Mobile home miller propane gas heater
My heater comes on for 4 seconds,goes off for 2 seconds,comes back on for 4 seconds,goes off for 2 and keeps repeating this. Help!!
  • JUSTMYLUCK Nov 26, 2007
    My heater is a propane gas Miller heater in a mobile home. When the motor fan blower comes on, it only comes on for about 4 then shuts off for about 2 seconds then comes on about every 4 seconds. The fan motor also is making a little more noise to it. Thnaks so much for the help.
  • 63 Answers
Sound like the blower motor is burning out. after it has run for a while, shut off the power to your furnace, then fell the motor. if the motor is really hot(be careful) then its starting to burn out. This is a very common symptom of this.
Posted on Jan 28, 2008
  • 1,420 Answers
Gas or Oil?
Posted on Nov 26, 2007
Kozy world propane wall heater pilot will not light
This can be caused by several things:
1. The inline gas valve running to the the heater is OFF. Turn the valve ON.
2. The gas control knob on the heater is not exactly in the PILOT position. Unless the knob bottoms
out and you feel strong pressure (other than spring pressure) pushing back at you. It's not exactly
in the PILOT Position. Once the pilot lights, hold the control knob in for 30 seconds to 60 seconds
to allow the Thermocouple to full heat.
3. The pilot is dirty and needs to be cleaned, as do the burners.*
4. The LP Gas Tank is empty or to low to maintain te proper gas pressure.
* Here is a link to a demonstration on how to properly clean the pilot & burners.
http://www.desatech.com/techDocs/Cleaning%20Demonstrations.pdf
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
Sep 23, 2011 | The Companion Group Kozy World Portable...
I have a Miller furnace with central air. I am looking to change to a propane gas heater. Looking for cost of Coleman furnace, or can a miller oil furnace be changed to a gas furnace?
Yes it can do but you will be better off by gone to a gas heater. MY own furnace was chance over to propane and didn't workout to good. Less then ayear i have put in a new heater. Ken's Repair
Jan 18, 2011 | Coleman Propane Forced Air Heater...
I have a hayward H400 serise propane heater. I replaced the gas valve. When it goes tot turn on it takes about a minute then starts clicking to ingnite the gas. SSoem time it lights but then goes out other...
0. Check the spark ignitor conection to the board
1. Check the water by-pass valve if you have it
2. Check your gas pressure. (5-7"wc for natural gas, 9-13"wc for propane gas)
3. Clean your filter for your water system or remove it and try again
4. Check the Hi-limits on your heater
5. Replace the thermostat
May 27, 2010 | Hayward H Series Pool & Spa Heater 400k...
My whirlpool water heater that i just installed is not heating up...it is for a mobil home...help
Are you on propane? and did you use a natural gas water heater for a replacement? If you did, it will not hardly have a flame.
You would need to install a propane water heater, which the info that you gave, that is about all I can come up with.
If you can give me some more info, I can help you.
Please rate the new guy :)
And get back to me with an answer to the above and also, what does the current flame look like? Nice blue flame, with 1/4" yellow tips? Total flame should be 3 to 5 inches tall.
Good Luck,
Paul Gibson
Apr 04, 2010 | Water Heaters
What color should the flame be on a coleman
hi the gas goes along aburner tube then comes out of the burner then it hits a baffle in side the heat exchanger as long as there is not sooting the flame will look yellow , i would say the best thing would be to contact the makers of the furnace direct they should have a technical department , they might be able to offer more help or have there own people to look at the heater most of these companys have a warrenty on there heaters
Jan 09, 2010 | Coleman Propane Forced Air Heater...
Heater won't stay lit after releasing yellow button
you need to replace the thermocouple at the burner tip it will be a copper line with a bulb in the flame tip with a copper tube leading back to the gas valve and it senses the flame and keeps the gas valve open
Dec 24, 2009 | All-Pro Propane Garage Shop Heaters - All...
Miller propane furnace .red light flashes 5 times
Look on the wiring diagram for an error code chart. It will give you a starting piont.
Dec 01, 2009 | Polaroid Heating & Cooling
Greenhouse Heater pilot light will not stay lit
replace the thermocouple. it is a small copper tube that screws into the gas valve and goes to the pilot assembly. a good haedware store that sells heaters will have one. they come in various lengths 18"-48".
Nov 30, 2009 | Heating & Cooling
Jandy Lite 2 does not ignite
burners are plug with spider get a wire and bended get it inside the orifices where the gas come out every single one than try now ? magic heater comes on
Jun 17, 2009 | Jandy Lite2 175,000 Btu Propane Gas...
Heating & Cooling Logo
1,051 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
