Question about Thetford Porta Potti
The fride is sited directly underneath the sink. The sink and side of unit get extremly hot. The fridge continues to work very well is there a problem hope you can help many thanks Clive
  • 32 Answers
I dont qoutie understand what you mean, But that will be a problem in the long run for the fridge bec it could ruin your motor or even melt wires if its always running hot and will cause big problems in the future
Posted on Aug 03, 2009
The partition that separates the freezer from the refrigerator on my unit is EXTREMELY hot to the touch. the fridge works ok, as does the freezer, but the partition between them is so hot, you can hardly...
It's usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
Apr 11, 2011 | Refrigerators
How do i turn my ice maker off? i have a viking side by side and the ice maker is just pouring water in my freezer...its a mess!
Turn the water off under the sink where the small line starts that goes to the fridge or there may be a cut off directly behind the fridge in the supply line.
Your water inlet valve may be stuck open. It's where the water supply connects to the fridge.
Dec 11, 2009 | Viking VCSB423 Side by Side Refrigerator
Both fridge and freezer do not cool
check your relay on your compressor ,unplug unit and take relay off and shake it.it is probaly trash.
Aug 24, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Whirlpool Gold side by side cabinet extremely hot to the touch.
the refrigerator has mullions simaler to the veins underneath your skin to aid in cooling .the first thing to check is the fan by the compressor is it running while the compressor is if so the next thing to inspect is the condensor coils usaly underneath the fridge or directly on the back of the fridge alot of times these get clogged with lint and or animal hairsimply unplug the fridge and gently brush off the lint and vacume.your feed back on the resolve for this issue would be gratly app.
Aug 13, 2009 | Refrigerators
Sides of the refrigerator get extremely hot
The coils below fridge need cleaning very badly ( if G E then behind fridge) or the fan behind refrig which cools the compressor , is not working . Model number would have been helpful .
Aug 12, 2009 | GE Refrigerators
Ice maker and the water dispensor is not working.the fridge is only 6 months old
does your plastic water line run from underneath your sink to fridge? if so maybe you put something under sink and crimped the little plastic water line. pull refride out some and then try water dispenser
Jul 11, 2009 | GE Profile PSW26P Stainless Steel Side by...
Panel between fridge and freezer very hot and no sound at all
Hi: Its just a coincidence you noticed it then. It is usually hot. It's the reverse side of the refrigerant (the hot side.) If you lived in a humid area the fridge would sweat. Water would run down between the doors. I live in a dry climate so no worries. Older fridges used an electric heating element to keep them dry. They also had an energy saver switch to turn it off. As Whirlpool uses the hot side of the refrigerant they don't use additional power to run the heater. Actually the heater is called a mullion heater. Nothing is wrong with your fridge. I'll look over my shoulder for angry retailers. Hope this helps, Jeff.
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer running, ice maker not producing, hot in middle divder.
The dividing section should be warm, to keep unit from sweating. (by design). Cleaning under the refrigerator was what cooled it down. You cleaned the condenser. The condenser allows the refrigerent to cool down. When it was dirty, the condenser could not get enough air to cool down.
Mar 14, 2009 | Kenmore 57029 Side by Side Refrigerator
Kitchen aid superba side by side refrigerator
CHECK CONDENSOR FAN IN REAR OF UNIT NEAR COMPRESSOR. IF COMPRESSOR IS RUNNING AND UNIT IS COOLING SOME, CONDENSOR FAN IS LIKLY THE PROBLEM. IF THE CONDENSOR FAN DOES NOT RUN THE COILS UNDERNEATH AND THE LOOP THAT RUNS NEAR THE FRONT EDGE OF BOTH DOORS WILL BE HOT.
Jul 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Maytag refrigerator MSD2758GEW divider panel hot to touch
What you could check is that the fan at the back of the unit, where the compressor is located, is working, as this could also cause a heat build up. The partition between the two sides does generally tend to get hot due to the door circuit, to prevent ice buildup around the door. But people tend to notice when something is different. You are also right to check for dust underneath the cabinet as the condenser tends to be layered. If you have already cleaned it all out then you have probably done as much as you can. If you are still concerned contact a fridge guy. Hope this is of some help.
Sep 12, 2007 | Maytag MSD2758GEW
Thetford Porta Potti  Logo
Top Thetford Camping, Backpacking & Hiking Experts
Patricia Cross
Level 1 Expert
Fredrik Str?hle
Fredrik Str?hle
Level 1 Expert
Tony
Are you a Thetford Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
