Question about Juki TL-98Q
I'm quilting and the tension is so tight that the thread always breaks. Can't go much farther then an inch. If I loosen the tension then the stitch is all messed up.
  • 98 Answers
Check the tension on the bobbin too?
Posted on Aug 02, 2009
CANT QUILT WITH MY JUKI TENSION PROBLEMS
Okay, you've tried a lot of things. The question is this: is the thread snapping (where abouts in the path), or is it shredding at the needle? Here are a few more:
Remove the top thread, ALWAYS RAISE the presser foot, and rethread from the beginning.
Try different thread--perhaps a polyester thread like Isacord or Aurafil. (AVOID old or bargain bin thread.)
Try a different kind of needle (brand new needle!)--like a top-stitch, microtex, or embroidery. The top stitch needle has a larger scarf that will better protect the thread if shredding is the issue. (I use a special bobbin case that I've increased the tension for Isacord thread and I use the same thread in top and bobbin.) I also decrease the top tension a tad so the bobbin thread will not pull to the top. You may need to install brand-new needles several times on one quilt when they get dull.
Usually an 80 or 90 needle will work for FMQ through a fabric/batting sandwich.
Check that the needle's eye is the appropriate size for the thread (also a cause of shredding thread).
Set the upper tension at the midway point perhaps a bit looser for FMQ (this tension will probably need to be tweaked for your particular machine due to wear and age).
Use an FMQ foot and drop the feed dogs. A Supreme Slider (avlb on the internet) is very helpful in helping move the quilt while doing FMQ.
Work at a moderate but steady pace. I find a faster speed while FMQ gets me into trouble...like spots I can't get out of, overlapping stitches, or outside the quilt edge.
FWIW, I still get some skipped stitches with FMQ. Usually, it happens when I move the fabric too fast, especially around a curve. I have a tendency of speeding up while going around a curve that will cause skipped stitches or eyelashing.
I'm also wondering if there is something to do with the fabric and/or batting you are using...like is it Batik? Batik is very tightly woven and presents some particular challenges. The type of batting could be more dense, making it harder for the needle to penetrate the sandwich. Also, pulling or stretching the fabric can cause skipped stitches.
Basic Maintenance Tension Skipped Stitches
Here What to Do if Your Sewing Machine is Skipping Stitches
10 reasons for skipped stitches
If you see no improvement in your machine's stitching, you may want to have it serviced.
Apr 28, 2017 | Juki Sewing Machines
Won't stay threaded
Nearly always incorrect threading or tensioning.
Sep 29, 2015 | Sewing Machines
Janome 1600P skipped stitches
Normal top tension is 3-4; normal bobbin tension (iirc) is 35 grams.
I'm betting, though, that a new needle, right way around and the correct size, would solve your skipping problems.
Jan 15, 2014 | Janome 1600P-DB Mechanical Sewing Machine
I have a janome 1600P, it will not sew without either the top thread breaking or the bobin thread breaking. It will sew for about a quarter of an inch and then the thread breaks, I have changed the bo
My experiences with thread breaking with machine on a quilting frame make me look at the upper tension being set too high, the needle being worn or movement of the machine is too fast. Reduce the upper tension first, then sew in straight lines at first. See if you can sew slowly, in straight lines and reduce the upper tension until the thread stops breaking. If so, try some 1-2 inch circles, again going slowly. If the needle thread is pulling to the back, you will need to increase the upper tension again until the stitches meet in the middle of the fabric. If you can't locate a balanced spot where the needle thread is not pulling to the back side and thread doesn't break, try taking the machine off of the frame and sewing on a table. If it won't sew this way, it needs some professional help. If it does, you will probably save a lot of time taking it in for service, making sure to explain to the repair center that you have problems on a quilting frame, not while sewing normally. When the machine is adjusted to sew normally on a table and you move it to the frame, you will probably need to reduce the tension by 1-2 complete turns of the tension knob.
Nov 17, 2011 | Sewing Machines
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Sewing Machines
I'm trying to use the Janome 1600P DBX for quilting. A repair tech. went through the machine and cleaned, oiled and set the tensions. It looks like the tensions are set right but the thread breaks after...
I would try this -
Make sure you are not using quilting thread for hand stitching.
Thread the machine with the presser foot up.
If the machine is stitching seams without a problem and the breakage happens with thicker fabrics, it could be the presser foot is not down below where it is closing the tension to the setting of choice.
When the presser foot is up, the tension control opens. When the presser foot is down, the tension control closes to the setting you have chosen.
If this continues, call the dealer/tech and tell them the problem you are having.
Mar 06, 2010 | Sewing Machines
Pfaff varimatic 6091 sew a rag quilt with jean and flannel,I can't get my tension right it seems to be funny on the bottom stitch,where shoulf the top tension be set at 4 1/2 ,when do I adjust the bobbin...
Hi! The bobbin tension rarely needs to be adjusted. First, make sure you're using the appropriate size needle and thread for your fabric (I'd probably use either a 'denim' needle or a universal size 14) and also that the upper thread and bobbin are threaded absolutely correctly. These can throw off the tension! Also, take the time to clean out the bobbin area. That can throw your stitch off also.
If the stitch on the bottom is loose, so that you see the top threads, then the top tension is too loose. If the top stitch is too loose and you see the bobbin threads on top, then the top tension is too tight.
It helps to thread the machine with different color thread on top and in the bobbin, and then stitch an inch or so on the same type of fabric as you're using in your quilt. Check the stitch. If you need to adjust the top tension, make sure the pressure foot is down! Adjust a little, stitch a few inches, and check again. Repeat until you don't see any (or very little) bobbin thread on the top or top thread on the bottom.
If you go through all these steps, and the bobbin thread is still loose (and you've tightened up the top tension), then there is a tiny little screw on the side of the bobbin case that you can use to adjust the bobbin tension. Turn the screw just a little bit (less than a quarter turn), stitch, check, etc. Once the bobbin tension is set, you shouldn't ever have to change it.
Let me know if this helps, ok?
Happy sewing!
Feb 10, 2010 | PfaFF Sewing Machines
Cannot machine quilt without the thread breaking and/or shredding. I've change needle, thread type and size and tension on my fabric.
If the thread is shredding and breaking, there is an incompatibility of your needle, thread, and fabric. Could be old, bargain bin, or poor quality thread--does the thread have little "hairs" of thread lint sticking out of it--that's probably not good quality. Look for fresh, good quality thread. Try a brand new needle--a sharp if you are sewing woven fabric. Make sure the thread is not too big for the needle eye. Sometimes, a top-stitch needle or embroidery needle will work well on FMQ. (A top-stitch needle has a longer scarf which helps protect the thread during the multiple times the needle penetrates the fabric before the thread forms a stitch. Shredding means the thread is getting worn out before it forms a stitch. A piece of thread penetrates the fabric 10-20 times before it forms a stitch.) Could also be a snag somewhere that is damaging the thread.
Sewing Needle Troubleshooting Guide
SCHMETZ Household Needle Chart
Most FMQ instructions say the upper and bobbin tension should be the same, however, I find my machine works a bit better when the bobbin thread is just a little tighter than the upper thread. Then the bobbin thread does not "pop" up on the top of my fabric quite as much. It's probably something you will just need to experiment with in getting used to your machine.
P.S.--when threading your machine, make sure the Presser Foot is ALWAYS RAISED so the top thread will seat properly in the tension disk. Failure to do this will cause thread barfs (usually referred to as thread nests or bird nests) under your fabric. Also, before beginning your FMQ, ALWAYS PULL the bobbin thread to the top of the fabric, then hold both thread tails gently in your left hand while you slowly take the first couple of stitches.
How and Why to Bring up the Bobbin Thread
Mar 01, 2017 | Brother Sewing Machines
Free motion quilting skipped stitches, breaking threads
Might be that you need to lower the tensions quite a bit, you'll have to juggle with top and bottom tensions though, and experiment for just this operation with the Sensormatic.
Mar 27, 2017 | PfaFF Sewing Machines
Needle thread breaks while quilting on machine frame
My friend and I both have the Juki 98Q but on different frames - we were both having problems (needles breaking, thread getting tangled) we removed the thin metal thing inside the bobbin case and have had no problems since (over a year now!).
Nov 01, 2008 | Juki TL-98Q
Juki TL-98Q Logo
275 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
