Question about Apple iMac G5 Desktop
IMac G5 3rd gen disassembly
Hey Mark! I am in a similar predicament... actually my iMac G5 3rd gen iSight died last September (2008) and I'm really pissed! I'm still paying for it (on my credit card bill) and it is just a pretty paperweight! I think I'm getting close to a solution but it requires some hard thinking. There is virtually NO documention for 3rd gen iMacs on the net... I am to the point where I just ordered an SATA dock so I can at least (I hope) recover whatever what was on my HD. That will be a task unto itself; again, there is very little information on the net about disassembly for the "backwards" assembly of the 3rd gen. You will need torx as well as phillips head screwdrivers first of all... The back does not come off... it is disassembled from the front. The face (bezel) has to come off, then the iSight, then the monitor (LCD screen)... then from there, I'm lost. I'm almost a week away from finding the answer. After I get the HD out and do what I have to do, I think it is a matter of replacing the PSU as well.
Will keep you informed. I know this may seem too late (your post being in Jan of this year) but put yourself in my shoes... I've been looking for a solution for almost a year.
eM me if you care to
kennzee_nj@yahoo.com
  • 62 Answers
Well, maybe it helps? This disassembling manual by apple is working. One thing I must to say - I´ve used my wife's plastic cooking knife instead.
Posted on Sep 16, 2009
How do you adjust valves on a 2006 3.5L V6 Toyota Avalon?
There is a Toyota Technical Service Bulletin issued for this:-
T-SB-0291-08 September 11, 2008 2GR-FE Valve Timing
Procedure Service Category Engine/Hybrid System Section Engine Mechanical Market USA Applicability YEAR(S) MODEL(S) ADDITIONAL INFORMATION 2005 - 2009 Avalon 2007 - 2009 Camry VDS(s): BK46K 2008 - 2009 Highlander 2006 - 2009 RAV4 Engine(s): 2GR VDS(s): BK31V, BK32V, BK33V, BK34V, ZK31V, ZK32V, ZK33V, ZK34V, ZK35V 2007 - 2009 Sienna Introduction This service bulletin provides information regarding valve timing inspection and service guidelines for vehicles equipped with 2GR-FE engines. © 2008 Toyota Motor Sales, USA Page 1 of 5 T-SB-0291-08 September 11, 2008 Page 2 of 5 2GR-FE Valve Timing Procedure Introduction (Continued) Figure 1. 3 2 1 5 9 8 7 6 4 1 RH Bank Intake Camshaft Timing Gear 2 RH Bank Exhaust Camshaft Timing Gear 3 RH Bank No. 2 Timing Chain 4 Crankshaft 5 Idler Gear 6 Timing Chain 7 LH Bank No. 2 Timing Chain 8 LH Bank Exhaust Camshaft Timing Gear 9 LH Bank Intake Camshaft Timing Gear Warranty Information OP CODE DESCRIPTION TIME OFP T1 T2 N/A Not Applicable to Warranty © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 3 of 5 2GR-FE Valve Timing Procedure Inspection 1. Set the No. 1 cylinder to TDC/compression. A. Set the timing mark to 0 on the timing chain cover by rotating the crankshaft clockwise. B. Verify the timing marks on the camshaft timing gears are in general alignment with the timing marks of the camshaft bearing cap: TIMING MARK IDENTIFICATION CYLINDER BANK INTAKE GEAR MARK EXHAUST GEAR MARK RH Bank (Bank 1) Small Mark Single Line LH Bank (Bank 2) Large Mark Double Line HINT When the engine is correctly timed, the timing marks will NOT perfectly align. Figure 2. Figure 3. RH Bank Exhaust Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark Figure 4. RH Bank Intake Camshaft Timing Gear 2 1 1 Bearing Cap Timing Mark 2 Gear Timing Mark © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 4 of 5 2GR-FE Valve Timing Procedure Inspection (Continued) Figure 5. LH Bank Intake Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark Figure 6. LH Bank Exhaust Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark HINT If the timing marks appear vastly out of alignment, turn the crankshaft one revolution (360 ) clockwise and note the position of the timing marks. Component Removal Guidelines 1. If engine disassembly is required that involves removing the camshafts or timing gears, set the #1 cylinder to TDC compression, wipe away any oil, and mark the following items in relation to each other prior to disassembly: • Timing gears • Timing chain • Timing chain No. 2 NOTE This relationship MUST be maintained. The intake gear is timed in relation to the crankshaft via the timing chain; the exhaust gear is timed in relation to the intake gear via the No. 2 timing chain. © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 5 of 5 2GR-FE Valve Timing Procedure Component Removal Guidelines (Continued) 2. If NEW camshaft timing gears or the No. 2 timing chain are being installed, the two yellow links on the No. 2 timing chain can be used to ensure correct relationship between the intake timing gear and the exhaust timing gear. Figure 7. 1 1 Yellow Link A. Align the paint mark on the timing chain with the intake gear timing mark (to ensure the intake gear is correctly timed to the crankshaft). Figure 8. RH Bank and LH Bank 3 3 4 3 3 4 5 4 5 4 1 2 1 RH Bank 2 LH Bank 3 Yellow Link 4 Gear Timing Mark 5 Timing Chain Paint Mark B. Align the two yellow links on the No. 2 timing chain to the timing marks on
May 04, 2015 | 2006 Toyota Avalon XLS
Isight lag
1st You download Webcam Driver.
Isight lag
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jan 04, 2013 | Apple iSight Webcam
My G5 tower is no longer recognising my external iSight camera. The only thing that happened was that I switched the G5 off and on again, it was working fine previously. Can you help? Many thanks
Best thing you can do is to determine whether its the port or the camera.
If you go to the Apple in the upper-left corner, and go to "About this Mac", then click "More information", it will start System Profiler. On the left side, under "Hardware", click on "Firewire" and see if your iSight shows up. If you have another FireWire device, plug it in, and see if it shows up there as well. The solution could just be a dead iSight (hopefully!). The worst case scenario is a dead FireWire bus...
If you have a dead iSight, I'd guess that ebay would be your best resource at this point. If its a dead bus, I'm afraid it won't be terribly cost effective to fix it :-/
Jan 06, 2011 | Apple iMac G5 Desktop
I'm trying to find a web cam w/mic that is compatible for an imac m5521
Hi Krystine. If your imac has firewire ports then look on ebay for an Apple iSight Camera.If you haven't got Firewire - and even if you have. it's wqorth looking here http://agent.liquiddigital.com.au/
This is a USB version of the Apple iSight in all but name.
I've seen it working and can vouch for its quality.
Sep 08, 2010 | Apple iMac G3 15" M5521 Desktop
Need manual for imac-5
Hi, try this link, its pdf but has your manul. http://manuals.info.apple.com/en/imacg5-isight-users_guide.pdf
Hope this helps
Jul 11, 2010 | Apple iMac G5 Desktop
Replace damaged screen apple iMac
If You want to make it yourself and You nave iSight model - be prepared to fighting with disassembling, it's not so easy and more - after assembling You can get it non-operate. Best way is a service center. But if You're sure - I can email You disassembling manual. Sincerely.
Sep 14, 2009 | Apple iMac G5 Desktop
Isight intermittent. G5 Imac 17" The Isight cam I have now dubbed 10sec cam turns off and has to be restarted.
I understand from your problem statement that the internal iSight camera in your G5 iMac turns itself off around 10 seconds after you turn it on.
Create a new temporary user in System Preferences / Accounts. Log out and then log in as this user. Enable the camera. Does it still turn off in 10 seconds? If not, something running in your other user account (a startup program or system preference) is interfering with the operation of your camera.
If you have a spare external drive, install a fresh version of the Mac OS on that drive, then boot from that drive. Does the camera still turn off in 10 seconds? If not, you should run an OS installation with "archive and install" on your internal drive. If it does, you have a hardware problem that requires a Mac tech. If this is indeed a G5 iMac, the repair will likely not be cost-effective.
Aug 26, 2009 | Apple Computers & Internet
IMac G5 no isight. Long beep at boot then flashing white light then grey screen and ? in file icon.
hi there,
The question mark usually relates to the computer not finding a system. Usually a bad hardrive. The beep at the beginning can be faulty RAM.
I would suggest taking the computer to your closest authorised apple dealer for them to diagnose further.
Cheers
verb
Aug 01, 2009 | Apple Computers & Internet
IMac G3 Not Starting
Hey, RexKing:
Your problem is hard to diagnose with your current description without knowing where the clicking sound is coming from or exactly what it sounds like, but most likely the problem resides either with the power supply or its connection to the circuit boards. If you have access to any scrapped G3 iMacs to cannibalize for parts at an E-recycling depot, you can probably find just about anything you need, as long as you get the right model, as they changed key components a few times, but, like cars, a lot of parts cross over. The exact model description is on the bottom in really fine print.
In any case, you will have to take it apart to check out the power supply and/or other components, which is a bit tricky without a guide. You can find a really comprehensive Apple iMac G3 service document, for many of the later models, posted at this URL as an 11 Mb PDF file:
http://www.scribd.com/doc/103447/iMac-G3-Disassembly-Guide?autodown=pdf
Only catch is that to download it you need to sign up for a free SCRIBD account. (It's a document sharing co-op site.) Hopefully this won't result in years of spam. Good luck, and if you figure out the cause, please let me know. (I have about a dozen iMac G3s that I am gradually refurbishing.)
Ciao 4 nao
WindGod
May 07, 2009 | Apple 15" iMac G3 400Mhz with 128 RAM,...
Philips ap navigator mk8( marine gps) Recently stopped fixing. All self tests, including antenna result in satisfactory.Could this be due to recent changes to gps satellites? Is there a solution?
I have a similar problem, unit not used since September 2008, now will not find any satellites. Self test all ok.   I know software updates were made available from time to time, last updated in 2004 by previous owner.
Sep 14, 2008 | GPS
Apple iMac G5 Desktop Logo
377 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
