SOURCE: Defrost Problem
there is a drain in the middle of the defrost water collector and it is probably blocked - usually with ice. dry ot the tray and put very hot water in to melt the ice. you may have to do several times. do this until water flows away freely
SOURCE: Maytag PBF 2255 HEW refrigerator defrost timer location?
These look like schematics that might help you.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=PBF2255HEW&mfgModelNum=&fkMfgID=1
SOURCE: maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
SOURCE: Water is pooling in the bottom of the freezer
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing
it out with hot water and clorox may help.
Make sure it drains quick enough
to prevent refreezing. . The drain should be located below the evaporator coils
on the lower back of the freezer
Testimonial: "THANKS... it's all defrosted and cleaned out and will wait to see what it does tomorrow after it's all back up and running again !! Thanks !"
