It shouldn't be getting any "drain" water anyway. Be sure the door gasket is good because this seems like a condensation problem. Is it holding cold temperatures?
Testimonial: "It holds temp fine , door gasket fine, seams like it's defrost water with no where to go ??"
SOURCE: refrigerator
check behind the drawers is there a water tank for water in thew door that would be my first guess
SOURCE: Water collecting in refrigerator and ice collecting in freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you access to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somewhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wire around the heater( black heater right above the drain trough) and stick it in the whole maybe an inch or so. now every time the heater comes on to defrost it will prevent the hole from freezing over
SOURCE: How do I find the drain hose/plug on a 1996 kenmore refrig.
if you open the fridge door in the top you will see a small funnel typy that goes tru your back wakk this is where it normally cloged pull it out if no screws that hold it then clean it out or blw tru hose in the back of fridge if you can get access to it thanks from gille
SOURCE: Water draining under crisper bins & onto shelves. Try again
Your drain tube is stopped up. Take the panel off in the freezer section and chip away the ice in the pan below the coil. When you get to the drain hole pour hot water in it until it free flows. You will need a towel in the freezer to catch the excess water. Run some extra hot water through it to assure that you clean the drain out good.
SOURCE: Refrigerator has water under the crisper drawers
There is most likely a plugged drain in the freezer section. The easist solution can be to empty the refrigerator and unplug it over night. If this is not possible then the back or bottom should be removed to allow access to the drain and a hair dryer can be used to make defrosting go faster. still takes a while, if there is access in the back of the unit that can be the cause of the plug.
