Question about Maytag MBF2556HEW / MBF2556HEB / MBF2556HEQ Bottom Freezer Refrigerator
I have a lower drawer freezer that keeps frosting behind the upper left corner of the drawer. Is there a fix for this?
  • 232 Answers
Low on refrigerant or dirty condencer or missing rear cover bad condencer fan
Posted on Aug 02, 2009
Frost in freezer
You can switch off the freezer from time to time to let the ice to melt.
Of course the too much accumulation of ice will affect the freezer.
Mar 17, 2012 | Kenmore Elite 78722 78729 Bottom Freezer...
After thanksgiving, and loading the fridge with cooked food, after a couple of days water started accumulating under & in the vege drawers. How to correct?looks like the hing in top center of...
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Dec 10, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
We have an Amana side by side. The freezer door
hi. First of all, finding the model number can be a bit of a challenge. here are the places to look:
  • Inside the refrigerator or freezer, on the upper left or right side wall
  • Behind the lower crisper drawer
  • Behind the lower toe kick-plate
  • On the face frame of the refrigerator body
  • Nov 17, 2009 | Refrigerators
    Freezer drawer jars open at upper right corner when refrig door is closed. Air leaks in and is forming frost on frozen food.
    The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
    Nov 05, 2009 | Pds GE Profile Bottom-Freezer Drawer...
    GE Profile side by side...water collects under the Deli drawer...it's so bad we keep the Deli drawer out and a towel in the space to soak up the water. Any thoughts?
    Oct 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    We have a TFX25JR side-by-side with ice maker and water dispenser; had water leaking on floor on freezer side of bottom left corner. Comes under tray, cleaned the coils and seemed to work, but 2 weeks...
    Oct 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Vibrating noise comming from freezer, freezer not cooling well.
    Check product storage and move any product that may be keeping the freezer door from closing properly. Vibrating noise could be from frost build-up in the area of the fan.
    May 21, 2008 | Samsung Refrigerators
    Water always inside refrigerator sometimes ice forms
    Sounds like you might have a condensation problem. Is the fan in your freezer working? If not it's not circulating the cold air. If it is you might have frost on the lower rear wall of your freezer meaning its not defrosting like it should and restricting your air flow. Last but not least you have a damper door in the upper left corner of your fridge that allows the cold air from your freezer into the fridge to cool it, that might not be opening up. Any one of these things would cause your water problem and a warm fridge section
    Dec 05, 2007 | Kenmore 73262 / 73264 / 73269 Top Freezer...
    Kenmore Elite Trio
    Here are some examples of model numbers for this appliance: 106.8782070, 596.58692890, 119.909851, 119.3101279, 198.887482, 253.835123
    Can you help locate these numbers so I can assist you with the solution?  TKS,Sea Breeze
    Oct 24, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
    Same problem no solution not sure but need help bad fridge is getting warm
    Not cooling at all? or other symtoms that can help us get you going. Can you make sure the refrigerator is listed as Kenmore
    Can you help locate these numbers so I can assist you with the drawing of that door?  TKS,Sea Breeze
    Maytag MBF2556HEW / MBF2556HEB / MBF2556HEQ Bottom Freezer Refrigerator Logo
    181 people viewed this question
    Top Maytag Refrigerators Experts
    Bailey's...
    Bailey's...
    Shehu Pro
    Shehu Pro
    Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
