Question about Yamaha 12V Air Pump
After 1 year of using my 2001 Yamaha XLT 1200 with only 97 hrs, i changed a new sparks plugs and new battery and helped with fluid starter, didn't start. I changed the 1 year old gas by a new gas, didn't start. after i took out the 3 sparks plugs, i saw that the middle spark was a bit wet, and the 2 others were not wet, is that normal, please advise. ps ; i did use almost 1 bottle of fluid starter to help start the engine, it did help to start it for a minute. please advise. Thanks
  • skm1970 Aug 02, 2009
    Thanks for your email.
    If i understand correctly, i do have 2 problems?
    1- the wet sparks plug
    2- the starter relay?
    Or it is a 1 problem together?
    Thanks.
    2001 Yamaha XLT 1200 do not have a carb, it's fuel injected.
    I did change the Plug with a new one, same thing, a bit wet on the head of the plug.
    Where is the Starter located at?
    Thanks for responding.
    President:
  • 2,559 Answers
Your carbs are dirty and so is you fuel filter,have them cleaned inside and out and all the jets cleaned,replace the fuel filter and you'll be good to go.
Posted on Aug 02, 2009
  • Randy Hough
    Randy Hough Aug 03, 2009
    Clean or replace the injectors.The wet plug is from a leaky injector.
    If the starter was bad it wouln't turn over the motor.
    President:
  • 1,129 Answers
Purchase a new plug for the one that is wet I have seen brand new plugs come defective from the factory. I recomend denso whenever possible, also when storing the unit run all gas out and restart until no gas is left this will ensure that no varnish or gum will build up from bad gas. If this doesn't work the carb must be removed, disassembled, cleaned with gumout solvent then blown out with compressed air then reassembled and tried.
  • 1 more comment
  • Mark Babineau Aug 02, 2009
    Sometimes when the engine becomes flooded the starter has a hard time overcoming the higher compression created with a flooded condition, make sure the battery is charged fully and pull out the spark plug then with the throttle at 3/4 or 1/2 turn over the motor for ten seconds this will force out some of the excessive gas. If the starter will not engage while you sit on the mower either the starter relay is bad the seats safety switch faulty or the battery is weak. Either way I would definately replace the spark plug.
    Please disregard the part of the last thread concerning a seat safety switch
    Chances are it is one problem a bad plug.
    President:
  • 1,734 Answers
Wet sparks are definitely a problem. Check the fuses under the front in a round cover, 1 fuse is for the starter,but the cover must be on after checking the fuses. If everything looks good you most probably will need a new starter relay. It is located in the black box on the rear wall of the forward compartment. It is the one with the 2 red starter cables going to it and a brown and black wire coming off of it. Check this.
98 Yamaha 700 vmax xtc snowmobile has spark getting gas new plugs new battery won't start won't pop tors unplugged won't do anything but turn over
Try spraying a little starter fluid into the air intake. If it tries to start, the carburetor needs adjustment or cleaning and rebuilding or replacing. DO NOT USE A LOT OF STARTER FLUID!
Dec 03, 2017 | Yamaha 2007 VK Professional
Yamaha kodiak 450
Your float adjustment is incorrect, asis your fast idle
Jul 02, 2013 | Motorcycles
86 ford f-150 xlt with a 302 5.0 v8 wont start until i put starter fluid into it it will start then dies right away only runs when i pump the gas then dies again i changed the spark plugs and plug wires...
If it runs when you spray starter fluid in you know the ignition system and all related systems are working. On an '86 you have an in-take electric fuel pump. You need to confirm that it runs and that it is supplying adequate fuel pressure in the system.
Jan 30, 2013 | Cars & Trucks
2002 Ford Escape XLT OD light blinking - am told it may be a torque converter cellunoid - only has 80K on it & I bought it new! Any ideas? How expensive is the fix? Would it help to change the...
The Trans fluid should be changed every 30,000 miles or two years.
Changing any fluid on a vehicle is never a fix for anything,just preventative maintenance.
You should have done the Power Steering Fluid, Trans Fluid,Brake Fluid,Etc a couple of times,before getting to 80K.
Also I would hope you changed the spark plugs buy at least 60K.
You may have a TCC Solenoid going bad,but the engages the torque converter clutch.
Is it shifting into OD? Most likely you have a solenoid issue,but need to find out which one. Most fords have a solenoid pack in the trans,with all of them in one unit. Not sure on yours.
The only way it will be expensive, is if you go to a dealer or get pitched some story by a shop, not able to diagnose, what is most likely a simple fix.
Aug 03, 2010 | 2001 Ford Escape
My 2001 yamaha 1100 v-star custom has a hard time starting.
Hi, Ataylor42779 and the usual suspects are:
1. Spark plugs in bad condition or have an improper gap or are partially fouled.
2. Spark plug cables in bad condition.
3. Battery damaged or nearly discharged, should have 12.5 volts.
4. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Throttle controls not adjusted correctly.
6. Water or dirt in the fuel system.
7. Water or dirt in the carburetor.
8. Faulty fuel pump.
9. Intake air leak.
10. Fuel tank vent hose and vapor valve plugged, or fuel line closed off, restricting fuel flow.
11. Enricher valve inoperative.
12. Engine lubricant to heavy (winter operation).
13. Ignition is not functioning properly (possible sensor failure).
14. Faulty ignition coil.
15. Valves sticking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Starting Problem on vstar classic
star 1100 starter problems
Yamaha star 1100 Owner Manual
OEM parts for Yamaha
YAMAHA XVS1100 Owner Manual
Jul 08, 2010 | 2001 Yamaha V Star 1100 Custom
It has not been run for about a year the battery was flat so i charged it but all it does is turn over, it has not started
hello. Put new gas in the tank, a new spark plug, and a new air filter. Then use some starter fluid and put a couple of squirts in the hole before you install the spark plug. It will start, and if it doesn't repeat.
Nov 28, 2009 | 2001 Sym Husky 125
I have a 2002 Yamaha FX140 Waverunner.Fuel problem or electronic?
you have fouled spark plugs change them all fixed all the newq yamaha sare doing it it is the in thing to do
Jun 12, 2009 | Yamaha 12V Air Pump
Yamaha 2001 Raptor 660, sat for a year, wont start, starter is ok, battery is ok, spark is great, but it sounds like starter is not engaging, when it does engage bike just cranks and cranks.
Your gas is bad.  I have to change my all the time If your starter turns but dose not engage the starter barring is out DO NOT BUY STOCK. buy after market when you replace that.  they
Mar 09, 2009 | Yamaha XT 660 X Motorcycles
TROUBLE STARTING BIKE HELP
If the spark plug is not getting a spark then you will need to replace the starting coil! the bike wikk start then !...Is the engine getting fule?
Dec 17, 2008 | 2001 Yamaha YZ 426 F
Yamaha 12V Air Pump Logo
171 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
