My comp wont boot up
My computer wont boot up... some orange light blinks at the power button... please help!!!!
  • dorr221 May 11, 2010
    Check on back for 4 lights that are diagnostic lights then post what those lights show, also post the model of the Dell PC.
    Problem Solver:
  • 8 Answers
Several possibilities here, no quick solution.
1. Could be the graphics card is dead or monitor unplugged. If its a PC and the box has been moved recently, the graphics card could have been dislodged in the slot. In any case check for signs that the computer is continuing with normal startup. Such as HD activity led flashing. If the machine shuts down immediately when you press the on button, it is probably not the graphics card.
2. Motherboard, could be faulty, do you get any beep codes when starting up? It's probably Phoenix BIOS, but there are others. The beep coded for this BIOS are in 3 blocks of 3 beeps. To check if its the motherboard, if it's a PC, power off, open the box, and remove any cards in add on slots, Including memory barettes. Power on again, no beep probably signifies mother board fault, so replace.
3. Could be a faulty add on card such as internal Modem or sound card, so do as above. and try booting without add on cards but with memory in slots.
4. could be a rogue Hard disc or CD/DVD, so take unplug the cabled connecting them to the mother board.
5. Even though the thing lights up, it could still be the power unit and the only way to check this is with another power unit.
Good luck, for further help email me at its.the.merovingian@gmail.com
Posted on Aug 02, 2009
    Problem Solver:
  • 15 Answers
Try reinstalling the OS, I hope this will resolve this issue.
My computer can't boot at all after switching it of for some days now. the power led just blinks orange and that is it...please what do i do?
Replace the jumper back into it's original position. Remove the power cable & hold down the power button for 15 seconds to reset the board. replace the power cable & attempt to boot.
Jul 16, 2012 | Computers & Internet
Dell mini computer power button blinks orange whats the cause?
A blicking power light and no boot indicates one of two things. First, an error on the motherboard caused by failed capacitors or two a power supply that is not putting out all of the correct voltages. To check the motherboard look over this article:
http://www.ccl-la.com/blog/index.php/dell-optiplex-745-repair/
If you don't see any bad capacitors then the power supply will need to be changed.
I hope this helps, if so please rate my solution.
BuddyMc
Nov 29, 2011 | Dell OPTIPLEX 745 PC Desktop
My laptop wont turn on and yet its fully charge. The power light keeps on blinking with orange and when i push the start button, it turns green and when i stop pushing, it turns orange again-blinking.
Hi.
This sounds like there is a problem with the battery.
Remove the AC mains power and take out the battery from the laptop. Plug AC power back in and try booting the laptop up.
If it boots up let it boot into Windows/linux and then shut the computer down as normal. Remove AC power and re-insert the battery. Plug AC back in and power it up, see if it does the same thing. If it does the same thing the battery is faulty. If it boots up with the battery in then there was a glitch.
Regards.
Jun 08, 2011 | Sony Computers & Internet
Dimension 3100 turns on the power button has a steady orange light there is also an orange light on motherboard cpu and power suplly fans working but wont bot up
Blinking amber (orange) indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this could indicate a problem with the power connections for the CPU on the system board (see "Power Problems" in your Owner's Manual).
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
My computer is blinking orange light
In addition to the power supply, motherboard issues can cause the blinking power light and no boot problems. The Optiplex 270, 520, 620, 745 and 755 units are all known to have issues with capacitors on the motherboard. Here is a link to an article about this issue and what to do about it:
I hope this helps, if sol please rate my solution.
BuddyMc
Aug 10, 2010 | Dell OptiPlex 360 Desktop Computer
No display and wont boot
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Power supply is easier and cheaper to replace.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 12, 2008 | Dell Dimension 4700 PC Desktop
Dell GX 280 wont start
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Thank You.
Oct 30, 2008 | Dell OptiPlex GX280 PC Desktop
Dell comp
To help you better , could you let me know , when the system goes into sleep mode, the power light in the front of the tower is it amber or blinking amber or is it of some other color.
If the power button is blinking amber , the power supply on the unit is going bad.
Thanks
Proton
Oct 29, 2008 | Dell Dimension 2400 PC Desktop
Booting up
one light is for hardrive activity , the other is to show the power is on.. the flashing one is most likely the power light as most computers will tell you when thier ill....the beeping is an error code and should be in some pattern EG: Power LED blinks red twice, once a second, followed by a two second pause. Or something like that. Take note of the pattern and repost it here, then we can give you a specific area to look at.
Sep 16, 2008 | HP Compaq d530c PC Desktop
IPOD Shuffle doesn't work at all
If the status light blinks orange when you press a button, the iPod shuffle buttons are
disabled. Press and hold Play/Pause (’) for about three seconds, until the status light
blinks green.
Jun 13, 2007 | Apple iPod shuffle Second Gen. Silver (1...
Computers & Internet Logo
200 people viewed this question
David Payne
David Payne
