Question about Dell (E210882) Motherboard
NOTHING COMES ON NO SIGNAL TO MONITOR CHECKED POWER SUPPLY STILL WONT COME ON
  • aqqalu May 11, 2010
    Can the computer turn on?
  • dewey wyatt May 11, 2010
    maybe a bad video card or motherboard. unsure as to what you are working on
  • 433 Answers
If the power supply is good and showing proper voltage to the rails but no fans turn and absolutely no power is going to the computer, then it could be the processor or motherboard is burnt out. Check that power cable is firmly connected, the switch to power supply is on, and there is power going to the outlet.
Hank
Posted on Aug 05, 2009
Hello I am repairing a philips tv 32pfl3504d/f7. I replaced the main power supply CBA and the inverter CBA and still have the same problem. The power light comes on when the unit is plugged in and blinks...
This problem it is the main tv Tuner signal board it is dead also.Beside the power supply board.This problems have nothing to do with the long LCD invert board.
Jun 07, 2011 | Philips 32PFL3504D 32 in. LCD TV
I have an X2Gen MW22U monitor. While using, I heard a heavy static sound, then the monitor went black. I can't get it to work now. I disconnected the wires and then reconnected. Restarted the computer....
You should powercycle the Monitor.
Unplug the printer from the power and press and hold the power button on the monitor for 30 seconds. (It wont show anything)
Try the same again than.
Sep 23, 2008 | Computers & Internet
My Acer aspire ax1700 PC dsektop wont work and here are the steps I took: First one day it wouldn't power up - The power led would blink once the fan (power supply) would come on for a split second and...
Hi, I had the same inital problem as you, except I didn't put a new video card as I was please with the Onboard card performance that even has an HDMI port. Not sure if your problem is solved already, but in my working process, I first suspected the Power Supply, and I had everything out of the case but the Mother Board. When I tried to fire it up I was always getting "No signal" on the screen, not even a blink from the BIOS. I then put everything back in place, then after the HD started spinning of and Windows booting, the screen started coming on. I felt it was like if I needed Windows to have a clean booth to replace the video drivers and switch to the InBoard card. Hoping this of any help.
Feb 12, 2011 | Acer Aspire AX1700-U3793A PC Desktop
Replace power supply, computer on, monitor no signal, help
Did you forget to connect the 4 pin power plug to the display card or motherboard??????????
May 16, 2010 | E-Machines eMachines Desktop PC
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
My lcd screen does not show images projected by the computer, when the RGB cord is unplugged it says check cable setting and when adjusted and it picks it up it still shows nothing
Good day sir/maam, there are several reasons why your LCD monitor acts like the one you say. but let us start with the common ones.
  • check your PC if there is the video signal going out to your monitor. (simply, is your pc working fine?)
  • check your contrast/brightness control.
  • check what type of signal your monitor is accepting, VGA/DVI/HDMI/S-video?
If the above, did not solve your problem, there is serious problem with your monitor's power supply, check first if it is 110v/220/or autovolt that is 100-240v. Still wont work? at this point you have the option of taking it to your dealer for repairs or you do it your own. if you do, you may need to dissassemble your monitor. Check out your switching power supply section. you will find there the fuse, switching transistor on a heatsink, a high speed transformer and big capacitors, a switching oscillator IC. you have to test them one by one. until you find the bad part.
I suggest to bring it to your dealer. you may need extra cash.
Oct 02, 2009 | Computers & Internet
Pc won't start
Check the power supply on the PC. Make sure it working. When you first plug in the power to the power supply unit, the fan should "Jump" alittle.
May 06, 2008 | Computers & Internet
No Power LED and Nothing on the screen
Check your power supply to your screen cause it should at least show a amber light at the screen to show that there is power but no proper signal from the computer.
So below are step to check the power supply to your monitor. Assuming if you use a different monitor on your pc it works
1. Check your fuse both internal and external
2. check if power is receipted by the LCD
Mar 24, 2008 | Dell 1704FPTt 17" TFT LCD Flat Panel...
Booting problem
Hi Yunisa,
I need a little more info on this issue. Do you hear the power supply fan operating when you switch the server on? Did the server still startup even though the monitor is not displaying? Did this problem just occur or where there other signs of a problem coming? This may sound a little foolish to you, but check to make sure that the server is plugged into power and that the monitor is connected properly. There should at least be a message on the monitor indicating there is no signal coming to the monitor. The first thought that comes to mind if all is connected would be that the power supply has failed. Please check this out and get back to me with info.
--RoadHawk
Nov 05, 2007 | Dell PowerEdge 1800 Server
Wont power on
hi , please change the signal cable which is connected from CPU to monitor. please rate this comment.
Sep 15, 2007 | Mag Innovision LT765b 17" Flat Panel LCD...
Dell (E210882) Motherboard Logo
143 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
