Question about Kenmore Heating & Cooling
I just bought a kenmore 15,000 btu and ther is a lot of water behind the filter screen is this normal
  • 232 Answers
An air conditioner is a dehumidifyer make sure it is level the water should drain out the back
Posted on Aug 02, 2009
    President:
  • 1,188 Answers
If the humidity is high then there can be some water nut too much water indicates the the condensate drain is blocked or partially blocked.
Washing machine will not drain or spin out the code is f21
On some Kenmore machines an f21 code indicates a "Long Drain". It is taking too long for the water to drain from the washer. This is normally caused by a clogged filter in the pump assembly. On the front loaders the filter is behind the bottom cover below the door. The filter cover unscrews from the pump, and if your washer is holding water, the water will run out on the floor when the filter cover is removed.
Jun 20, 2015 | Kenmore Washing Machines
Model 25373156301 air conditioner: What are the dimensions? How many BTU? Last year they were manufactured?
Found very little on that model: Kenmore 25373156301
24 in. Wide, 18 in. Height, 24 in. Depth and approx. 112 lbs.
15,000 BTU, Parts are still available.
Unknown date(s) of manufacture but Sears (Kenmore) does have similar (exact matches) models still in production.
Sep 13, 2014 | Heating & Cooling
Need to know BTU of Model ACQ158XSO Serial QT0601317
That would be a 15,000 BTU air conditioner...
That is what the "15" stands for in the model number...
heatman101
Apr 12, 2011 | Whirlpool ACQ158XP Wall/Window Air...
Washer stopped, motor hums, door locked, water still in tank. how do i clear and restart?
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time or is actually jammed by a foreign object.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER- THERE IS LIKELY TO BE LOTS!
With the filter removed it is normally possible to see and check that the pump is free by hand/finger.
Afterwards it is also possible to check that the motor does work-
filter still removed, power back on, an empty drum, all water having been removed by removing the filter then select a spin cycle. At some point you should be able to see the pump start operating. If it doesn't there lies the problem.
It's surprising what people have found in their filters! It is always worthwhile checking it on a regular basis.
Hope this is the problem/cure and good luck!
John C
Feb 11, 2011 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore elite Model #795 7554 2501 MFg date 2005-01. The water container behind the left door is leaking I need a replacement. Can you help
in trying to locate this model # with sears data base it didn't come up. i don't know of any kenmore that has a water container behind the left door . left door being the freezer door .. the water container is located in the botttom of fresh food side in the back behind the crispers . if thers a leak in the freezer door i would think that it a water line that is carcked or come loose .. mm hope this helps .. pls reck your model # and in needed get back with me ..mm
Oct 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water in air conditioner
A lot of the newer window units design the outside fan to pickup the condensate water and sling it onto the coil. The evaporative effect makes the unit run more efficiently. They ususally don't spit, but if the unit is running well, otherwise, I would't worry about it.
Jul 22, 2010 | Kenmore 6000 BTU Single Room Air...
Ready Heater wont start
Most likely,the motor is going bad,or the filter for the intake air is stopped up,if the filter is fine,then the motor is locking up,just replace it.
Jan 09, 2010 | Reddy Heater-10-12-15,000 Btu L.P.
New Frigidaire 15,000 AC makes knocking sound
Knocking happens when the compressor is faulty. The clicking is often the overheat Klickson switch clicking on and off. If is three weeks old, call it in under warranty.
Jul 10, 2017 | Heating & Cooling
Need the BTU rating for an old Kenmore K948991 a/c
Your model number is not complete enough for a model check.
However, 18,000 btu in todays' units is what you need.
Mar 28, 2009 | Kenmore Heating & Cooling
Heating & Cooling Logo
94 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
