The no-signal timer indicator is in the middle of my screen on my video channel.This prevents me from taping or watching anything on my vcr. i don't have my original remote control for my tv i have an all in one.the timer starts showing 05.00 then counts down to 0 then repeats itself continually.How do i get this to go off ?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, please postback with the brands and model numbers of the TV and the universal remote. Additionally, describe how the TV, VCR and any other devices are interconnected, the number & colors of the cables and from what jack to what jacks
Offhand, the no signal indicates as the term implies, that the TV is not receiving anything. Have you tried pressing INPUT or SOURCE on the universal remote to cycle through the available video sources?
Good luck and thank you for asking FixYa.
Posted on Aug 02, 2009
My Samsung TV work fine. My RcA VHS VCR when I want to record the screen said WEAK or NO SIGNAL
VCRs use Channel three or Four to watch the tape. It is better if you use the video out on the VCR to go IN to the TV video In on a modern TV.
For record, the VCR cannot see Digital TV. You must connect the Digital TV box or satellite box Video Out to the Video In on the VCR.
Feb 21, 2012 | RCA Televison & Video
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
Rolling picture and blue screen
According to my Satellite provider tech support. More and more channels are being encoded so that recording equipment cannot capture the signals to prevent piracy. I know the premium channels use this technique now. I would call and ask tech support if there is any copy restrictions in place that would affect your VCR recording before doing any further trouble shooting on the VCR. If you can play pack a prerecorded movie fine with your VCR then it should also record fine. Also try watching the channel through the VCR tuner and I bet you will see the same pattern. The VCR can only record the signal it is given.
Hope this helps you,
Ron
Feb 24, 2010 | Samsung DVD-V5500 DVD Player/VCR
I have an older but operable Sanyo VWM-700 4 head hi-fi VCR to connect to an older but operable 13" TV just to watch workout video cassettes(via cable, no cable box necessary).How are the connections made...
You connect the Antenna to the VCR, you connect the AV OUT from VCR to AV IN on TV.(Yellow, Red & White) (Doesn't matter as long as color to color) Then you TUNE the VCR to the channels and the TV simply acts as a monitor. You must tune the TV to the OUTPUT from the VCR. If ya play a tape and look for the signal on the TV, to "Tune it in" to the VCR. first. then go to tuner.
Jan 26, 2010 | Televison & Video
Toshiba D-VR650 can't tape says canot record protected image
THERE IS A TAB ON THE VCR TAPES IT CAN BE BROKEN OUT TO KEEP PEOPLE FROM TAPING OVER YOUR PERSONAL TAPES.LOOK AND SEE IF THIS IS NOT BROKEN OUT. IF IT IS PUT SOME TAPE OVER IT AND IT WILL RECORD ON THAT TAPE AGAIN.
Feb 10, 2009 | Toshiba D-VR650
VCR ejects tape when I try to record using the timer facility
Simple. The Cassette's 'Prevent Erasure' tab is missing. Just cover with Scotch tape and reload. Now try recording.
Nov 29, 2008 | Televison & Video
Go video VR3845
Try unpluging the unit and the plug it back in
Apr 19, 2008 | GoVideo VR3845 DVD Recorder/VCR
Can not tape from cable, blue screen
If you have a cable box connected now, leave the VCR on channel 3 all the time and use the channels from the cable box.
The way this should be connected is cable in to cable box and cable out to VCR, VCR output to TV IN.
Hope this works for you.
Feb 11, 2008 | RCA VR348 VCR
Sound only works when vcr is turned on
When not watching a tape, be sure power is off ( VCR ).....
How is the picture...? When you watch tapes, do you put the
TV on channel 3 or select video..? Also, what is signal source ?
Cable ? Box ?.....................T.
Dec 05, 2007 | Panasonic CT-27G13 TV
VCR tuner cannot tune in my cable channels
It is working as designed. The purpose of your cable box is to take in a wire containing all of the possible channels you might watch, and then extract *one* channel, and force it to appear as channel 3. If you connect the cable directly to the VCR, then the VCR's "tuner" (ie, channel selector) has an opportunity to extract any channel it wants. But... as you point out, your VCR won't be able to "see" any of the digital channels. So... if your goal is to be able to watch any of the digital channels, the signal must pass through your cable box, which will put the selected channel on channel 3. There is no value in going from the VCR to the cable box, since the VCR's tuner will have already filtered out all but one channel. It would be helpful to make a list of what your useage goals really are, since there are so many different ways to hook these things up. Are you interested in: - watching digital channels? - recording digital channels? - watching one channel while recording another? - using higher quality video signals (composite, s-video, component, etc) rather than RF (ie, channel 3) And so on. Keep in mind that you have *three* tuners: Your cable box, your VCR, and your TV. It sounds like only your cable box can tune in the digital channels. If your cable box puts out any non-RF signal, then the best choice would be to go: Coaxial Wire -> Cable Box -> Video Connection -> VCR -> Video Connection -> TV, with the VCR and the TV both set to "video". Then you would only use the cable box as a tuner, the VCR would only see the tuned channel (via video in), and the TV would see the same channel (or whatever tape you are playing) on its video input.
Mar 29, 2007 | Zenith VCS442 VHS VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
