I do not get complete picture ie picture continually breaks up (pixilates) as does sound, even sometimes no signal but only for a short time.
  • 49 Answers
If it only happens while watching an incoming signal from the cable company and not a DVD playing,
I went through this too on a rear projection HD TV.
If you have any splitters on the line to the TV eliminate as many branches to other devices as possible. They cause a drop in signal strength which is the problem. Make sure the cable is RG6 others are too weak to carry a good signal.
After going through many splitters and taking other things off I got a better signal. But it came down to the cable companys box out by the street had corroded metal components and when they changed that, the problem cleared and was even able to add all devises back to my signal splitter.
If is happening on a satellite dish then check and clean or replace cable connectors.
Posted on Aug 02, 2009
Picture and sound break up, freeze, pixilate and then resume. Doing it more often.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 12, 2015 | Samsung Televison & Video
How is it myTV picture is interrupted by occasional pixilation break-ups with or without electrical switches being turned on/off,also, possibly an i-pad affects it as well. Sometimes half the screen is...
Main board fault / input signal weak. Contact any service technician to troubleshoot.
If the fault is with the main digital board, it should be replaced with a new one.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 11, 2014 | Panasonic Televison & Video
Ihave Bushldc 26" T.V. and
The most common cause of that is signal break up causing firstly "blocking" of the picture and audio drop out. Heavy clouds can also cause signal deteriation as does heavy rain.
Hope that helps.
Jan 18, 2011 | Televison & Video
My new television keeps saying no signal or the picture breaks up sometimes its fine all other t.vs in house ok but this one is in new extension
No signal or weak signal would indicate that there is a problem with the continuity of the coak antenna cable.
Most times in mu8lti installations there is a splitter somewhere that couples all the Tv's to the antenna. Check this connection as it is often the source of many NO SIGNAL problems
Please rate my help++++Thanks for using FIXYA
May 24, 2010 | Televison & Video
My digital tv keeps freezing it is an Alba TV and we live in bournemouth and it says we don't have coverage at the moment but we get all the chnnels its just every now aqnd again the picture jutters and...
Because you are receiving digital transmissions, if the signal is too weak your picture will break up and pixilate. In the days of analougue you would just get a snowy picture. If you are getting the channels, you might want to consider investing in a booster and a digital antenna. Install the booster as near to the antenna as possible to get the best out of it.
Jan 23, 2010 | Televison & Video
Picture on all 4 TV's in house randomly pixilate/freeze.
you have a low signal problem or if you have rj 59 in your home you need rg6 for at and t signal
Aug 27, 2009 | Vizio L37 Television
Just getting fuzz, no picture or sound
check that the coax cable is complete and has no internal breaks. get a new piece and even paring both ends to wire you should get pic and sound even if its not clear. then attach new plugs and connect. Also check that the outside cable is still connected. If iit goes up into the roof check mice or rats have not chewed the cable.
Even a rabbits ears antenna should be able to oick up some signal even in a poor reception area.
Sometimes if it snot an antenna problem select rescan on the remote to check for signals
Aug 14, 2009 | Samsung CXJ1964 19 in. TV/VCR Combo
High pitch screech w/no signal
is this a picture tube type of tv? big in back? If so, it could be the tube/circuit short.
If it flatpanel, it could be a bad capacitor in the DM or "Y" board or even possibly faulty power supply. Further testing will be necessary
Jul 22, 2009 | Polaroid FLM-3732 Television
Turn indicator sound (ticking) continues after signal is cancelled. replaced flasher and sound continues.
Remove the signal lever (switch) clean the grease completely and lube again with di-electric grease.
This should solve your problem.
May 20, 2009 | 2004 Pontiac Grand Am
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
