Check the bearings on beater bar. Try turning with your finger. If they are locked up beater bar won't turn.
Check bearing on beater bar. Try rolling it with your finger. If the do not turn have them replaced so they won't cause further damage.
Belts may look ok and may make the brushroll spin but need to be replaced at least once per year. First make sure the brush roll will spin freely.
SOURCE: My brushes are not turning. We checked the gear and it is turning, but brushes aren't
Take the brushroll out and see if it turns freely just by holding the end. Also make sure that the belt isn't stretched out. Also, before putting the head on the vac, you have to pick the belt up on the "finger" that's in the head. You can verify this by looking into the circle that's cut out of the metal. When the head is affixed to the vac, then turn the belt lifter back around to the proper position and all should be well. If you still need help, you may call us at 1-866-509-1952. Thanks
SOURCE: Bissell Proheat 2x Series 8920 - Brush Belt Metal Shaft Sprocket won't turn
Most likely the brush motor is bad and not turning, part #2036757, would sell for around $23. To get to it, start taking out screws on the top cover, that motor is under the that top access cover.
SOURCE: weak suction on rainbow se vacuum
With years of use, you will collect a layer of "micro dust" on the impeller (the fan part) which reduces the efficiency. A toothbrush and some mild cleaner with gently scrubbing will restore it's power.
The impeller is that parts that spins that you can see when you take the top off to fill the water tank.
Hope this is the answer that you need!
SOURCE: roller brush won't spin (bissel 6390/3910 series)
I just fixed mine. It took me all of 10 minutes. Pull the brush out. Stand the brush on end on the edge of your study work bench/table top. while holding the brush vertical( on end) take a small phillips screwdriver and tap using a hammer on the metal pin you see in the middle of the brush. Keep tamping and the whole assembly will come apart. What you will have then is a long metal shaft, 2 bearings(they are acutally skateboard wheel bearings same number same make). Clean the gobbed up hair with a razor blade and then reassemble by tapping back together. The bearing wont be worn out because they are way too tough for a vaccum. We used ride down hills on them! a ten minute fix wow and you wont have to drive to vacuum shop and spend $$ and time
SOURCE: The brushes won't turn on my hoover steam vac dual v
Hi There,
Unfortunately the answer above is far from helpful. The filter has absolutely nothing to do with your brushes not spinning, and you can really replace the turbine yourself without having to take it into a shop to fix it. Here's a much more helpful diagnosing of how to check the brushes, and fix the turbine if needed.
There can be serveral things that may have gone wrong with your Hoover so that the brushes stop spinning. Unlike the other "expert" above I will walk you through step by step on how to diagnosis this problem, and fix it. Unfortunately there is no belt or band on this model, but instead it's actually a turbine assembly that drives this brush.
Possible Problem #1. Usually the most common problem when the brushes stop spinning is that the brushes have simply gotten clogged with something that is preventing them from spinning. Especially if you have pets in the home, this is a common problem. Here's how you can clean these brushes.
First, turn the machine upside down so that the brushes are facing upwards. Pull down on the upwards on the brushes and they will easily snap right out of the mahcine completely. . Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. It's important to make sure that the brush switch on the top of the machine is turned to "Rotating Brush Speed Hi", and that the handle of the machine is reclined down. There is an internal switch inside the machine that turns the brushes off when the machine is in the upright position, so you'll need to step on the handle release pedal to ensure that this switch is engaged. Hopefully the brushes just needed to be cleaned, and they will now work now that you have reinserted them. If this still didn't fix your problem, move on to the next possible problem.
Possible problem #2: If the cleaning didn't fix your problem, remove the brushes from the machine again. Once the brushes have been removed, the handle reclined, and the brush switch turned to fast, turn the machine on. Where the brushes were sitting you'll see a square shaped hole (pictured below) that the brush stem fits into that actually spins the brushes. This part should be spinning while the machine is on. Here's a picture of that part:
If this part is not spinning, then your Turbine Gear Assembly has gone bad and needs to be replaced. If this part spins however, then this indicates that your brush block is gone bad, and needs to be replaced.
Here are links to the exact parts for your model that may need to be replaced:
Brush Block:
http://www.govacuum.com/hov2st6blpa4.html
Turbine Gear Assembly:
http://www.govacuum.com/hostretubrge.html
Here's also a link to a Fixya repair solution that I've done explaining step by step how to replace the turbine gear:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
I hope this helped you, please be sure to rate the repair or leave feedback if you found this repair to be helpful.
Thanks so much,
Chris Jones
GoVacuum.com
