Cannot Find Low pressure port for 1996 Buick Skylark.
This is actually my 2nd question about this problem. I should have given more info in the first one. I can only see one A/C rail that connects to the radiator. There are 2 ports on that same rail that are 3 inches apart. One port is the regular A/C nipple that the the recharge quick connect coupler goes on and the other port has threads and has an electrical plug in it. I am sure that there has to be 2 different pressure rails. One for low and one for high. I have a problem with the port that the quick connect coupler is supposed to attach to. It does not attach, the Port nipple is too large for the coupler. I know that the recharge coupler will not fit on the High pressure port so thats where I am lost. i cannot find any other ports. I followed all the A/C rails form the firewall, compressor and the accumulator and there is no port. I was trying to find the location of the Low pressure port so I know if I have to get an adapter or what. I hope I explained it well enough. Thanks.
  • 4 more comments
  • Rockfish24 Aug 02, 2009
    Its a 1996 Buick Skylark 4CYL
  • Rockfish24 Aug 03, 2009
    I found the Low pressure port. It is right under the compressor which is under the car behind the radiator. I thought they make the car so there was easy access to it but apparently not. Thanks for the help everyone.
  • John Staten May 11, 2010
    What is the make, model and year of the vehicle?
  • 358 Answers
The low pressure port shold be on the bigger pipe that came out from the compresor.
Posted on Aug 02, 2009
What is ets off on a car l have a 1996 Skylark
The actual cause may vary. If I remember correctly a bad oil pressure switch might cause the ets to turn off. Or it might be a defective oil pump. Either way, you will need a qualified technician troubleshoot the cause.
Oct 18, 2014 | 1996 Buick Skylark
Fan works but air not cold
Try recharging your Freon. You can buy a recharge kit at almost any auto part store. Hook it into the low pressure port on the A/C line. On my 3.1L it is best to jack it up and get to in from underneath, metal line in the middle with a blue cap.
Jul 07, 2012 | 1996 Buick Skylark
Where is the low pressure air conditioning service port on a 1998 Buick Skylark?
Locate your AC compressor.
The low pressure service port is located on the back of the compressor where the high and low side connections bolt to the compressor.
Look on this line about 4 inches or so back on the line.
Hope this helps.. Best of Luck
Aug 21, 2011 | 1997 Buick Skylark
Cant find the low side for the air condition on a 1995 buick skylark
FOLLOW AC COMPRESSOR SUCTION SIDE FROM THE ACCUMULATOR CANISTER TO THE SMALL EVAPORATOR LINE GOING INTO FIREWALL LOOK FOR LINE WITH A BLUE PLASTIC CAP.THATS YOUR LOW PRESSURE CHARGE PORT.
Jul 04, 2011 | 1995 Buick Skylark
My 1996 buick skylark V6 3.1 transmission wont work in D OR 3RD but will work in 2nd and 1st after i am moving i can move it in 3 and then D
You need to have the tranny service. If it is a longtime the fluid could be too old to do it's job.
Jul 27, 2010 | 1996 Buick Skylark
Locating the Airconditioning lo service port 1995
There should be a yellow and a red cap. One is for low and one is for high pressure. You can go to autozone.com and register for full free online repair manual.
Sep 23, 2009 | 1995 Buick Skylark
Cant find Low pressure AC port
Did you check the acumulator? There is a port on it, that is the low side port. Keep in mind that if you have to recharge the system it is because other parts need service (leak in the syst) and whatever refrigerant you put in it will leak out again. The system may work temporarily or may work inefficiently. Also may sure that there is oil in syst.
Aug 02, 2009 | 1996 Buick Skylark
Can't find low pressure recharge port for AC 1997 buick skylark
Where is the AC recharge port located on 1995 Buick Skylark
Jul 02, 2009 | 1997 Buick Skylark
Air Conditioning
low side is under the car.
Jun 22, 2008 | 1996 Buick Skylark
Heating & Cooling Logo
121 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
