Refrigerators Logo
g
gerald kramer Posted on Jun 25, 2018
I need to replace PCB for my b&d fridge 5210-60 5210-06 were can I get one
How do I fix the gas side of my Thetford N104 fridge?
Yes, it does. Check the wire to the electrode, if the wire is ok, then the problem is in the pcb.
1helpful
I have a BEKO GNE134620X fridge with a multifunction compartment, that only works correctly in fridge mode. When switched to freezer mode it will not cool below -6C. Does the main pcb need replacing?
is anything blocking the sensor,if it does not cool below -6 and where are you checking temp it could be a refrigerant problem.Turn fridge off for 10 min and start again.
I have a Samsung RL55VTEBG fridge/freezer and the LED display is not displaying properly/not responding. Is it the PCB board that needs replacing? If so, where is it located? Thanks.
First disconnect refrigerator from the power supply for 3+ minutes. Then reconnect power supply. If prolem remains ,then the PCB output voltage should be checked beforE replacing the PCB.
Model GD5SHAXMB00. The digital temp numbers are blank for both fridge and freezer and the water filter red, orange, green dot is dark and cannot be reset.
check the pcb board then locate busted fuses replace it then after reset theres nothing happen possible your pcb damage need replacements.
1helpful
Freezer keeps defrosting up, thought timer pcb was the main pcb in the back of refrigerator replaced that but still keeps frosting up, heater is fine
There is whats called a defrost termination sensor in behind the back panel of the freezer it has failed & needs to be replaced.Very common problem in electronic fridge's.
My fridge is freezing everything. I've received advice that I need to change the SENSOR and or the PCB which controls the temps. Does anyone one know where these components are located in the fridge. I...
Not sure if you have got this fixed, but it is highly unlikely to be the PCB. There are diagrams (via google) to show where parts are and the service manual is downloadable if you search your model.
2helpful
2answers
I have a Whirlpool Refridgerator model WBM39MS. It stopped cooling and I had it repaired. The Repairman replaced the electronic control box. Repairer claims that the compressor is working. It now seems...
Hi Lollipop, partially working fridge? A fridge either works or not, cold air is made in freezer then distributed to fridge via a vent. In your case WBM Series fridge, top mount freezer blows air down a vent (back centre of chiller compartment). A common fault with the WBM Series is both the PCB and Interface Panel (PCB beside compressor back of fridge, Interface is display panel front of fridge).
So if freezer is cold and fridge not, try a fan motor. If compressor doesn't work either comp is faulty or PCB has blown(has a burning smell).. Hope this helps you and maybe many other ppl.
Replacing the PCB
There are two screws located underneath the silver sticker, of all places. You need to pull the sticker back just a few inches on either side and there you will find the two hexagonal screws.
Remove these two screws and the PCB Board will slide out. You will also see where the thermostat probe plugs into the board and then snakes to the back of the fridge.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
