Question about Solis Crema SL-70 Espresso Machine
Solis SL70 Espresso Machine: Pump Switch Light Turns Off
Solis SL70 Espresso Machine: Espresso machine working okay, but green light for pump often goes off within 30 seconds after starting espresso shots. After the pump switch green light goes off, the machine recharges within about a minute, and the light comes back on. However, I cannot consistently make espresso without the green light going off mid-way. I have de-scaled the machine several times in the last few months, but not seen any improvement.
Mine has always worked that way; it only seems to have enough power to do a single set of 25 second shots before a short re-heat
Posted on Feb 04, 2010
Need a solis sl70 parts diagram
search for that on Google we do not have any info on it
Aug 10, 2015 | Solis Crema SL-70 Espresso Machine
"Dead" Espresso Machine
can you please identify the maker/model & part # of your Machine..
Thank you
May 05, 2008 | Solis Crema SL-70 Espresso Machine
Solis pallazo rapid steam. I can't remember how to clean the system
Descaling the Palazzo: The Palazzo is programmed to descale the boilers on its own, when set in the correct mode. You program the machine to descale it's self, do the following. With the machine turned on, push and hold the left 2 buttons (clean and pre-ground). This should light the top right red indicator light. Mix your descaling crystals in 32 to 48 oz in your water tank. Stir until they are completely dissolved in the water. Next, have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz's. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, all lights on the bottom will flash. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, and then close, and then open the steam knob again and let the water just flow through the boilers until it is emptied by the machine. Don't turn off anything until the machine stops on its own. This will clear the descale light. Refill the water tank again with fresh water and your ready to go.
Sep 10, 2010 | Solis Palazzo Espresso Machine
Trying to relpace the on/off switch on my solis crema sl70. I have the machine apart, but can not get the switch out of the face plate. Anyone kn ow the secret?
Hi The foil on the front has to peel back until the switch will push out the front. Peel from a corner. Make sure that the switch goes back in the same way.
Feb 17, 2010 | Solis Crema SL-70 Espresso Machine
Need a new on/off switch-Solis Crema sl70-San Diego
Hi
Do you have a thick or thin switch? If its the thick one I have one.
Dec 27, 2009 | Solis Crema SL-70 Espresso Machine
Solis palazzo espresso maker / water tank problem
HI
Did you push the water button, before you opened the knob? When you finished descaling did the lights change? On any compact machine you need the let the pump stop on its own. Then go to the next part, rinsing. Again letting the machine stop on its own. Pump will stop and the lights will change. Once the machine has finished rinsing. You will have a steady water light and a blinking green light. Put your tank back on with fresh water, then push the water button(far right), then open the knob for water. The red light should go out, and the machine will heat again.
Dec 22, 2009 | Coffee Makers & Espresso Machines
Does not warm up
HI
If you don't have any other lights on, it could be 1 of 2 things. Your boiler is bad or your power board is bad. Can you get steam or hot water?
Oct 25, 2009 | Solis Palazzo Espresso Machine
No water supply on Solis Master 5000 Manual
open steam valve and run water couple minuts,after try again if light show up again thats mean machine is somewhere clugged
Aug 23, 2009 | Solis Master 5000 Espresso Machine
Hi, cleaning cycle stalled, all lights on, machine stuck
We forced the mechanism!! Works like a charm!  I think we'll get a backup, the french press didn't cut it this AM.......
Feb 14, 2009 | Solis Palazzo Espresso Machine
WHERE can I download the FULL SOLIS SL70 Owner's Manual????? Please reply to: kchunt@canby.com
Follow the links from the Coffeegeek review for the English manual:
http://coffeegeek.com/proreviews/detailed/cremasl70/operation
Jun 08, 2008 | Solis Crema SL-70 Espresso Machine
Solis Crema SL-70 Espresso Machine Logo
264 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
isaac johny
isaac johny
Colin Stickland
Colin Stickland
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
