Question about Microsoft Xbox 360 Console
Will not turn on via on/off button also cannot turn on from controller
  • 3 Answers
For the On/Off button in the front...Take off front face plate (Pulls right off) and make sure there are small pins that stick out of tghe back side of the faceplate because they brak sometimes. If theyre there, re-instal the face plate and make sure its seated tightly against the console. If its not that check your system settings on your dashboard, go to settings and configure your system.
It might be this item that needs to be repkaced, its the power module attached to your console. http://consolextras.com/product_info.php?cPath=21_26&products_id=33
Posted on Aug 02, 2009
Polaroid dualshock probleme
turn off the ps3 plug control in via usb turn computer on with center control button
Nov 13, 2013 | Polaroid Pgps533blk Playstation 3...
Hi. Can you please tell me the correct code for the Curtis tv for Cablevision Remote? We have two remotes now, the cable remote cannot operate the volume or the power on/off tv, must use Curtis remote.....
Hello
Codes for Curtis TV with Cablevison remote control are:-
070 004 101 127 236 011 072 081 120 164
*Tip: The iO button will light on for 20 seconds. The
next step must be entered while the iO button is
on.
STEP2 Press the [INFO] button.
The iO button will blink number of times indicating the
number of each digit of the code number. Each digit is
separated by a 1 second interval of the iO button being
turned off.
Example :One blink, three blinks and eight blinks with
an interval of 1 second of iO button being
turned off, indicates the code number 138.
Note :Ten blinks is equal to the number 0.
D. Program the Volume Controls.
By following the steps below, the user can program
the volume controls (Volume UP, Volume Down and
MUTE) . The default volume control settings on the
remote control is TV volume control. If you wish you
can control the volume via your CABLE box, use the
following steps.
STEP1 Press the [CBL] button and the [SEL] button
simultaneously for 3 seconds. The iO button
will turn on.
*Tip : The iO button will light on for 20 seconds.
The next step must be entered while the
iO button is on.
STEP2 Press the [VOL +] button.
STEP3 Press the [CBL] button.
The iO button will blink twice to confirm the
programming.
To return to original state:
If you wish you can control the volume via your TV,
repeat the above steps by pressing [TV] in STEP3 .
OK.
Dec 23, 2010 | Curtis CM13102 13" TV
Error e68
Remove any disk from the DVD drive2_bing.gif.
Remove the hard drive and turn on. When you get to the dashboard turn it off again by holding the X button on the controller and select 'Turn off console'.
Wait 10 seconds and then turn on again by pushing the X button on the controller. When you get to the dashboard turn off again via the X button.
Remove the AV / Video plug from the back of your Xbox.
Replace the hard drive correctly.
Switch on the Xbox via the power button on the console. 4 red lights should flash.
Wait 10 seconds and re-insert the AV / Video cable.
You should now load into the dashboard with your hard drive profiles - wait theres more!
Turn off and on via the X button as before another 2 times with all leads and the hard drive in place.
After you power it off the second time, remove the power lead for 20 minutes and then turn on again any way you feel like it and it should be cured.
Apr 20, 2010 | Microsoft Xbox Console
Error 68 does that mean the hard drive is screwed up?
Remove any disk from the DVD drive.
Jan 21, 2010 | Microsoft Xbox 360 Console
Red light coming on the switch
this happens when the hard drive is gone faulty or is loose connected. initially try this:-- Remove any disk from the DVD drive.
After you power it off the second time, remove the power lead for 20 minutes and then turn on again and it should be cured. if the hard drive is not faulty.otherwise get the hard drive replaced.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Dec 21, 2009 | Microsoft Xbox 360 Console
My dualshock 3 wont pair with my playstation , all the 4 lights flicker but the number 1 light dont stay lit.
Try attaching the controller via cable, then turn the controller on. This will set you to the #1 controller, then unplug the controller, it should stay on the #1. Then turn the controller off (hold PS button for 3 seconds) and then turn back on.
Oct 15, 2009 | Sony Dual Shock 3 Controller for...
All light blinking then two lights stay on and no button works, i can only turn on my console (pres ps button) via usb connected to this controller. tried to reset controller, turned off console and turned...
Ok, you've probably already figured this out, but you are in possession of a worthless POS fake PS3 controller. Congratulations: http://www.youtube.com/watch?v=mji_PLB7Tb0
Don't feel bad - i just bought a used white ps3 controller from gamestop and it was FAKE. they better take this back....
Sep 18, 2009 | Sony Dual Shock 3 Controller for...
One red light on my 360
A Working Solution.
May 20, 2009 | Microsoft Xbox 360 Elite Console - Black
Got new ps3 and controller from old one will not conntect
First turn on your ps3 manually then press the PS button on your controller and with a thumbtack press the reset button on the back of your controller then connect your controller to your ps3 via usb and press the PS button and it should be synchronized.
May 06, 2009 | Sony Playstation 3 (PS3) Console
AUX inputs
Turn the ignition key to on or accessory position, turn the stereo off, then hold the function key for a couple seconds, the stereo will turn on and you scroll through the menu with the left and right arrow buttons and change settings with the up and down buttons
Feb 25, 2007 | Pioneer DEH-P6800MP CD Player
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
