SOURCE: Craftsman 19.5 riding mower starts runs quits no power
When you let it sit did you remove all the fuel or add a additive? If you did not then I would recommend that you remove all the fuel and add brand new fuel to your system. Gasoline only last for about 3 to 4 months before it will start to go bad and this sounds like your problem
put a volt meter on the battery then start it and check the voltage before and after if it is not more running it's not working if it is not charging remove the top cover from the engine and see if mice chewed the wires
