Spin cycle not activating with simpson eziset 950. It will drain but not spin? The red indicator light is active but machine will not spin. The agitator is working but the spin cycle is not. I have tried it on full wash cycle and on specific Rinse/Spin cycle and Spin/Drain cycle. Any tips, ideas would be greatly appreciated!
  • Washing Mach... Master
  • 1,527 Answers
Hello any spin problems could be down to the module circuit board all the best
shaun
Posted on Aug 02, 2009
Hello, hope you can help, I have a eziset 550 simpson when I put the water on it starts filling but won't stop I have to listen & try to change settings so the water that won't stop running doesn't...
there is a small hose from the bottom of the tub to the water level switch
that gets air pressure to activate a switch when the level selected overcomes the switch spring
At that point the water solenoid is turned off and the wash cycle begins
over flowing indicates that the level sensor is not working or the inlet solenoid and diaphragm is faulty
if it doesn't progress the wash cycle , that indicates a program board problem so call the technician for a proper diagnosis
Sep 13, 2017 | Simpson Washing Machines
Simpson 605 washing machine
it is worth having it properly diagnosed first before making a decision to spend money
could be a program board or start run capacitor
Nov 11, 2017 | Washing Machines
Simpson ezi 950 9.5 will not empty, rinse, spin dry.
That sounds like the pump is jammed. Have you checked for hair slides or similar? Once the pump is free to operate, your Simpson should resume normal service.
Feb 20, 2014 | Washing Machines
My simpson eziset 550 5.5kg will go through the washing cycle but will not rinse or drain and makes a continuous beeping sound how can I fix this problem?
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, If not check the drain valve and the voltage at the time of the cycle. Now at the time of the rinse the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Feb 07, 2013 | Washing Machines
Eziset 950 wont spin and gives slight electric shock
Possible that the motor has failed and it has developed a leak to the body which seems to be felt over the machine, Isolate the motor and test the external voltage presence.. if absent it can be related to the motor.
Jan 12, 2013 | Simpson Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Washing Machines Logo
1,437 people viewed this question
Top Washing Machines Experts
