Question about Vehicle Parts & Accessories
I have a cheetah car alarm with a sensor positioned near steering wheel, the clutch has to be pushed to the floor sensor swiped and ignition turned on for car to start. I am not sure which cheetah alarm this is as it was installed when i purchased car and there is no manual, but it used to beep once when alarmed and twice when disarmed and now it doesnt beep at all. can you tell me how i can make it beep again when turning the alarm on and off. thanks
ltfrc
  • 227 Answers
SOURCE: car alarm stoped working
First check the hood plunger switch. Next look for a valet switch under dash or in glove box. Turn key on and press the switch.
Posted on Jan 19, 2009
SOURCE: spy car alarm manual
Forget the advice on how to steal a car. It's pointless and does nothing to answer your question. I suppose alicantecoli is proud of his abilities (I used to be too, but I don't do that anymore), however he is a fool if he thinks a 2-Way alarm is useless. While it may only take him minutes to disarm the alarm (waaaaay too long), with a 2-Way system & GPS tracking it would only take me seconds to find it again. Or you could use the silent alarm feature, allow the car to be stolen and immobilise it in the middle of the road. Beside all of this, a simple set of relays properly wired to monitor the alarm system power status can turn those few minutes into an hour or two. Anyway, to your question.
The install manual for the (rebranded) Spy 2-Way Car Alarm is a pathetic chinglish translation printed on a single sheet. It would do you no good unless you have some experience with electronics, and a working knowledge of your car's wiring. That being said, here's the wire colours for you:
6-Pin Connector:
Purple : A/C
Brown: On
Yellow: Start
Red: 12v+
Black: 12v-
12-Pin Connector:
Central Locking - it depends on the type as to how you wire it...
Yellow: Nc
Y/Black: No
White: Com
W/Black: Com
Orange: Nc
O/Black: No
Brown: Flash Lights
Brown2: Flash Lights
R/Black: Trunk/boot release
Red: Siren
8-Pin Connector:
Red: Window roll-up
Green: Side-door + trigger
Blue: Side-door - trigger
Yellow: Engine cut-off
White: Acc
Orange: Foot-brake
Purple: Handbrake
Grey: Start-sensing
2-Pin White: LED
2-Pin Black: Temp. Sens.
3-Pin White: Shock Sens.
3-Pin Black: Microwave Sens.
These four plug in in this order: 2PW, 3PB, 2PB, 3PW
Inside the unit (under the sliding cover on the top) there are three jumper settings: Elec/Pneu CL, Lights Flash/No Flash, Auto-arm/No auto. The first of each pair is the default setting.
Hope this helps. That, honestly, should be all you need. If you do need more info, then please DO NOT TRY TO INSTALL THIS ITEM YOURSELF. As it says on the manual, "Install the system by a professional people."
Posted on Feb 18, 2009
  • 91 Answers
SOURCE: Disarm car alarm
first off ill assume the alarm goes off and oviously you have no remote. first disconnect the negative ground (black wire on your battery) so you can work with out the alarm going off.
the "brain" of the alarm should be located on the drivers side underneath the dash, go underneath and look for a small black box zip tied into place with wirescoming into it that looks like it shouldnt be there. it should have crimestoppers inscribbed into it.
there will be wires clipped into the brain, disconnect these and your alarm is deactivated.
to remove, trace wires to where they tie in, cut off wire that leads to brain leaving origonal facory vehicle wire there, and tape over cause you dont want anything to ground out. once you have done this, reconnect the negative, and your good to go
Posted on May 11, 2009
SOURCE: alarm doesnt beep
Turn the ignition on and off 5 times without starting the engine and the alarm will chirp and will be out of "Valet mode"
Posted on Jul 28, 2009
SOURCE: need to disarm the alarm because the remote is not
i have an 02 WRX my alarm keepes going off and i cant start my car and it keeps honking and honkin this viper system cam with the car n there is no button to press my blue button is flashing n my car is honking loud ! help! RPN 473V
Posted on Oct 10, 2009
Key stuck in ignition car stuck in park key won't go to off position
There may be to much pressure on the steering wheel lock for it to go into the off position. put the parking brake on. put the shifter in neutral gently turn the steering wheel in the opposite direction of where the wheels are pointed and try turning the key to the off position. Good Luck
Sep 03, 2016 | Cars & Trucks
Noise of 2004 Volvo s40 2.4i
Cannot figure out what that part is, but it has a vacuum line connected. Therefore, it should not be functioning unless the engine is running. I would have to guess there is a wire crossed in the key cylinder. The presence of the key should activate the warning system and perhaps deactivate the security system. However, the engine system wiring comes in proximity to the warning wiring behind the ignition switch near the contact reel. It's possible you have a short in that area. I am posting access instructions from autozone.com.
CAUTION Models equipped with a Supplemental Restraint System (SRS), use an inflatable air bag. Whenever working near any of the SRS components, such as the impact sensors, the air bag module, steering column, and instrument panel, disable the SRS.
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Disconnect battery cable.
  3. Remove steering wheel and air bag module. Refer to Steering Wheel removal and installation.
  4. Remove steering column covers. Remove or disconnect the following:
    Screws from lower coverClip mounting between the upper and lower coversLower steering column coverUpper steering column cover
  5. Remove the contact reel:
    1. Disconnect the left connector.
    2. Remove the screws.
    3. Remove the contact reel.
      Fig. Removing the contact reel from steering column
  6. Remove the ignition switch:
    1. Disconnect the electrical connector.
    3. Remove the ignition switch.
      Fig. Ignition switch removal
To install:
  1. Install the ignition switch:
    1. Position the ignition switch and tighten the screws.
    2. Connect the electrical connector.
  2. Install the contact reel. Tighten the M5 screws to 44 inch lbs. (5 Nm).
  3. Install the upper and lower steering column covers. Tighten the screws.
  4. Install the air bag and steering wheel. Refer to Steering Wheel removal and installation.
  5. Connect the negative battery cable.
Jul 15, 2017 | 2004 Volvo S40
How do u unlock your steering wheel and ingnition for a 99 sunfire gt
Place ing key in ingtion make sure u r in park or clutch if a stick shift is pushed all the way to the floor, then grab stering wheel tight turn wheel to left and hold while turning ing key, or try turning wheel to right while trying ing key, steering wheel can lock with pressure causing ing key to be non turnable same with transmision, park or clutch to the floor. Hope this helps
Mar 05, 2012 | 1999 Pontiac Sunfire
1995 gmc serria will not start no click from starter, manual trans
replace the starter. Being a manual transmission you should be able to pop the clutch to get it going till you replace the starter. If you don't know how to pop the clutch follow these steps. That way you can still drive the car. When need to.
  1. Get inside the vehicle and depress the clutch to shift the car into "Neutral." Insert the key into the ignition and turn it to the "On" position. This is the place the key would be after a normal turn of the ignition switch for starting. Instead, with a clutch pop, the ignition will already need to be on so that when the engine is turned over, the key is in the On position.
  2. Move the car in position to be pushed from behind or sent down a slope for the starting procedure. Check to see that the brakes will work when pressed and how hard the steering wheel will need to be turned before the vehicle is started. Power steering and brakes will make both systems work poorly until the vehicle is started.
  3. 3 Sitting inside the driver's seat with the clutch depressed, put the shifter into first gear. Keep your foot depressed onto the clutch and the brake pedal without depressing the brake pedal. Roll down the window and signal to your helper to push. As the car rolls, you will steer toward any slope that will assist the helper in getting the car down the street. Allow the momentum of the vehicle to increase to constant motion.
  4. 4 Release the clutch quickly and be prepared to throttle the gas pedal as the engine is turned over by the motion of the vehicle. When in gear, the engine will be forced to crank and the ignition will send a spark for a start. The quicker the vehicle is going before the clutch is released will determine how many times the engine will turn over. More cranks equal more opportunities to ignite the gas and air for combustion and the engine to start without a battery or starter
Dec 06, 2010 | GMC K1500 Cars & Trucks
I have a 1996 Miata where the alarm system goes off no matter what I do to the secuirty switch on the steering column. It can be in the off position or on and open a door and the alarm contiues to go off....
Check wires connections in ALARM WIRING DIAGRAM
Also, its possible that this info helpfull:
- Power Lock - TO DRIVERS DOOR ONLY, See DIAGRAM
- Power Unlock - TO DRIVERS DOOR ONLY, See DIAGRAM
Keepo us updated and send comments.
Oct 17, 2010 | 1996 Mazda MX-5 Miata
My ignition is locked and will not turn. i am trying to replace the ignition but am having trouble figuring out how to remove it. do u have to take the steering wheel off and if so wont that mess up the...
You have to remove the steering wheel with a puller,and the lock plate ,with a lock plate remover tool,and the cancel for the turn signals,and then the turn signal switch,then you remove a screw on the right side about 2 o clock position,and the lock and key will slide out.
Jul 12, 2010 | 1997 Chevrolet Blazer
I can't shift my car from the park position.
mcdevito75 here, When you turn the car off the ignition switch locks the steering wheel, sometimes when you go to start the car it starts but you can"t move the shift lever due to the steering wheel being locked, try this, put the key in the ignition switch, turn the key and at the same time move the steering wheel, if you can move the steering wheel even a 1/2 inch that should free up the shift lever also.
Jun 18, 2010 | 2008 Chevrolet Impala
Steering wheel covers
I hope this helps....these are the steps to removing and replacing the cylinder:
  1. Remove the knee bolster.
  2. Remove the steering column trim covers from the steering column.
  3. Disconnect the steering column electrical connectors.
  4. Remove the wire harness assembly from the steering column and the wire harness strap.
  5. Slide the 2 connectors of the turn signal and multifunction switch assembly out of the bulkhead connector.
  6. Remove the key alarm connector from the lock module assembly in the following way:
  7. Rotate the key alarm connector 90 degrees.
  8. Pull the key alarm connector out of the lock module assembly.
  9. Remove the passkey connector from the lock module assembly.
  10. Remove the connector from the electric park lock, for vehicles equipped with floor shifters.
  11. Remove the ignition switch from the lock module using tool J42759 or equivalent.
To install:
  1. Install the ignition switch to the lock module
  2. Install the key alarm connector into the lock module assembly.
  3. Push the key alarm connector into the lock module assembly.
  4. Rotate the key alarm connector 90 degrees so that the key alarm connector locks into place.
  5. Install the passkey connector into the lock module assembly.
  6. Install the connector to the electric park lock, for vehicles equipped with floor shifters.
  7. Slide the 2 connectors of the turn signal and multifunction switch into the bulkhead connector.
  8. Attach the wire harness assembly to the steering column wire harness strap.
  9. Connect the steering column electrical connectors to the vehicle.
  10. Install the trim covers to the column.
  11. Install the knee bolster.
  12. Enable the SIR system.
  13. It may be necessary to reprogram the theft deterrent system if the module was replaced.
Mar 06, 2010 | 2001 Chevrolet Suburban
Got a 2000 chevy 3500 express van how do i get the old ignition switch out to replace it
remove the steering wheel , need a puller and locking ring tool, disconnect batt, turn the key to tho on position, and remove bolt that holds the tumbler in,
Nov 13, 2009 | 2000 Chevrolet 3500
Auto theft alarm went off, now can't get it to reset. can't start truck or even unlock steering wheel to tow home or to garage. 1998 toyota tacoma
get in truck shut door . . . turn key to acc position. . .push alarm button on dash near ECT button. turn key back off .. . then to the acc position again. . then push button back like it originally was. this should help i had the same problem . only i was in the middle of the woods with no cell phone signal!
Oct 03, 2008 | Toyota Tacoma Cars & Trucks
Vehicle Parts & Accessories Logo
451 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
