Question about Dryers
My clothes are getting hung up at the front of my dryer where it turns and they keep getting tore when pulled out. they also have brown greasy looking stuff on them afterwards, what is the problem. thanks
    Problem Solver:
  • 12 Answers
Sounds like the problem is that the teflon drum support shoes are worn out and the drum has dropped creating a gap that the clothes get caught in.
First of all unplug the dryer.
Pull the dryer out from the wall about a foot, pry the top up at the front using wooden shimming wedges, tapping them in lightly or a flat screwdriver with a rag wrapped round it to protect the dryer finish, when the top is released from the spring clips lift the top and hinge it back and rest it against the back wall, remove the two screws at the top corners of the front panel and pull the panel slightly toward you, disconnect the door interlock switch then lift the front panel out of the way, everthing will now be in plain view.
This would be a good time to also replace the drum drive belt.
Posted on Aug 02, 2009
Will have burn marks on clothes sometimes
Are you sure it's burnt marks or could it be from getting hung up between the drum and cabinet and rubbing due to the drum guides failing? Look at the rear and front of the drum to see if the clothes could be getting hung there. Is the dryer making any kind of squealing noise while it is running?
Nov 26, 2011 | Frigidaire FDE336RE Dryer
Makes scraping sound and clothes get hung up in front of drum. What parts need to be replaced?
When clothes get hung up in the space between the drum it means the seal is bad - probably your unit has glides that have worn (rollers make a banging noise)
Glides require removing the front of the dryer and pop riveting in new ones.
Go to searspartsdirect.com and enter your model number found on the dryer door jam (hidden when the door is closed). You can see the construction from the parts diagram
Sep 04, 2011 | Dryers
Clothes getting greasy marks
There is nothing that has grease on it that can leak into the dryer I would do a good inspection in the drum and clean it.
Dec 13, 2009 | GE Dryers
Brown streaks of clothing from dryer
Check your front and rear felt seals. How old is the dryer and what is the model number?
Eric
May 16, 2009 | Whirlpool LER4634J Electric Dryer
Maytag MDE7500AYW Dryer squeals
look in side make sure the drum did not off track. look for the cloth that the drum rides on you might have to push the cloth out. or check the out side of the drum look to see if you have a brown ring around the drum if you do take some sand papper to the mark.
May 05, 2009 | Maytag Dryers
The dryer is leaving what looks like brown burn marks on clothes
you might need to replace the felt on the inside front that the tub rides on
Apr 23, 2009 | Dryers
White clothes come out of dryer with brown lines.
Run a rag along the inside drum seals to see if this is the source of the brown lines. Replace the front and rear drum seals. Part number is 280114.
Mar 06, 2009 | Kenmore 63942 Dryer
Stains from dryer
rear seal on drum needs replacing front 1 too if it has one the felt seals tend to turn brown and the "rust"will come back off on clothes leaving brown streaks
Jun 30, 2008 | Kenmore Dryers
Dryer leaving brown streaks on clothes
the brown streaks and holes will be when they get stuck the dryer is still turning and it will be friction marks if it is getting stuck between the inner and outer drums than check to see if there is any wobble in the inner drum by opening the door and placing your hand at the top of the outer rim of the panel and place your fingers to the top of the inner drum pull your fingers towards your hand if there is any movement than the bearings are gone which will need replacing once done then this will eliminate the problem if there is no movement check to see if there is a seal missing from between the inner and outer drum u can find this out by checking with your fingers than calling the manufacturer to see if there is supposed to be one there
Aug 19, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Dryers Logo
65 people viewed this question
Top Dryers Experts
