Question about Refrigerators
Ice dam in small tray under the water spout. We
The ice maker has an ice dam in the small tray (1''x2'') under the water spout, so water can't get to the main ice tray. We turned the water off while on vacation, and it was frozen when we got home i.e. no ice.
  • Anonymous Mar 29, 2014
    ice dam water leak
    President:
  • 1,188 Answers
Turn off refrigerator and open its door. The ice maker will resume operation once it get defrosted.
Posted on Aug 02, 2009
  • 232 Answers
Bad water valve
Ice maker spout starts to freeze up (6years old Viking side by side), is there a solution?
low water pressure or faulty valve
low water pressure the valves do not seal proper and slow drips freeze up in tube
are you on well/?
last time fridge filter was changed?
if all good faulty water valve
Mar 28, 2017 | Viking 48 in Built In Professional...
Water is not getting to ice maker.
If your ice maker water valve is dripping like an old faucet it can build ice in the spout causing the water to be blocked wen the ice maker powers up the water valve for 7 seconds to fill the ice mold. Either that or the water valve itself is bad physically or electrically.
Jun 20, 2012 | GE Refrigerators
Franklin chef ice maker fim70 finished running cleaning cycle. have cleaned plugs, lines, on rear and sprayer inside bin. water continues to run, ice forms on top (w/ frost). Ice never drops.
Hello
Ice may jam up in an ice dam and close off the chute. Shove the ice scoop up into the chute with a fair amount of force to break up the ice dam. Chunks of ice should fall into the bin, followed by a shower of ice cubes.
Jun 21, 2011 | Franklin Freezer Chef FIM70 Commercial Ice...
Ice maker drips water into ice tray
Probably the solenoid valve leaks(electric valve that opens when the ice maker calls for water) and overflood the ice maker,the only way to fix this is replacing the solenoid.
Sep 22, 2009 | Kenmore Refrigerators
Maytag mff2557hew ice maker is leaking water and the water is freezing directly under ice maker in a huge glob
ice maker is leaking water and the water is freezing in holding tray causing a ice dam in container.
Jun 07, 2009 | Refrigerators
GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Mar 26, 2009 | Refrigerators
Water not getting to ice tray
Sherman usually (not always) the problem is a frozen delivery spout coming in back of the freezer. look where your ice maker and on the back wall and up behind that you will see the delivery spout area. The water valve may be bad or not opening also but it most likely has 2 solenoids 1 for water in the door and 1 for the ice maker. If you have checked and have the ability turn off the water and reverse the water inlet lines on the water valve. This is just to make sure the water passage is open. Hit the cold water cupplunger then look and see if you have water that cam into the ice maker if not your problem is in the valve or the line to the ice maker. Next hit the same plunger with the water line disconnected if you have water then your problem is in the freezer delivery and needs defrosting and cleaning if its a plastic spout it probably has lime covering it inside and freezes over or the water valve is leaking by a little and refreezing. with the water line off yuo will quickly know if its leaking by. and cover with a towel to prevent a mess if it sprays out when you try the plunger. If it still dosnt work try to check the coil on the water valve both coils should read about the same. If after all this works and you have water everyplace (thats why I said use the towel) the problem is in the ice maker circut. Either it is the main power, the ice maker motor its self, or or most likely its the fill valve switch.In any case if you purchase a new replacement Ice amker head all this will be new.OR Either replace the switch if it checks open or if its loose or there are broken parts. It requires a cam to open and close the switch so it only opens for about 5 to 15 seconds. .Hope this helps you let me know if I need to tell you more. Rate me accordingly please and Good luck.
Mar 12, 2009 | Refrigerators
Ice maker nor making ice
hi thanks for the question use a hair blower to thaw the tube and then pull the tube out clean and reinstall thanks te appliance doc
Aug 10, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice build-up in back of freezer
you probly got a water inlet spout froze over.. take out ice maker and look where water inters icemaker and see i that is froze
Aug 23, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Side by side fridge / freezer - Icemaker problems
What kind of ice maker do you have? Is it "Ice Maker Plus"? Pull the ice bucket out so you can get a better view. On the back of the freezer is a spout ramp that should connect to the back of the ice tray water deflector that the wire connects to. (I know, It's cold in there). The water deflector is connected to the back of the ice tray which sends the water to the tray. It should snap in.
Jul 06, 2007 | Whirlpool ED2FHSS Side by Side...
Refrigerators Logo
139 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
