v?lvulas de agua.
NOTAS: Despu?s de 4 minutos, el "SD" error se mostrar?, a continuaci?n,
4 minutos m?s tarde el "F/21" c?digo de error se mostrar?. Pulse
PAUSA / CANCELAR dos veces para borrar la pantalla.
Posibles causas / Procedimiento
1. Revise el tubo de descarga y aseg?rese de que no est? conectado o
doblada.
2. Desenchufe la lavadora o desconecte la energ?a.
3. Compruebe las conexiones el?ctricas en la bomba y aseg?rese de
la bomba est? funcionando.
4. Compruebe la bomba de drenaje de objetos extra?os.
5. Enchufe la lavadora o reconecte el suministro de energ?a.
Dec 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Tengo una lavadora electrolux maxi clean y me manda codigo de error e4 que tengo que hacer
Buenos dias tengo una lavadora maxi clean que no centrifuga y los demas ciclos los hace sin problemas, como le reviso l control de nivel por que la bonba suena como si tubiera agua la tina por mucho rato.
Gracias
Nov 03, 2010 | Washing Machines
Lavadora samsung dosnt spin
  1. Puede que el motor no gire en la direccion requerida ya que son reversibles
  2. El cloch esta danado
Nov 14, 2007 | Samsung WE356A5W Washer/Dryer Laundry...
Washing Machines Logo
353 people viewed this question
Top Washing Machines Experts
