Question about Rockford Fosgate RFZ2410 Car Subwoofer
Amps that work with 10" RFZ2410 - Rockford Fosgate RFZ2410 Car Subwoofer
Pretty much any 1000 watt mono-block amp, within the specs of the amps that I have been looking at 4 ohms for one channel it peaks around at 250 watts. So, if you decide to get another RFZ2410 it would still support it. The amps that I have been looking at Acoustic Audio XS1001 and Boss and also most of the newer amps from Rockford Fosgate. The Rockford Fostgate amps are expensive for the 200w mono-block.
Posted on Apr 11, 2013
  • 132 Answers
Well how manny amps can the sub hold? any amp will work you can bridge it to doulbe the power but i would say a 200 wat amp would do you good
Posted on Aug 02, 2009
No dash lights, power locks don't work, fuel gadge doesn't work, radio doesn't work.
all these circuits share some common fuses, check fuse #6 ( 10 amp ), fuse # 11 ( 15 amp ) & fuse #12 ( 10 amp ) all in the inside fuse box at the left end of the dash.....good luck
Jun 20, 2011 | 2000 Mitsubishi Diamante
I don't have a cover for my fuse box and need to
Thanks for the inquiry.
Fuse Numbers and Locations:
EXPLORER FUSE PANEL Fuse Position Rating Circuit Protected 1 10 Amp Power Mirrors/Antenna 2 10 Amp Air Bag/Blower Relay 3 15 Amp Parking Lamps 4 15 Amp Left Headlamp 5 10 Amp On Board Diagnostic II System 6 15 Amp HO2S Sensors 7 10 Amp Illumination Switches 8 15 Amp Right Headlamp/Fog Lamp System 9 10 Amp EATC Mem./Seat Mem./Mess. Ctr./Cell. Phone 10 10 Amp EATC Sys./Rear Blower/Spd. Control/GEM Sys./Brake Interlock/OH Console Adapt. Susp. 11 10 Amp Warning Lamps 12 10 Amp Front and Rear Washers 13 15 Amp PCM Sys./Stoplamps/4WD/
ABS/Spd. Control/Trailer Tow 14 10 Amp Anti-Lock System 15 15 Amp Air Bag System/Alternator 16 30 Amp Front Wiper 17 30 Amp Cigar Lighter 18 15 Amp A/C System 19 25 Amp Ignition Coil/PCM System 20 10 Amp Radio/Power Ant./GEM Sys./Anti-Theft/Cell. Phone 21 15 Amp Hazard Lamps 22 15 Amp Turn Signals 23 15 Amp Rear Wiper System 24 15 Amp Starter Relay/Anti-Theft 25 10 Amp Speedometer/GEM System 26 15 Amp A4LDE Trans/DRL Sys./Backup Lamps/4WD/Rear Defroster 27 15 Amp Under Hood LP/Map Lights/Glove Box Lamp/Dome Lamp/Visor Lamps/Accessory Delay/DR Switch Illum./4x4 System 28 10 Amp Memory Seat/GEM System 29 15 Amp Audio System 30 - Not Used 31 10 Amp Aux. Blower System 32 10 Amp Heated Mirrors/Heated Backlite 33 20 Amp High Beam Lamps 34 10 Amp Audio System/Power Antenna 35 - Not Used 36 - Not Used
Hope this helps helps. Please keep us updated and remember to rate this answer.
Kind regards,
TF
Jun 05, 2011 | 1995 Chevrolet S-10 CA Edition
Schematic to driver side fuse box
Cavity Fuse Description
1) 15 Amp Blue Horn Relay, Power Sunroof
Relay, Power Window Relay
2) 10 Amp Red Rear Fog Lights (Export Only)
3) 20 Amp Yellow Cigar Lighter
4) 10 Amp Red Headlight Low Beam Right
5) 10 Amp Red Headlight Low Beam Left
6) 20 Amp Yellow Body Control Module/Power Door Locks
7 )10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
8) Spare
9) 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/Cluster
10) Spare Cavity Fuse Description
11) 15 Amp Blue Flasher
12) 15 Amp Blue Stop Lights
13) 10 Amp Red Body Control Module/CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight
Mirror/Light Bar Switch (Renegade Only)
14) 10 Amp Red PDC Fuel Pump/AC Clutch,
Starter Relay/Engine
Controller/Transmission
Controller (Diesel Only)
15) Spare
16) 20 Amp Yellow Power Outlet (Rear)
17) 15 Amp Blue Rear Wiper
18) 20 Amp Yellow Radio Choke & Relay
19 20 Amp Yellow
Frt Fog Lights/Trailer Tow
Stop and Turn Lights
20 Spare
21 10 Amp Red Radio
22 20 Amp Yellow
Power Sunroof Relay/
Antenna Module (Export
Only)
23 Spare
24 10 Amp Red PDC Blower Motor
25 10 Amp Red Heated Seat Switches/HVAC
Control Head/Trailer Tow
Battery Charge
26 10 Amp Red Headlight High Beam Right
27 10 Amp Red Headlight High Beam Left
28 Spare
29 10 Amp Red Heated Mirrors/Rear Window
Defroster Indicator
30 15 Amp Blue Heated Seat Module
31 Spare
32 10 Amp Red Wiper Switch/Front and
Rear Wipers
33 10 Amp Red SKIM Module/Data Link
Connector
34 15 Amp Blue Body Control Module/
Cluster/Interior Lights,
Hands Free Module/Radio/
CMTC/ITM Module & Siren
(Export Only)
35 Spare
36 10 Amp Red Airbag Control Module/
Occupation Classification
Module (Right Front Seat)
37 10 Amp Red Airbag Control Module
38 10 Amp Red ABS Controller/Shifter Assembly
39 10 Amp Red Hazard Flasher (Turn
Signals)/Backup Lamp
Switch (Manual Transmission
Only)/Transmission Range
Switch (Automatic Transmis
May 23, 2011 | 2005 Jeep Liberty
Where are the fuses for blinkers
Cavity Fuse Color Description F1 -- -- Spare F2 -- -- Spare F3 10 Amp Red Headlight high beam left F4 15 Amp Lt. Blue Flasher, hazard switch (see Junction Block diagram above for location of turn signal Flasher relay - Mopar p/n 4686094) (Repair tip: WJ flasher repair)
F5 25 Amp Natural Radio amplifier F6 15 Amp Lt. Blue Park lamps F7 10 Amp Red Interior lights F8 15 Amp Lt. Blue Overhead console, rear wiper, IP lights, rear flipper glass solenoid, power locks F9 20 Amp Yellow Power outlets F10 20 Amp Yellow Adjustable pedals (2002-2004 only) F11 10 Amp Red Rear window defrost indicator F12 10 Amp Red Auto shutdown relay / "Fuel" F13 -- -- Spare F14 10 Amp Red Headlight low, left F15 10 Amp Red Headlight low, right F16 10 Amp Red Headlight high, right F17 10 Amp Red Instrument cluster, diagnostic connector F18 30 Amp ? Trailer tow F19 10 Amp Red Anti-lock brakes F20 10 Amp Red Ignition Run / Heated seats / A/C Heater control / Flasher - Left and Right turn signal switch sense F21 10 Amp Red Ignition Run / Start - PDC (Power Distribution Center) F22 10 Amp Red Ignition Run / Start F23 15 Amp Lt. Blue Brake switch F24 15 Amp Lt. Blue Foglamps F25 20 Amp Yellow Accessory delay relay (sunroof) F26 15 Amp Lt. Blue Cigar F27 15 Amp Lt. Blue Rear fog (export) F28 10 Amp Red Body Control Module, Acc/Run F29 10 Amp Red Rear wiper switch. Washer motors F30 15 Amp Lt. Blue Radio F31 10 Amp Red Ignition Start F32 10 Amp Red Ignition Run / Start - Airbag F33 10 Amp Red Ignition Run / Only - Airbag C1 20 Amp Yellow Wiper (Circuit Breaker) C2 20 Amp Yellow Seats (Circuit Breaker) C3 -- -- Spare
I hope this helps :)
May 16, 2011 | 2004 Jeep Grand Cherokee
1993 rodeo not running no power to fuel pump
if there is no power to the fuel pump check relays and fuses....UNDERHOOD FUSE & RELAY PANEL IDENTIFICATION Fig. 2: Underhood Fuse & Relay Panel Identification Courtesy of ISUZU MOTOR CO. Fusible Link Identification ? A - 80 Amp (1991-92 3.1L) ? A - 60 Amp Main-1 ? B - 30 Amp Main-2 ? C - 30 Amp (1993-94) ECM (3.2L) ? D - 30 Amp Condenser Fan (A/T Models) Relay Identification ? 1 - Headlight Relay ? 2 - A/C - Heater Relay ? 3 - Starter Relay ? 4 - A/C Compressor Relay ? 5 - Charge Relay ? 6 - Fuel Pump Relay ? 7 - ECM Relay ? 8 - Wiper Relay Fuse & Circuit Breaker Identification ? 1 - 15 Amp (1991) ECM, Fuel Injection System ? 1 - 15 Amp (1992-94 2.6L) ECM, Fuel Injection System ? 1 - 10 Amp (1992-94 3.1 & 3.2L) Heated Oxygen Sensor, Fuel Injection System ? 2 - 20 Amp (1991-92) Fuel Pump ? 2 - 20 Amp (1993-94 2.6L) Fuel Pump ? 2 - 15 Amp (1993-94 3.2L) Fuel Pump ? 3 - 10 Amp (1991) ? 3 - 15 Amp (1992-94) Turn Signal Lights, Hazard Warning Flasher Lights ? 4 - 10 Amp Horn, Door Locks ? 5 - Not Used (1991 3.1L) ? 5 - 10 Amp Charging System, Charge Warning Light WARNING: Always disconnect battery ground cable before servicing "high- current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician. Page 1 of 2 FUSES & CIRCUIT BREAKERS -1994 Isuzu Rodeo LS? 6 - Not Used (1991) (1992-93 2.6L) ? 6 - 10 Amp (1992-94 3.1L & 3.2L) A/T Interlock System ? 6 - 10 Amp (1994 2.6L) Heated Oxygen Sensor, Fuel Injection System ? 7 - 20 Amp Heater/Air Conditioning Blower Controls ? 8 - 10 Amp Air Conditioner Compressor Controls ? 9 - 10 Amp Right Headlight ? 10 - 10 Amp Left Headlight © 2008 Mitchell Repair Information Co., LLC.
Underhood fuse block swap out relay #7 thats the ECM relay.
Ground Circuits Using a DVOM, touch negative voltmeter lead to a good ground. Touch positive voltmeter lead to each ground terminal. With vehicle running, voltmeter should indicate less than one volt. If reading is greater than one volt, check for open, corrosion and loose connection on ground lead. See ECM GROUND LOCATION table for ECM ground location.
Page 1 of 1 SYSTEM/COMPONENT TESTS - 2.6L EFI -1994 Isuzu Rodeo
Mar 28, 2010 | 1993 Isuzu Rodeo
Diagram of 1996 ford ranger fusebox which fuse is
RANGER FUSE PANEL Fuse Position Rating Circuit Protected 1 7.5 Amp Power Mirror 2 — Not Used 3 15 Amp Parking Lamps 4 10 Amp Left Headlamp 5 10 Amp On Board Diagnostic (OBD) II System 6 7.5 Amp Air Bag System/Blower Relay 7 7.5 Amp Illumination Switches 8 10 Amp Right Headlamp/Fog Lamp System 9 10 Amp ABS System 10 7.5 Amp Speed Control/GEM System/Brake Interlock 11 7.5 Amp Warning Lamps 12 10 Amp Front Washer System 13 15 Amp PCM System/Stoplamps/
4WD/ABS/Speed Control 14 10/20 Amp ABS System 15 7.5 Amp Air Bag System/Alternator 16 30 Amp Front Wiper 17 15 Amp Cigar Lighter 18 15 Amp A/C System 19 25 Amp Ignition Coil/PCM System 20 7.5 Amp Radio/GEM System/Anti-Theft 21 15 Amp Hazard Lamps 22 10 Amp Turn Signals 23 — Not Used 24 10 Amp Starter Relay/Anti-Theft 25 7.5 Amp Speedometer/GEM System 26 10 Amp 4R44E/4R55E Trans./Backup Lamps/DRL System 27 10 Amp Underhood LP/Map Lights/Glove Box Lamp/Dome Lamp/Visor Lamps/4x4 Sys. 28 7.5 Amp GEM System 29 10 Amp Audio System 30 — Not Used 31 — Not Used 32 — Not Used 33 15 Amp High Beam Lamps 34 — Not Used 6d47eae.gif
Nov 01, 2009 | 1996 Ford Ranger SuperCab
Nissan maxima 1996
moz-screenshot.png#1-10 amp
SRS (Aribag)
#2-15 Amp
Air conditioner
#3-15 Amp
Air Conditioner
#4-7.5 Amp
A/T TP/Sw
#5-Tail LIght, Turn Signal Switch
#6-15 Amp
Horn
#7-10 Amp
Power Mirror, Mirror Heaters
#8-10 Amp
#9-10 Amp
#10-15 Amp
Power Windows
#11-10 Amp
Turn Signal
#12-7.5 Amp
Power Windo, Door Locks, Sunroof, Time control unit
#13-10 Amp
Meter, ABS, ASCD, Back-up Lights, Air bag, Warning Chime
#14-7.5 Amp
Corner, Turn
#15-10 Amp
ABS
#16-7.5 Amp
#17-10 Amp
A/C, Fuel Pump, Canister, EGR, Cooling Fan, ASCD
#18-7.5 Amp
Illumination
#19-7.5 Amp
Wiper Motor
#20-20 Amp
Wiper washer timer
#21-10 Amp
Horn, Audio, Power Antenna
#22-15 Amp
Audio
#23-10 Amp
#24-10 Amp
#25-15 Amp
#26-7.5 Amp
Step/L, Room
#27-10 Amp
#28-7.5 Amp
#29-7.5 Amp
Heated Seats
#30-20 Amp
A/C
#31-10 Amp
#32-15 Amp
Fuel Pump
#33-10 Amp
Theft Warning System
#34-10 Amp
Fuel, RO2H
#35-15 Amp
#36-7.5 Amp
#37-10 Amp
TLID, MULTI
#38-7.5 Amp
Rear Defogger
#39-7.5 Amp
Rear Defogger
#40-20 Amp
Door Lock, Horn, Multi, SRS, Power Antenna, Timer
Aug 01, 2009 | 1996 Nissan Maxima
Need fuse box pannel to see what fuse is what
FUSE USAGE
1. 10 AMP LOW BEAM-LEFT
2. 10 AMP LOW BEAM-RIGHT
3. 30 AMP BRKR POWER WDO/SUNROOF
4. 30 AMP BRKR PWR ACSRY
5. 20 AMP BRKR LIGHNG CONTROL MODULE
6. 15 AMP IGN/REM ACSRY CONT/INST CSTR
7. 10 AMP SUPPLEMENTAL INFLATABLE RST
8. 20 AMP CORNERING LPS/TURN SIG
9. 10 AMP CRANK SIGNAL-SIR
10. 20 AMP TRK REL/FUEL FILL REL/BACK-UP LPS
11. 15 AMP BAT/RADIO/PWR ANT/CIG LGTR/ INST CSTR
12. 20 AMP ELECTRONIC LEVEL CONTROL
13. 20 AMP BRAKE & HAZARD LAMPS
14. 15 AMP PARK LAMPS
15. 15 AMP COURTESY LPS/PWR MIRRORS
16. 10 AMP COOLING FAN
17. 25 AMP HEATING/AIR CONDITIONING (C67)
18. 15 AMP A/C AUTOMATIC ELECTRONIC (CJ2)
19. 10 AMP ANTILOCK BRAKES
20. 10 AMP LOW COOLANT/LAMP MONITOR
21. 10 AMP IP LIGHTS
22. 10 AMP HI BEAM-RIGHT
23. 10 AMP HI BEAM-LEFT
24 10 AMP IGNITION/RADIO
25 25 AMP WIPER/WASHER
FOR ACCESS TO ADDITIONAL FUSES
REMOVE RIHT SOUND INSULATOR
May 16, 2009 | 1991 Buick Park Avenue
Electrical problem after battery replacement.
Below is a listing of which fuse corresponds with which circuit:
1 - 10 Amp - Transmission Controller, Gauges, Autostick
2 - 10 Amp - Right High Beam Headlight
3 - 10 Amp - Left High Beam Headlight
4 - 10 Amp - Radio, CD Player
5 - 10 Amp - Washer Motor
6 - 15 Amp - Power Outlet
7 - 20 Amp - Tail, License, Parking, Illumination Lights, Instrument Cluster
8 - 10 Amp - Airbag
9 - 10 Amp - Turn Signal Lights, Turn Signal/Hazard Indicator
10 - 15 Amp - Right Low Beam
11 - 20 Amp - High Beam Relay, High Beam Indicator, High Beam Switch
12 - 15 Amp - Left Low Beam Headlight
13 - 10 Amp - Fuel Pump Relay, Power Train Control Module
14 - 10 Amp - Cluster, Day/Night Mirror,Sunroof, Overhead Console, Garage Door Opener, Body Control Module
15 - 10 Amp - Daytime Running Light Module (Canada)
16 - 20 Amp - Fog Light Indicator
17 - 10 Amp - ABS Control, Back Up Lights, Daytime Running Lights, A/C Heater Control Cavity Fuse Circuits
18 - 20 Amp - Power Amplifier, Horn
19 - 15 Amp - Overhead Console, Garage Door Opener, Trunk, Overhead, Rear Reading, and Visor Vanity Lights, Trunk Release Solenoid, Power Mirrors, Power Door Locks, Body Control Module, Aspirator Motor
20 - 20 Amp - Brake Lights
21 - 10 Amp - Leak Detection Pump, Low Rad Relay, High Rad Relay, A/C Clutch Relay
22 - 10 Amp - Airbag
23 - 30 Amp - Blower Motor, ATC Power Module
24 - 20 Amp - Power Window Motors
25 - 20 Amp - Power Door Lock Motors, Power Seats
Apr 04, 2009 | 2002 Dodge Intrepid
Jetta electrical problems
hi, i recently bought a used 2001 jetta and had the same problem...auto locks, sunroof, windows, interior lights, trunk switch on door all stopped working all of a sudden. replaced fuse #14 and everything works like magic again...
I found this fuse diagram A LIFE SAVER!!!
-----------------[ S8 ][S 12][S 16][S 20]
-----------[ S5 ][ S9 ][S 13][S 17][S 21]
[ S1 ][ S3 ][ S6 ][S 10][S 14][S 18][S 22]
[ S2 ][ S4 ][ S7 ][S 11][S 15][S 19][S 23]
[ S 24 ] [ S 31 ] [ S 38 ] -- -- --
[ S 25 ] [ S 32 ] [ S 39 ] R R R
[ S 26 ] [ S 33 ] [ S 40 ] S S S
[ S 27 ] [ S 34 ] [ S 41 ] -- -- --
[ S 28 ] [ S 35 ] [ S 42 ] R R
[ S 29 ] [ S 36 ] [ S 43 ] S S
[ S 30 ] [ S 37 ] [ S 44 ] -- --
S1=10 AMP=Heated washer nozzles, glove compartment light, memory seat...
S2=10 AMP=Turn Signal System
S3=5 AMP=Fog Light Relay, Instrument Panel Dimmer Switch
S4=5 AMP=License Plate Lamps
S5=7.5 AMP=Comfort System, Cruise Control, Climatronic, A/C, Heated Seat Control Modules, Day/Night Dimming Mirror, Control Module and Control Unit for Multifunction Steering Wheel.
S6=5 AMP=Central Locking System
S7=10 AMP=Back-up Lights, Speedometer Vehicle Speed Sensor.
S8=OPEN
S9=5 AMP=Anti-Lock Brakes.
S10=10 AMP for GAS/5 AMPS for Diesel=ECM
S11=5 AMP=Instrument Cluster
S12=7.5 AMP=B+ (battery positive for data-link connector) (DLC).
S13=10 AMP=Brake Lights
S14=10 AMP=Interior Lights, Central Locking System
S15=5 AMP=Instrument Cluster, Automatic Transmission Control Module (TCM).
S16=10 AMP=A/C Clutch, After Run Coolant Pump.
S17=Open
S18=10 AMP=High Beam Right
S19=10 AMP=High Beam Left
S20=15 AMP=Low Beam Right
S21=15 AMP=Low Beam Left
S22=5 AMP=Parking and Side Marker Lights, Right
S23=5 AMP=Parking and Side Marker Lights, Left
S24=20 AMP=Front Wiper Motor, Washer Pump
S25=25 AMP=Fresh Air Blower, Climatronic, A/C
S26=25 AMP=Rear Window Defogger
S27=15 AMP=Rear Wiper Motor
S28=15 AMP=Fuel Pump, Gas Engine Only
S29=15 AMP Gas/10 AMPS Diesel=ECM
S30=20 AMP=Sunroof Control Module
S31=20 AMP=Automatic Transmission Control Module
S32=10 AMP Gas for Fuel Injectors/15 AMP Diesel for ECM
S33=20 AMP=Headlight Washer System
S34=10 AMP=Engine Control Elements
S35=30 AMP=12 VDC Outlet in Trunk
S36=15 AMP=Fog Lights
S37=10 AMP=Radio Terminal 86S, Instrument Cluster
S38=15 AMP=Central Locking System (w/ Power Windows), Luggage Compartment Light, Remote Fuel Tank Door, Rear Lid Unlock.
S39=15 AMP=Emergency Flashers
S40=20 AMP=Dual Tone Horn
S41=15 AMP=Cigarette Lighter
S42=25 AMP=Radio System
S43=10 AMP=Engine Control Elements
S44=15 AMP=Heated Seats
hope this helps ; )
Sep 14, 2008 | 2001 Volkswagen Jetta TDI
Rockford Fosgate RFZ2410 Car Subwoofer Logo
Top Rockford Fosgate Car Audio & Video Experts
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
