Question about LG Flatron L1710M 17" LCD Monitor
HELP! when i switch the computer on the screen doesnt go on and my PC starts beeping. Ive disconnected and re-connected all of the cables but the problem persists. I URGENTLY NEED HELP! PLEASE GUYS!
  • Anonymous Dec 17, 2007
    I have the exact same problem, my screen doesnt even go on and it just beeps constantly.
  • tombuzz Feb 26, 2009
    When i start up my computer, the screen doesn't respond (and yes it is turned on) sometimes it works after waiting a very long time but today it's been almost 4 hours and i can hear a high beeping sound coming from the screens volume boxes. I have no picture and I (re)connected all cables. i already tried rebooting the pc but it just wont work
    the screen is connected to a normal home PC tower... I have no idea what the problem is... any help?
    Scholar:
  • 116 Answers
What are you trying to do? I need more information? Are trying to connect an LCD monitor to your laptop, desktop? What?
Posted on Nov 26, 2007
Medion desktop beeps 8 times and wont boot up
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove new hardware If any new HARDWARE has been recently added to the computer, remove that hardware to make sure it is not the cause of your issue. If after removing the new hardware your computer works it's likely the computer is either not compatible with the new hardware or a system setting needs to be changed to work with the new hardware device. Remove any disks or USB devices Remove any disks, CD's, DVD's that are in the computer and if any USB devices (Ipods, drives, phones, etc) are connected disconnect all of them as well. Reboot the computer and see if anything changes. Disconnect external devices. Remove everything from the back of the computer except the power cable. Turn on the computer and see if it beeps normally. If the computer has never beeped keep the monitor or display connected to see if any change occurs. Check all fans Make sure all fans are running in the computer. If a fan has failed (especially the heat sink fan for theCPU) your computer could be overheating or detecting the fan failure causing the computer not to boot. Check all cables Verify that all the cables are properly connected at that there are no loose cables by firmly pressing in each cable. All disk drives should have a data cable and power cable connected to them. Your power supply should have at least one cable going to the motherboard. Many motherboards may also have additional cables connected to them to supply power to the fans. Disconnect all expansion cards If the above recommendations still have not resolved the irregular POST, disconnect the riser board (if applicable) and each of theexpansion cards. If this resolves the issue or allows the computer to POST connect one card at a time until you determine what card is causing the issue. Disconnect all drives If you were unable to determine by the beep code what is failing or do not have a beep code disconnect theIDE, SATA ,SCSI or other data cables from the CD-ROM ,Hard Drive and Floppy Drive from the Motherboard. If this resolves your irregular POST or generates error messages re-connect each device until you determine what device or cable is causing the issue. In some situations it can also be a loose cable connection that causes the issue. Remove the RAM If you continue to to receive the same problem with all the above hardware removed, disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue. Re-insert the memory into the same slot. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick. Try one stick of memory in each slot. If you're able to get the computer to boot with one or more of the sticks of memory it's likely you're dealing with some bad memory. Try to identify what stick of memory is bad and replace it. If you're able to get memory to work in one slot but not another slot. You're motherboard is defective you can either workaround the issue by running the memory in a different slot or replace the motherboard. Power cycle the computer In some situations a computer may have power related issues often caused by either the power supply or the motherboard. To help determine if this is the cause of your issue try turning the computer on, off, and back on as fast as possible, making sure the computer power light goes on and off each time. In some situations you may be able to temporarily get the computer to boot. This should only be used as a temporary workaround if you're able to get this to work. Often this is good for users who may have not done a backup and need to get the computer up one more time to copy files before starting to replace hardware. Disconnect and reconnect the CPU For users who are more comfortable working with the inside of their computer or who have built their computer one last recommendation before assuming hardware is bad is to reseat the CPU by removing it and putting it back into the computer. Bad motherboard, CPU, RAM, or power supply If after doing all of the above recommendations you continue to have the same issue unfortunately it is likely that you have badMotherboard, PSU, CPU, orRAM. The next step would be either to replace these components or have the computer serviced. If you plan on doing the repairs yourself or you are a repair shop it is suggested that you replace the Motherboard first, RAM, CPU, and then power supply in that order or try swappable parts from other computers. Hope this helps.
Jan 20, 2013 | Medion Computers & Internet
Epos won't turn on
b> The PSU might be the culprit
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove new hardware If any new HARDWARE has been recently added to the computer, remove that hardware to make sure it is not the cause of your issue. If after removing the new hardware your computer works it's likely the computer is either not compatible with the new hardware or a system setting needs to be changed to work with the new hardware device. Remove any disks or USB devices Remove any disks, CD's, DVD's that are in the computer and if any USB devices (Ipods, drives, phones, etc) are connected disconnect all of them as well. Reboot the computer and see if anything changes. Disconnect external devices. Remove everything from the back of the computer except the power cable. Turn on the computer and see if it beeps normally. If the computer has never beeped keep the monitor or display connected to see if any change occurs. Check all fans Make sure all fans are running in the computer. If a fan has failed (especially the heat sink fan for theCPU) your computer could be overheating or detecting the fan failure causing the computer not to boot. Check all cables Verify that all the cables are properly connected at that there are no loose cables by firmly pressing in each cable. All disk drives should have a data cable and power cable connected to them. Your power supply should have at least one cable going to the motherboard. Many motherboards may also have additional cables connected to them to supply power to the fans. Disconnect all expansion cards If the above recommendations still have not resolved the irregular POST, disconnect the riser board (if applicable) and each of theexpansion cards. If this resolves the issue or allows the computer to POST connect one card at a time until you determine what card is causing the issue. Disconnect all drives If you were unable to determine by the beep code what is failing or do not have a beep code disconnect theIDE, SATA ,SCSI or other data cables from the CD-ROM ,Hard Drive and Floppy Drive from the Motherboard. If this resolves your irregular POST or generates error messages re-connect each device until you determine what device or cable is causing the issue. In some situations it can also be a loose cable connection that causes the issue. Remove the RAM If you continue to to receive the same problem with all the above hardware removed, disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue. Re-insert the memory into the same slot. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick. Try one stick of memory in each slot. If you're able to get the computer to boot with one or more of the sticks of memory it's likely you're dealing with some bad memory. Try to identify what stick of memory is bad and replace it. If you're able to get memory to work in one slot but not another slot. You're motherboard is defective you can either workaround the issue by running the memory in a different slot or replace the motherboard. Power cycle the computer In some situations a computer may have power related issues often caused by either the power supply or the motherboard. To help determine if this is the cause of your issue try turning the computer on, off, and back on as fast as possible, making sure the computer power light goes on and off each time. In some situations you may be able to temporarily get the computer to boot. This should only be used as a temporary workaround if you're able to get this to work. Often this is good for users who may have not done a backup and need to get the computer up one more time to copy files before starting to replace hardware. Disconnect and reconnect the CPU For users who are more comfortable working with the inside of their computer or who have built their computer one last recommendation before assuming hardware is bad is to reseat the CPU by removing it and putting it back into the computer. Bad motherboard, CPU, RAM, or power supply If after doing all of the above recommendations you continue to have the same issue unfortunately it is likely that you have badMotherboard, PSU, CPU, orRAM. The next step would be either to replace these components or have the computer serviced. If you plan on doing the repairs yourself or you are a repair shop it is suggested that you replace the Motherboard first, RAM, CPU, and then power supply in that order or try swappable parts from other computers. Hope this helps. b>
Dec 22, 2012 | Computers & Internet
7 loud beeps and a black screen on bootup
Dec 08, 2012 | Dell Inspiron 1200 Notebook
Ive got a long continual beep and it emits orange light from the front and back of the computer how am i to fix it?
Turn the computer off.
Unplug the power cable.
Remove the video card.
Remove the RAM.
Re-insert the video-card, ensuring that it is "seated" properly.
Do NOT re-install the RAM, just yet.
Connect the power cable.
Turn the computer on.
If you get a different "beep", the lack of RAM is the problem.
If you get the same "beep", the video-card is the problem.
Disconnect the power-cable.
Re-install one stick of RAM (two if it is RAMBUS/RDRAM).
Reconnect the power-cable.
If it beeps "normally", then the not-yet-installed RAM is the problem.
If it still "long-beeps", turn the computer off, disconnect the power-cable, and remove the RAM, and insert the "other" stick/pair of RAM.
Reconnect and start it up.
If still a problem, change the video-card.
Dec 02, 2009 | Dell PowerEdge 1800 Server
PC show the message and hang and black screen .
You are going to have to start with basic troubleshooting first.
TAKE notes as to where cables were etc. (digital camera would be useful here)
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the on-board)
Power u the computer and make sure you can at least get into the BIOS.
If you hear any beeps these can indicate where the fault is.
Power up the PC and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
If its not the PSU and your fans are working it may suggest a problem with either the motherboard or CPU
Sep 05, 2009 | Computers & Internet
Pc has power but nothing shows on screen. motherboard doesnt beep once like it used to when turned on but green light is on indicating its ok.
dear,
Remove the ram and check, is the motherboard beeps or not..
it should beep as long beeps....and should continue beeping after serveral times until u switch off it...
then reconnect the ram after swiching off power...
remove the data cables of hdd and cd/dvd and then try to switch it on...
if it works fine then reconnect it properly...
Fault can be in Ram or data cables perhaps...
regards,
hope it will fix the issue so dont forget to rate it...
Apr 20, 2009 | Computers & Internet
WHEN CONNECTED TO POWER THE BOX EMITS A BEEPING NOISE BUT DOESNT START UP OR POWER MOUSE/KEYBOARD & SCREEN SAYS "NO SIGNAL". HAVE DISCONNECTED ALL CONNECTIONS, LEFT OVERNIGHT THEN RECONNECTED...
Hai
It seems your PC is having some kind of hardware problem.
It can be a loose connection or so. If you have little bit of experience in opening the PC, try yourself. Also check listen to the type of beep it produces.
If there is 2 beeps its RAM problem or if it beeps continuasly, its power supply problem.
If you doubt RAM, have a new one and check.
It it does'nt help, take it to the nearest service tech. It does'nt cost that much
good luck
Rabby
Jun 17, 2008 | Acer Computers & Internet
Ipod does not charge?
i connected my ipod to the computer but it only shows "very little battery do not disconnect"and it does not show the battery sign.please help.
May 11, 2008 | Audio Players & Recorders
Atx12v1 cable
The repeating single beep with a small pause (actually 3 Beeps a Pause) clearly indicates problems with RAM .Replace it ,your problem will be solved . As for connecting the 12 volt 4 pin connector all mobos are designed to sense the presence of this 12 volts and ONLY THEN TURN ON.
May 02, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
Aspire? T180
If the PC does not to any beep then usually is a problem with the motherboard.
If the PC does a certain number of beeps on startup, then tell me how many beeps to troubleshoot the problem.
If the computer does single beep on startup as usual, then may be the monitor, monitor cable or graphic adapter.
Simple thing that you can do it yourself is disconnecting computer power cable from power outlet for 15 -12 mins. ac connect it back, this will solve troubles caused by electrostatic charges.
Also check video cable connections to monitor.
If you have another computer also test the monitor on other computer.
If the main unit is not booting (CD drives and internal fans often start up even if the Motherboard is blown). Then yo need to open the pc and test component inside.
If you have practice in fixing hardware you can start removing RAM modules and testing them, then buy a tester board for the MB and do a diagnostic test on motherboard.
Other options are taking PC to service or getting a new PC.
If the PC is still under guarantee, then contact Acer to validate your guarantee and get the machine to an authorised service centre.
Regards
Mar 16, 2008 | Acer Aspire™ T180 PC Desktop
LG Flatron L1710M 17" LCD Monitor Logo
129 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
