Question about JBL SCS145.5 System
Is it possible to connect jbl scs 500.5 with a computer without an amplifier
3 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Hello. I have a jbl
Judging by the simple fact that it has NO AC power cord or supply - NO.
http://audio-vintage.pl/product.php?id_product=198&id_lang=1
Posted on Aug 07, 2011
  • 52096 Answers
SOURCE: Sir I have denon aur 1312 pairing jbl SCS speakers and woofer. Everything being ok many times my woofer doesn't work...is this amplifiers problem or woofer issues.? Pls help me in this
sooner think it might be a connection problem check for a loose wire .
Posted on Jul 03, 2016
Hi, I bought a new JBL SCS 140 system with amp HK
Fuses blow when something is shorted. In this case it will be a semi-conductor of some kind. If the device uses IC for the main amplification then you are right to be worried!
The 158 amp is totally unsuitable for the JBL.
This is the specification of the JBL:
  • Recommended Amplifier Power 10 Watt
  • they are also 4 Ohm speakers.
  • 158 is: Output Impedance / Channel
    8 Ohm.
May 31, 2017 | JBL PB10 Subwoofer
Hello!!! Thanks for letting me ask these nagging questions. I bought a set of six JBL Home Theater Speakers.I did manage to have them connected and working. But I face a dilemma: How do I connect my...
You want to connect the JBL's to the yamaha using standard speaker wire. Get a few HDMI cables and run one from the blu ray to the yamaha and from the yamaha to the tv. To use the JBL's for watching tv, get an optical cable or coaxial cable (either will work) and connect that from the tv to the yamaha and you are all set.
Aug 20, 2011 | JBL Dual 8 3-Way Floor Standing Speaker...
My JBL subwoofer just buzzes when I turn it on. It doesnt seem to change anything if I plug it into a powerstrip or the wall. It also doesnt seem to matter what setting it is on, all that changes is the...
It is possible that the amplifier within the unit is faulty; The best you can do is to put the woofer ON for about 12 hours so that if there is any chance of any capacitors being faulty or has electrlytic drying.
if this wont solve the unit must be opened to check the amplifier. Possible failure of the input source selector as the woofer is humming.
Oct 27, 2010 | JBL PB12 Subwoofer
JBL PLATINUM SERIES SPEAKERS
It is possible, but you may run into a problem with the amplification to be able to hear the speaker. Without knowing exactly what your setup is the best I can say is to attempt to hook them up to your headphone jack and see how well they work. If you don't hear anything, you need an amplifier. If you hear a distorted sound, but volume is not an issue, use the line out jack and see if it is any better.
Jul 19, 2008 | HP Compaq Computer Speakers
Can i wire 3 jbl gto1204d subs into 1 jl audio 500/1 amp
You can connect them in a series/parallel configuration. Put two of them in series and then connect the last one in parallel across the two in series. This would give you an impeadance of around 2.7 ohms. Only do this if your amp is stable at 3 ohms or less. I am not familiar with the specs of your amp. If your amp is only 4 ohm stable you can not do this.
This would also give you half the power on the two subs in series as the power for the one that is parallel. The two in series would be sharing the total output signal, where-as the one in parallel would get the entire output signal from the amp.
if you were to connect a fourth sub woofer in this configuration it could give you a 4 ohm load, by adding the fourth sub in series with the single sub that is in parallel. or in other words, yu have two sets of 2 sub woofers each in series. That gives you two 8 ohm loads (two 4 ohm subs in series is 8 ohms). Then you take the two sets of subs and parallel them (two 8 ohm loads in parallel equals 4 ohms).
If i had a picture to show you it would make sense, two subs in series that are in parallel with two subs in series.
May 12, 2008 | Jl Audio 500/1 Car Audio Amplifier
JBL SCS145.5 System Logo
314 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
