Question about RCA D52W23 52" HDTV CRT TV
Letters and numbers are 3d and curved picture
When u turn tv on red, green, and blue lines curve across the top of tv
  • 39 Answers
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Posted on Aug 02, 2009
Picture is bowed inward and looks like a 3d image without the glasses. I also have a green, red, and blue line curving across the top of the picture.
Looks like the focusing lens may have moved a bit or the projector lamp has gone weak. Get a technician to check up the projector.
There's very little you can do here.
Mar 05, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Top left of unit, there is a blue green stripe the covers five inches of the TV. When I hit the cable guide, the letters curve down to the right and look like they are in 3d. With a blue green and red...
Tv will get worse and will dies completely causes more damages to the other tv boards if continue using the tv this way.The tv have a problems known as a convergence problems,it dead.The tv convergence board require replacing 2 STK convergence ICS and some or all of it resistors to fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 20, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
The picture looks 3D
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
Blue line across top of my Sony XBR 60
KDF-60XBR950 replaced bulb, but no picture. It DOES have a solid green light when on.
Jul 21, 2009 | Sony Televison & Video
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Picture in 3d without the 3d glasses
Replace 2 convergence chips, will start with stk ###-###
Oct 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Nov 19, 2007 | RCA HD56W66 56" HDTV
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
RCA D52W23 52" HDTV CRT TV Logo
461 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
