Question about Uniden 5.8GHz Cordless Phone
Not hanging up correctly
Uniden WDECT 2355, was working perfectly until 2 days ago. Finished a call, hung up, went to make another call, had no dial tone. powered off the base station, disconnected the phone line, reconnected the line, powered up, had dial tone. rang the next number, all ok, pressed hang up, and checked for dial tone, nothing. Repeated power off/disconnection cycle and got a dial tone. Didnt ring a number, just hung up, went to use the phone later in the morning, and no dial tone, only an engaged signal. Thinking the base station has had it, or is not sending the correct disconnection signal/tone etc.
  • asho Dec 28, 2011
    Hi mdesmarc,
    I have the same problem - did you find a solution?
    thanks
    ash
SOURCE: All of the sudden the phone just stopped working. It says 'out of range'.
remove battery from handset then unplug base from power supply. Reinstall battery in handset then plug base back in to power.It worked for me.
Posted on Dec 18, 2007
  • 86 Answers
SOURCE: Uniden TCX805 Cordless "loses" dial tone
Sounds like the switching mechanism that creates the link is stuck. When you answer your phone, you allow the voltage to complete it's path and you either answer the phone or you hear dial tone. If that switch is stuck closed, even though you hung up the phone, the connection is still alive. When you try to pick the phone back up later, the connection is still closed, but your phone has already passed it's "if you would like to make a call" message and you hear no dial tone. Unplugging the power to the phone resets this switch and all is good again.....that is until it gets stuck again. I have seen this problem with phones after a near lightening strike at the house. Sounds like you need to get a new phone as I don't think this is repairable.
Posted on Jan 20, 2008
SOURCE: re. call waiting
Using Call Waiting
If you have Call Waiting service and a second call comes in when you are on the phone, a call waiting tone will
sound. Press [ /Flash] to accept the waiting call. There is a short pause, and then you will hear the new caller. To
return to the original caller, press [ /Flash].
Note: You must subscribe to Call Waiting service for this feature to operate. Not all features are available in all areas.
Posted on Mar 23, 2008
SOURCE: Uniden WDECT 2315 1
http://www.telecom.co.nz/binarys/uniden_wdect2315_userguide.pdf will give you the manual. Chris.
Posted on Nov 05, 2008
SOURCE: Dial Tone but won't call out.
The problem was the main phone line not the phone itself
Posted on Jan 08, 2009
When I dial number the screen blacks out & if it goes to message bank on the other end I cant hang up untill other end is finished & hung up this is a motorola defy smart phone
The only known solution to this i can think of is if you are using a task killer it is killing vital functions and causing the bug. Try disabling it or using a different one.
Mar 10, 2011 | Motorola Mobility Defy Cell Phone
Is it possible to buy a power adapter for uniden cordless N32 for the main phone model wdect2355+2 also if available the cost WDECT wideband digital
You can purchase power adapters at this link:
www.lcdpayless.com. On upper left of page search for Uniden wdect power adapter. The price is $9.99.
I found a Uniden wdect 3355+1 (two handsets; one on answering machine and one stand alone). this is a wideband (64kbps-2mbps) phone/ans. mach. It's priced at $149.95 at Yahoo shoping. The wdect2355 that you have apparently is no longer offered.
Please let me know if this is a satisfactory answer.
Master FixYa...saailer@att.net
Dec 06, 2009 | Uniden Cordless Phone
Manual for uniden wdect 2355
http://www.uniden.com.au/resources_main/pdfs/WDECT2380.pdf good luck!
Oct 11, 2009 | Lands Phones
Uniden 1725 no dial tone
I had the same problem as long as they are plugged in correctly and you put the #2 handset into the #1 cradle to register it to your base then try hanging the phone up several times. These are expandable phones so that I believe you can keep adding other handsets. So sometimes they think you have a few more handsets than you really have so when you hang up it may not know what handset you are hanging up #1 #2 or #3 #4 etc. So I had to keep hanging them up until it finally hung up. Then I had to re install them so it knew I only had 2 hand sets. So then you start from the beginning, like when you took it from the packaging. I hate these phones. I ended up replacing them with different ones. Plus I always keep a rotery phone laying around put away because during a power outage you still can plug in an old dial phone and it will work! Nothing like old technology.
Feb 15, 2009 | Uniden 5.8GHz Dual Cordless Phone
LIne In Use/Answer On Message
Just some Tips - Do you have any other phones or fax machine in the house? Check to make sure they are all hung up or press the off/ hang up button. If so, disconnect them until one brings back a dial tone when disconnected Also try cleaning the charger contacts with an eraser to the charger sends a signal that the phone is hung up.
Hope this helps!
Apr 27, 2008 | Uniden Cordless Phone
Re. call waiting
Using Call Waiting
Mar 19, 2008 | Uniden Cordless Phone
Dec 30, 2007 | Uniden Cordless Phone
Uniden 5.8GHz Cordless Phone Logo
76 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
