Question about Goodman CKL36AR36 Air Conditioner
How do you get a compressor to stop knocking like crazy with out replacing it?Im pretty sure there is noncondensables in the system. Can u just pump it down, add a L-line F-Dryer, vaccum it for a while and charge her up. or is that just a waste of time and refrigerant and just replace it. Thank You. Big AL
  • 5,546 Answers
Are there any specs for an oil charge? In theory the line dryer and vacuum pump should draw any moisture out. If you can drain the old oil it may have metal chips from the knocking and then bloe out the compressor with fresh oil. This would mean dicing and splicing the lines to the compressor to purge the old oil.
But then you start with a clean compressor, known quantity of oil and vacuum it down to refill. Is it cheaper than a new compressor?
Posted on Aug 02, 2009
95 Buick Regal .it makes a knocking noise when running,but when I take belt off it stops.I replaced the water pump and it still knocks.
Said "knock" could be in the AC compressor or power steering unit since it don't knock with belt off.
Aug 24, 2014 | 1995 Buick Regal
How do you add the refrigerant yourself to your cooler GDM-12
I will tell you what the factory says. Get a reclaimer and remove the remaining refrigerant from the system. Put your vacuum pump on the system and finish removing the noncondensibles from the system. Take a scale that weighs in ounces and weigh in the exact charge stated on the spec. tag that gives you the model and serial number and refrigerant type and charge. If you just try to put some gas in you will have a refrigerator that builds up ice on the coil, wont shut off, makes bad sounds, and has compressor problems. Hope this helps and good luck.
Jun 16, 2014 | True GDM-12 Refrigerator Commercial
Bought the cavalier had no ac/ but has great fan blowing it's just hot, defrost everything runs normal mulitiple speed////recharged w r134 blew ice cold almost 3 months went out again slowly. Stopped at...
I,t sounds like you had a leak, and pulled air into the system. This calls for professional servicing. Whenever there's a leak in a refrigeration system, air and sometimes other noncondensables get pulled into the system. They don't belong there. They cause heat and high pressure in the condenser, and will eventually destroy the compressor. The system needs dehydration and evacuation before charging. That's after all leaks have been repaired.
Aug 26, 2013 | Heating & Cooling
Have a 11yr old RUUD Uaka 060jaz with the A coil frozen, solid, no air getting through. Service tech came out and charged system with minimum 3lbs of r22 but suction pressure wouldn't go above 6
Hello, typiccally with noncondensables in the system your head pressure would be alot higher. 175 is pretty low high side pressure. Usually coils will freeze due to either low airflow or low refrigersmt charge not becuase of non condensables. I would get a second opinion from a differant company.
Jun 28, 2012 | Heating & Cooling
94 oldsmobile 88 crank shaft location
Its the harmonic balancer. The rubber in the balancer has disintegrated and not balancing the motor any longer. You have to install a new one.
Jul 20, 2017 | 1994 Oldsmobile 88
Split unit airconditioning DSA099L. Trips and displays F6 error
F-6=High discharge temp/overheating compressor.
Due to condenser block (Clean it),/less RPM of fan motor (Replace capacitor)/Noncondensable gas( Remove gas flush out system, vacuum and do gas charging..
Helpful?
Jan 02, 2011 | Daewoo Heating & Cooling
Im not getting fuel. Replaced fuel pump. worked
Before you go chasing a possible bad electrical connection, I would replace the fuel filter. At the same time when you have the fuel line disconnected at the pump side, place the line into a bottle and have someone crank the engine for a second or two to see if the pump is priming. Always make sure you have gas in the tank which many of us tend to overlook. Check the ground wire for the fuel pump and inspect the wire and connection for corrosion or damage.
May 19, 2010 | 1985 Nissan Pickup
Trying to figure out where the knocking is coming from, on engine
It all depends how loud the knock is. A tapping valve can be caused by low oil level, or dirty oil. Topping up or changing oil will solve the problem. A really loud valve tapping is abnormal. Cars sometimes make what you call a spark knock when accelerating hard. Extremely loud knock coming from deep within the engine is a bad sign, which means the engine has failed. Further examination would reveal metallic residue on the dipstick.
Jun 27, 2009 | 1994 Ford Thunderbird
Copleland scroll compressor failure
I have scroll chiller contains scroll compressor tandom circuit. One of the compressor failure from it due to unbalance of the winding. Previously compressor thermistor opens two to three times. Also one phase open in contactor of the compressor. Can you guide me regarding the reason of compressor failure and what is the next step for the replacement of compressor. Also give guide line for the points take care.
Nov 02, 2008 | Goodman Heating & Cooling
Goodman CKL36AR36 Air Conditioner Logo
134 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
