Question about Saeco VIA Venezia
Wont brew coffee or steam
I stopped for a while using my espresso machine the via venezia from Starbucks. I can not get it to brew the espresso or for any steam to come out. Could it be plugged somewhere?
  • 80 Answers
Check steam valve sometimes valve make problem or steam wand is plugged
Posted on Aug 02, 2009
Is it worth it to get the machine fixed if the heating element no longer works?
Saeco Via Venezia - YouTube
? 3:10
www.youtube.com/watch?v=8L8vdfMOx2g
Nov 24, 2011 - Uploaded by TheSTiGUi
I dusted off my old Saeco Via Venezia, and wanted t. ... Quick run down of my incomplete modified Saeco Via Venezia Espresso Machine ... a start temperature of ~95deg C (obviously depends on boiler water temperature etc.) ...
Jul 28, 2015 | Saeco VIA Venezia
Doesn't pressurize in order to steam
Can you get hot water and hot coffee from the machine? If yes, then check the thermostats on the boiler, it is possible that the one for the steam could be damaged. Check the schematic below I know its a gaggia model but its close.ac19505.jpg
Aug 12, 2009 | Saeco VIA Venezia
Saeco Via Venezia leaks water from front top overhang.
That is not normal, this tells me that the pump has too much pressure that it is forcing water through the brew unit, or the expansion valve(if your model has one was not set properly). Is there a high pitch noise when the pump is running. If yes then it is the expansion, if no then the springs and the valve pins in the brew valve(small white plastic piece behind the brew unit) needs to be replaced.
May 22, 2009 | Saeco VIA Venezia
Water won't come out like its blocked
Water won't come out when you brew coffee or use the steam wand?
If its when you are using the steam/hot water valve the parnello might be clogged.
If it is when you are using the brew head, then try backwashing the machine with espresso machine cleaner(Purocaff or Cleancaff).
The pump could also be blocked, or the spring in the pump might be damaged, open machine and check pump.
May 15, 2009 | Saeco VIA Venezia
The espresso is a bit watery I have a starbucks via venezia
stop the extraction sooner... if you fill up the double filter basket full, stop it at 2 oz.
Apr 19, 2009 | Saeco VIA Venezia
My Via Venezia steam wand went down into the garbage disposal
go to this like and buy one.... it's called a panarello frothing attachment http://www.seattlecoffeegear.com/Seattle-Coffee-Gear-Panarello-Replacement-Wand-fo-p/scg10002-07.htm
Apr 05, 2009 | Saeco VIA Venezia
Steamer won't work
Can you get hot water from machine, if yes then it is posible that the booster tank for the steam valve is damaged. If no then you need to descale machine.
Mar 24, 2009 | Saeco VIA Venezia
Makeing coffee
No, these machines use a pressurized portafilter to make brewing espresso easier. Be sure your coffee is ground about the fineness of table salt. Just level the coffee in the filter and insert the filter as instructed.
Mar 08, 2009 | Saeco VIA Venezia
Saeco VIA Venezia Logo
173 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
