Question about Peg Perego John Deere Turf Tractor
Have a JD built scotts 16 hp 42 in using it with trailer moving wood would not start turned key motor clicked wouldent turn over, bats. good starter good i replaced starter relay still same wont turn over, can any one help, did run fine. Tim
    Genius:
  • Peg Perego Master
  • 1,508 Answers
Wrong forum
Posted on Jun 06, 2012
Will not start or click when hitting the ignition switch. have replaced the starter, charged the battery and cleaned the battery terminals
Use voltmeter or test lamp to see if you are getting power to ignition switch. Could be blown fusible link or bad switch.
Apr 21, 2016 | Cars & Trucks
Craftsman 21 hp lawn tractor motor seems frozen
Did it leak oil & seize up
Can you turn it over by hand
Is a belt or bearing preventing the motor
from turning?
May 08, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a 20 h.p. craftman lawn tractor model 917288130. The engine will not turn over. I have changed the battery, and all I get is "clicking" when I turn the key.
you can try an lightly tap the starter with a hammer to see if it's stuck,....while holding key to start,....this happens on mine sometimes,.....not to much you can do,..kind of poorly built these days,.....good luck, cracklin joe
Jan 10, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
My car wont start battery is not dead,but wont turn over?
if the battery is fine check if you hear a clicking noise coming from the starter motor when you turn the key to try and start the engine.
If you hear this noise then this is a good indication that the selenoid has failed meaning you need to replace the starter motor.
You can give the starter motor a hit with a piece of wood as some times this will get the starter motor working just to start the car but this isnt a permanent fix and could leave you stuck if you used the car.
Now if the starter motor isnt clicking but you hear a clicking noise coming from either the cars fuse box or the ecu when you turn the key to start the car then this would indicate a problem with the imobiliser this would need testing using a diagnostic machine as their is no other way of testing this to find out if its at fault.
Let me know how you get on or if you need further assistance ok
Dec 22, 2009 | 1996 Chevrolet Cavalier
Starter motor wouldent stop runing even with key
The starter silanoid is going bad and staying open.
Change it out with a new one.
Dec 11, 2009 | 2007 Triumph Bonneville T100
Clicking not cranking. Replaced battery at Pep
Why did you replace battery in the first place Before checking out the reason of why it wouldent start???????????.
1st when you turn the key does the starter motor click
2ndTurn on headlights and then try starting ,do the lights go out (yes/no) 3rdThe Alternator only does the charging not the starting
BUT YOU say you can jump it and it will start ???????????????
Well that still puts it down to either the Starter OR the BATTERY is no good unless you have a24 volt system (which you havent)
So check the Red + lead from the battery to Starter motor for good tight fit ,,and the Black -lead to any engine bolt and also to the body (2 wires 1thick 1 thinner Black leads ) good tight fit ,,
The funny hum you can hear would be the fuel pump working and that is in the fueltank But just check under the bonnet and make sure that
its not coming from the alternator as sometimes it get a short inside and will flattern the battery in 3minutes (that also has a Red feed wire going to it.
SO LET ME KNOW HOW YOU GET ON Ron
Oct 27, 2009 | 2000 Dodge Caravan
19.5 hp 917270810 starter making loud squeel
remove a plastic cover above or near the starter to access the gear and check the teeth on the gear.\
if it is chewed up replace gear or the complete top of starter assemly consisting of a clutch a gear and fastening components.
Starter will have to be removed to do this.
check the flywheel gear also to be sure its teeth are in good shape.
if gear is good move motor off of compression stroke and try again
Jun 14, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
I have a 42 in. 12.5 hp lawn tractor. It stopped running. I have replaced the battery, alternator, and had the started checked. Now, when I turn the key, all there is, is a click. I have been told the...
Have you checked the starter motor? It sounds like it is bad. You might be able to remove the blower housing cover and physically turn the starter teeth and then try to start (after putting the cover back on). If it tries to start then you have a bad starter (dead spot on the winding). Just replace the starter and you should be good.
Jun 04, 2009 | Garden
Peg Perego John Deere Turf Tractor Logo
96 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
