Question about HP Office Equipment & Supplies
Hi, i want to scan to email, but when i press the scan menu it does not give me that option.
  • 114 Answers
Easiest way is scan to file then email an attachment.
Posted on Aug 02, 2009
How do you delete an old email from my computer
Hi
Depending on what email service you are using, they give you options on there web interface page to select the emails and use the delete feature to delete them.
If its a email on your computer your can normally right click the icon or file and a drop down menu will give the option to delete it.
Try that and see how you go.
Cheers
Nov 26, 2012 | Computers & Internet
Problem with 5300 scanner
the inner parts may not receive proper power supply thats why you are not able to scan .......
Aug 19, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Toshiba Freeview Tv, Model 19A 615 DB. Re-tuning I pressed Menu, Set-up, Restore Defaults, then Yes to delete previous settings, and OK. Absolutely nothing happens, Help please?
hi,
To Re- tune your TV you have to go to the Auto tuning option in the menu. do the following procedure for auto scan all the available channels.
To tune the free view analogue channels do the following procedure.
1. Press the Menu/setup button on the remote.
2. Select Auto tuning and press enter.
3.Select the country and press enter.
4. Select start and press enter.
The automatic tuning will search for available broadcasts and should store the channels in the correct order. During the search the sound is muted. When all programs have been stored, the normal TV screen will appear.
If you can sent your email address through fixya then i will sent the user manual for Toshiba 19A 615 DB.
ok
Sep 07, 2011 | Televison & Video
After scanning and attaching it to an email, you cannot read it because it is so light
Run a scan calibration under the secondary menu:
1. Press Setup.
2. Press the Left arrow (<) and Cancel buttons at the same time.NOTE: Some control panels might require that the Left arrow (<) be pressed slightly before the
Cancel button.
3. Press Setup.
4. Use the arrow buttons to navigate the listings.
5. Press OK to select the appropriate option, or Press Cancel to cancel an action or return to the
Ready state.
Under the scan calibration you need to run each calibration twice
May 12, 2010 | HP Laserjet M2727nf Multifunction Printer
How do i scan and email a document using the a940 printer
On the printer press scan, then press options, move the right arrow key. Select e-mail and press select button. Also, go to start menu, go to all programs, Dell printer, then select DELL AIO Printer A940, then select Dell All-In-One Center. On the Scan box on the drop menu select e-mail. All set, scan from printer to e-mail.
Sep 25, 2009 | Dell A940 All-In-One InkJet Printer
Scanning from a canon 3220
Yes, the type of scanning mentioned by the previous answer is called 'pull scanning' and you will have limited functionality. You have to load the document on the copier, turn on the scanner (nobody can use the machine now) return to your desk which I hope is not far from the copier because the doc stays there until you 'insert picture from scanner' then the machine scans the document and you run back to the copier to get it before someone throws it in the trash! It's a free system but limited. To have a fully functioning 'push scanner' where you send a doc as you stand at the copier to either a file on your computer, server or an email address you would need a universal send kit installed. If your machine has one you'l see the option tab called 'SEND' along the top of your screen. If you have this you're in luck. All you need is to enter the necessary network and email settings which can be done by any half decent network administrator vis the 'system settings' area from the addtional functions screen (accessed by pressing the head key with a star in it). Once this is set up merely select the 'SEND' tab and insert your document. In the top right hand corner will be a drop down menu reading either 'FILE' 'EMAIL' or 'FTP' If you want to send it to a shared folder on your network (anywhere) you select the 'FILE' option and then use the drop down menu in the centre of the screen to search the network for your shared folder. Select it and then press ok then the start key - IT'S GONE - IF YOU'RE LUCKY. To send to email you just select the 'EMAIL' option and enter the email address of the recipient and ok then start and you're in business provided that all the network and email settings are correctly entered and permissions for network access is set up. The machine needs a email account registered for it as well. I'm tired now - good luck.
Feb 17, 2009 | Canon imageRUNNER C3220 Color Copier
How do you scan and email a document on the HP Deskjet F4200?
Just open an email & address it as usuall, now, at the top of the email you will see an icon that looks like a peperclip, click on that, a box opens & you just navigate to the file using the browse button. When you click on the file it will show up in your email uner 'subject'. If you don't see a paperclip then look for the word 'insert', this will do the same thing. Good luck. If this helps you plz rate this 'fixya'. If you need further help leave a comment & I'll be happy to walk you through it. Thank you kindly.
Feb 14, 2009 | Office Equipment & Supplies
Can't scan from HP Photosmart C7280 to my Mac Computer
The best way to scan documents from the scanner to your computer is to use HP Photosmart Essential. If you don`t already have it installed it can be downloaded from the HP site. Once in the program it is very simple to follow. It is basically a point and click operation.
Let me know how you make out and we can do other things if this doesn`t work for you.
Please remember to rate me.
Feb 02, 2009 | HP PSC 2410 All-In-One InkJet Printer
Hi,i'm using dell photo aio printer 922,i keep getting the blank page when i give print...even the test page is not printing.please help
check the ink levels. if they are not low, try to clear NVRAM by pressing the Scan button and the Up button at the same time to enter diagnostic mode. Use the Up button or the Down button to go to the option for Clear NVRAM on the LCD and press Menu to confirm. Press Menu again when asked if you are sure. Press Menu again when asked if you are really sure.
Feb 01, 2009 | Office Equipment & Supplies
Won't scan legal documents properly
Make sure that you set the paper size in the setup menu for legal - 8.5 x 14 for the manual paper feed.
Jul 01, 2008 | Samsung CLX 3160fn All-In-One Printer
54 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
