I bought this washing machine used. I think a repairman was working on it and put the wash selctor switch in backwards or something of that nature. I can't tell where I'm at in the cycles. Any ideas?
  • Washing Mach... Master
  • 1,525 Answers
Hello there should be a bit of a guararntee with the machine like 3 month. get the guy back out .good luck
shaun
Posted on Aug 02, 2009
Lid light is flashing, machine will fill with water but does not wash
lid light flashing would give me the idea that something is wrong with the lid switch .and If I can not find and fix that then I call a repairman
Oct 14, 2015 | Admiral ATW4475XQ
Washing machine will not start, only get two red flashing lights, what could be the problem ?
Sounds like something toasted on the control panel
Better call certified appliance repairman
Oct 08, 2014 | Russell Hobbs RH1042 Frontload Washing...
Hoover elite 700 washing machine won't spin
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
# A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
# 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
# 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
# 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
# 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
Regards.
Jan 05, 2012 | Hoover Washing Machines
Whirlpool awm 6145/3 washing machine. Door shuts cycle starts but within about 5 seconds it stops and door open light comes on.
your door safety switch may be to blame,, if its faulty the machine gets a notice that something is wrong and stops,, to check that try this link http://www.partselect.com/Virtual-Repairman.htm
May 31, 2011 | Washing Machines
My samsung top loader 7.2kg washing machine works but does not spin
There are several reasons why a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
Find some possible cause and how to solve the problem:
If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Good luck.
Mar 31, 2011 | Washing Machines
Washer which is kenmore 80 series and about 6 years old just stopped working while filled with water. after 3 hours we finally got it to start again and then I stopped it cause it was filling up with...
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • thanks
    Oct 03, 2010 | Kenmore Washing Machines
    Haier washer/dryer combo not drying clothes
    Check things like the Filter / clear fluff...Make sure outlet hose if any is not kinked and passing air..Hope this helps..
    Oct 02, 2009 | Haier 14.3 lb. Washer/Dryer Combo
    Whirlpool lsr8233jq0 Was washing fine this morning and now does not do anything, on any cycle. Do not think it is lid interlock. Circuit is ok and power is to the wall. It was getting ready to drain and...
    I called a repairman. Problem was a broken wire going to the motor. This machine has a timer and you guy insisted that it had a control board. I almost bought a timer for $100, but cancelled and called a repairman. As it turned out, I paid $139 in total and didn't have to do the work. I will call this repairman from now on.
    I gave it a shot, but having worked on these things for 25+ years, I just don't see how you can do that on the phone from a remote location. I wasted $9.95, but it was my decision to spend it. I won't again.
    Thanks!
    Mike
    Feb 27, 2009 | Washing Machines
    Top Loading whirlpool washing machine.
    Could be the top lid switch. If the timer has stopped moving (you can no longer hear it clicking along) good chance that's what it is. When it has stopped try pushing hard down on the top of the lid AND/OR put a piece of plastic (or something ) into the lid latch switch... See if it continues on with the wash cycle...
    Mine just went bad this week. Bought the part for $25...
    Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    20 year old washing machine leaks
    the tank is hooked to the pump and the pump to the drain hose, by flexible rubber couplings.
    Try those couplings to see if they have deteriorated, they are cheaper to replace than to buy a new washer ort get a service man
    Jul 27, 2008 | Washing Machines
    Washing Machines Logo
    13 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
