SOURCE: saeco vienna deluxe espresso machine
adjust the water flow look for a knob that turn right to left minus less water plus more water
SOURCE: "Fill System/Press Steam"
Remove the tray at the front of the machine. Look inside and you will see a rubber flap which separates the right and left side of the machine. Gently lift this to the right and look inside to the left (a small mirror like from a womans compact and a flashlight will help you see in there.) You will find a small circular screen (about the size of a half dollar.) You need to wipe ALL the coffee grinds off of this screen. That should fix the problem. If you use dark beans, you are probably grinding them to fine and some of the oily residue is sticking to this screen. Try grinding the dark beans more coarsely. Only change the grinder WHEN IT IS GRINDING by adjusting the litlle knob in the box where you place the beans. If the problem started just after changing the filter you may have air in the water line and it needs to be flushed. Try running the tea portion hot water until it clears. These suggestions were given to me by Capresso and actually worked for my machine. Good luck. Gary
SOURCE: cuisinart Grind and Brew 10
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
SOURCE: My Vev Vigano Kontessa 12 cup espresso maker does not work properly
I had the same problem, so I embarked on a search mission. Here's what I found, and it worked for me. First, these pots are designed to work only for the amount of water specified for each size. So I have a 6 cup pot that requires 9 oz of water. If I try to put 8 oz. of water, I only get about 1 maybe 2 oz of coffee. Size of the grind doesn't matter as long as you stick to espresso grind (some coffee grinders have several settings for espresso grind). As soon as I put exact amount of water, it works much better. Now, you have to understand that some water gets evaporated as steam, and some water should remain in the boiler section of the pot for safety reason. The general advice is to take the pot off the burner as soon as the gurgling sound reaches its peak and just starts to subside.
That may result (as least for me) in weaker coffee than I like. So what I do, is I fill the coffee funnel with coffee grinds, tamp it very lightly, and then using a wooden skewer I make 3 or 4 holes all the way to the bottom of the funnel. That will help the steam to escape. Before I learned this trick, I thought it was a valve problem or a seal problem. As soon as I tried this trick, bingo! I personally like strong coffee. So I didn't want to compromise it and start adding less coffee to the funnel. The thing is that steam wets and expands coffee grinds, and that may be enough to hinder the process. If you make several holes, steam will not be building in the boiler section and escaping thrgough the valve or break the seal on the gasket.
Hope this helps.
SOURCE: Leaky Tassemo coffee maker
All you have to do is push the filter down into the base of the water caraf. You have to be careful as there are now 2 different types of filters being sold. The Bosch filters will not fit into the Braun machines and vice versa. The only local store to me that sells the filters is Bed Bath and Beyond and they have stopped carrying the Braun filters. The only place I have been able to find them is on the Tassimo website. Good luck!
