Question about Carrier 38CKC036 Air Conditioner
A/C fan very loud
The A/C fan on my exterior unit didn't start up two summers back. I tried manually rotating it a bit, which fixed it, and it has worked fine for about 2 years. Recently, a visitor noted how loud our fan was outside. It is much louder than identical units nearby, though it still works and cools our house well. Is this likely to be a lubrication issue, or possibly a capacitor or motor issue?
  • 86 Answers
Sounds like a motor issue check for loose bolts on top of the unit i would get the unit cleaned and have the technician look at it
Posted on Aug 02, 2009
  • t1m130
    t1m130 Aug 02, 2009
    sounds like a motor issue check for loose bolts on top of the unit i would get the unit cleaned and have the technician look at it
    New Friend:
    Problem Solver:
  • 18 Answers
If the air coming from the condenser is not hot or warm you may be hearing the compressor trying to start but it will stop after only a few seconds as the overload opens and shuts it down. The compressor could be bad or there may be something keeping it from starting properly. This is not good and you should leave it off until someone can come out to look at it to prevent possible further damage. The other possibility is you are hearing one of the components inside the electrical compartment buzzing. This one is not so bad but can still cause more problems if not addressed soon. Can't really go into much more detail about this as it involves high-voltage parts and the rules forbid DIY instructions. Someone may read this post and think "that's what wrong with my system" and attempt to fix it themselves. Either way it is something that I would recommend having looked at soon unless the weather is mild enough for you to go without the A/C for a few days.
Posted on Jun 03, 2013
I installed a fujitsu asu24c1 unit in my garage a few years ago. I used it for one summer, didn't turn it on last summer and when I turned it on this year it wouldn't cool. I have troubleshooted...
With the limited information i would suggest the following:
Check to see if the outdoor unit is running.
If the outdoor unit is running, grab the large copper line coming out of it and see if it is cool.
If the fan outside is running and the line is not cool then the compressor is not running or the system has lost its refrigerant charge.
Check these things and repost for a more complete answer.
Hope this helps.
Sep 05, 2011 | Heating & Cooling
Our unit has been working fine - suddenly quit - we have no air, no fan. Power is getting to the unit - both the exterior and the interior LEDs are lit. It has had heavy use all summer... ideas???? The...
The fan/condenser motor bit the dust....when that goes nothing works... can be a ****** to get a new one and change it...need to take it apart from the top...
It will then look something like this...the motor you will need to change is the one under that flat sheet metal shield in the center...
heatman101
Aug 26, 2011 | Coleman Mach III Air Conditioner
My Sunbeam air conditioner has always flipped the breakers in my house (old wiring), but it worked fine for two summers and then sat last summer. This summer it blows the breaker constantly and in the...
This is a good question to ask. 1. if a unit trippes a breaker its for 2 reasons. A. to protect the wiring from catching fire . B. to protect you from electrical contact with ashort condition. Before you buy a new unit I would recommend you fix the wiring as bad siring is ******* the unit and costly to operate due to load resistance. Also replace any breakers that are unsed to support this unit. Brealers go bad esp if they have been problematic in the past. I am not certain as to the size of the unit you have now but if it cooled the room well then replace it with a match or a bit bigger unit.
As to why it tripps the breaker now? could be a couple thing Bad wiring like you state. weak breakers as I pointed out. or a bad compressor or fans. Or in my view its most like a combo of all the above. Hope this helps let me know.. Jon
Aug 03, 2011 | Kenmore 76129 Air Conditioner
E805 ERROR OCCUR. WHAT IS THIS
Hi.
E805 is Fan Rotation Error. It means that one of the internal fans have failed. Problem is repaired accessing service mode. Identifying the defective fan through the sub-code. Reading DC voltage to fan. Replacing fan or troubleshooting supply problem.
The repair is suitable for a technician or for an expert DIYer.
Try powering down the unit (disconnect power cord), and see if this can clear the error code.
Call Canon number listed on the user manual to contact support.
Jan 09, 2011 | Canon imageRUNNER 400S Copier
Can not find directions to reverse fan rotation for summer
it should be a simple slide switch on the side of the housing that moves up and down to change the direction of rotation of the fan motor and blades. look at the manual that came with the fan to make sure it has this feature but i personally have never seen a fan without one.
May 30, 2010 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Samsung home theater HT Z410 fan chk will not stay on anymore
Can you see or hear if the fan is running? Is there sufficient clearance (4 inches) between it and the nearest surface for airflow? Is it clogged up with dust bunnies? You may be able to fix it yourself.
Unplug the unit. Look inside the vent at the rear. Reach in with a non-conductive probe to see if the fan turns freely. If not, it's bound up and needs replacement or unclogging.
If it turns freely with power off but doesn't rotate with power on, it's dead.
If it turns sufficiently fast with power on and you still have Fan Check, it's a sensor.
Resolve this issue and it will probably stop trying to protect itself by shutting off.
Feb 08, 2010 | Audio Players & Recorders
OUTSIDE UNIT OPERATES BUT FAN DOESN'T TURN AND UNIT DOESN'T COOL.
the motor could just be locked in place from sitting...take a stick or something and try to see if it spins be sure of rotation! you can also give it a little nudge while it is on and it will take off! if this happens then you have a bad start compacitor but no there are no fuses that only protect the motor!
May 25, 2009 | Goodman CKL42AR42 Air Conditioner
Scraping sound inside casablanca stealth fan
You need a new flywheel. Go here: http://www.bostonplus.com/parts.html#flywheel
Jan 24, 2009 | Casablanca Fan Stealth 3211T Ceiling
Ariston Fridge not cooling - Frozen Coils
Try to check the noisy fan, slow rotation of fan can cause the icing evaporator. Unplug the unit and rotate the fan manually by your finger check if the fan is not misalign or not touching the fan frame. Or check if fan motor bearing is not worn out. Under charge of gas is also one of icing cause.
Feb 20, 2008 | Ariston Technologies CBC96 Wine Cooler...
Carrier 38CKC036 Air Conditioner Logo
167 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
