Question about Panasonic Microwave Ovens
Panasonic NE-1780 - F14
Heating starts but after a few seconds, it stops and displays code F14.
    Champion:
  • 207 Answers
Could be a problem with the door latch, or the magnetron or magnetron circuit.
Posted on Nov 05, 2016
3 Suggested Answers
  • 119 Answers
SOURCE: Panasonic microwave start and stop in a few
replace magnetron
Posted on Feb 17, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: PANASONIC MICROWAVE-NN-S615BFX
These H codes usually indicate a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Posted on Sep 25, 2008
F14 error code comes up after heating starts and shuts down.
this is special error. You must go to the panasonic ONLINE. give your model, and ask a question for get support ONLINE free, and fix it.
God bless you
Jun 15, 2013 | Panasonic Pro II NE2180 2100 Watts...
My trusty 20 y.o. Panasonic NE-8180 starts, runs for a couple of seconds & then displays a message
It is important to observe if there is heating in the first few seconds of use. If not the possibility of the magetron or the HT main capacitor ebing faulty is high as this leads to a trip due to an error.
You need to check with the power switched on and care must be taken- shield used- to avoid any radiation injury.
Dec 02, 2011 | Microwave Ovens
Hi, I have a Panasonic Inverter microwave NN-Sn9688. It's less than a year old and when you press the START button H98 appears and it will not start. Everything else works, clock etc and reset/stop...
Hi Judith, I am Kelly
If this has a 1 year warranty it is time to make that call.
Otherwise see this link about H97 or H98 codes: http://www.applianceaid.com/micro_faultcodes.html#panasonic
There are a few things that can cause the problem, none of them cheap repairs. The Magnetron filament, Control board and Inverter are the top 3 other than a losse connection.
I tried running the Model number NN-SN9688 and it does not cross. See Panasonic link here: http://www2.panasonic.com/webapp/wcs/stores/servlet/PNAEndecaSearchCmd?N=779832097&Ne=&No=0&Nr=12001&Ns=&Ntk=SupportSearch&URL=vSupportSearch&cmTag=true&catalogId=11017&storeId=15001&cm_sp=SiteSearch-_-SupportSearch-_-SupportHome&Ntt=NN-SN9688&x=28&y=20
I did not go to Panasonic Global and try other countries. I just did a USA search.
Thanks for choosing FixYa.
Kelly
Sep 10, 2010 | Panasonic Microwave Ovens
Heating ceases after one second
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt http://207.234.249.73/mwd/disassembly.txt http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
If yours is not a Panasonic, please reply back with your brand and model number so we can help you.
May 30, 2010 | Panasonic NN-H275 Microwave Oven
Microwave stopped working suddenly,the sreen reads H97
If your oven is out of warranty then i would suggest just getting a new one.
The code is for a bad controller circuit, and it would cost almost as much to fix it as it would to buy a new one.
Jan 12, 2010 | Panasonic NN-H275 Microwave Oven
I have a Panasonic Dimension 4 Microwave/Convection "The Genius". The microwave stopped working? Can you advise?
So we can help you, please post a NEW FixYa inquiry which includes your full model number from the tag on the unit, and the answer to these questions:
Is it dead? (meaning no display, no beeps when you press a pad on the keypad and the inside light does not come on when you open the door)
Is it running but not heating?
Any usual noises?
Does it shut off after a few seconds when you try to cook with it?
Of so, exactly how many seconds?
Are there any error codes on the display?
Also, if you;re not in the US, which country are you in?
Oct 11, 2009 | Panasonic Microwave Ovens
H98 error message. Micowave not heating, stops after 37 seconds
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Sep 28, 2009 | Panasonic NN-H965 Microwave Oven
Sep 25, 2008 | Panasonic NN-MX26 Microwave Oven
Microwave runs for a few seconds then F 12 displays on screen and it stops
The following is a solution for the Panasonic brand microwave. I do not know your brand so this is the best I can do.
PANASONIC
Model: NE-1057, NE-1057C, NE-1257, NE-1077, NE-1277, NE-1457, NE-1457C, NE-1757, NE-1477, NE-1777 Symptom: Code "F11" or "F12" appears on the display intermittently Problem: Moisture is accumulating on control panel from steam rising out of the door. Solution: Install foam sealer (cushion rubber) along lower edge of control panel escutcheon. Part # A8251-3180
Apr 03, 2008 | Microwave Ovens
Microwave Ovens Logo
606 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
