Question about Gateway M-1628 Notebook
GATEWAY LAPTOP DOES NOT TURN ON
MY GATEWAY LAPTOP WAS WORKING FINE, AND I ACCIDENTALLY PLUGGED IN THE WRONG POWER SUPPLY. NOW THE LAPTOP DOES NOT TURN ON. WHAT CAN I DO? OR SHOULD I BYE A NEW ONE?
  • 1 more comment
  • emilbaez Aug 08, 2009
    nothing at all. with or without battery, even with power connected directly it does nothing. thanks
    ok i try and have a tech look at it. it's kind of hard because i am in afghanistan. thanks.
  • Mark Whitaker May 11, 2010
    it's really not possible to say for sure, but that power connector
    plugs directly into the motherboard. The most expensive part.
    Will it do anything at all when just on battery, or just on the right power supply with the battery removed?
  • 89 Answers
What was the Watts rating on the wrong power supply? Compare it with the watts on the correct adapter.You may have fried your laptop. I would have a tech check it out before you buy a new one. There are many companies available offering a free diagnosis in Fix Ya's repair directory.
Posted on Aug 02, 2009
Gateway computer power light flashes before booting up.
Hmm. I wouldn't have thought it had anything to do with pressing the button. It sounds more like a failing power supply or lack of current for startup. Did you make sure you plugged the power into the video card power connector (if it has one)? I know it worked ok at first but a heavier load can cause older or under-rated power supplies to fail soon after. Just a thought.
Dec 16, 2013 | Gateway GT5662 Desktop PC
Gateway mx6214 will not powerup -bought a new power cord and it still doesn't work. What could be the problem?
It is the plug in the laptop that is most likely the cause, plug the power supply in the laptop. Now put your thumb on the plug at the laptop, as you bend it sideways hit the power button repeatedly to see if it will power up, failing that take the main battery out of the laptop and use power supply only. Please take the main battery out first to see if your power supply will start the computer if the computer starts up change the battery.
Dec 31, 2010 | Gateway MX6214 Notebook
Charger was plugged in and working fine, went into
OK unplug power supply from back of laptop, remove battery, insert power supply, if NO light, on laptop, power supply is broken..Replace. IF it is OK, hold power button ON for a while, or until, the PC starts, if/when it starts, shutdown, with power ON key, and then take out power supply, replace battery, replace power supply, turn laptop on, now should be OK.
Mar 01, 2010 | Toshiba Satellite A70-S249 Notebook
Laptop power flickers on and off
Its probably the connector where the power supply plugs in. Pull out the battery and turn on the laptop with only the AC adapter plugged in. If it doesn't turn on, or doesn't stay on, its the connector.
Jun 29, 2009 | Gateway MT3705 Notebook
Gateway MT6840 Laptop will not power up
have you already tried to power up your laptop without the battery, only with the powersupply docked in?
If this works, you´ll have to replace the battery or use the laptop without a battery.
If this doesn´t work, just take the full battery from the other laptop try to power up the laptop without the power supply docked in.
If this works, your latop motherboard is broken and till it is replaced, you have only the chance to work with a battery and reload it with another latop.
Jun 02, 2009 | Gateway MT6840 Notebook
I dropped my laptop and now the battery will not charge.
Most likely its the DC Power Jack. Happened to me. You can find the part online by searching for "450ROG DC Jack" and then just resolder yourself or take it to a repair shop.
Jan 19, 2009 | Gateway 450ROG Notebook
Dropped my gateway laptop. Now it wont charge battery.
If you do not have either a manufacturer warranty or extended warranty from the retailer use it now. Contact them. Avoid telling them that you dropped the computer...you will void a manufacturer warranty. If you don't have either option then you can continue portability with an external laptop battery. They tend to be heavy, but they tend to provide 5 or more hours of portable use. The extended battery plugs into the same socket as your regular external power supply. I have included some links for product options.
http://www.youtube.com/watch?v=q1om-j6AGNg
http://reviews.cnet.com/1990-3121_7-5127099-1.html
http://www.batterygeek.net/Portable_Power_Stations_s/38.htm
http://www.amazon.com/s/ref=nb_ss_gw_0_13?url=search-alias%3Daps&field-keywords=external+laptop+battery&sprefix=external+lapt
Good luck
Sound Card Broken?
Im sorry to say it sounds like a surge in power is causing this issue. It would be interesting to see if an original power supply solves this issue. In any case I would get this checked by a qualified engineer to determine the exact fault (Use the repairman finder on this site to find one near you.)
Apr 01, 2008 | Gateway 450ROG Notebook
Gateway M-1628 Notebook Logo
341 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
