Question about Refrigerators
Freezer with ice buildup and refrigerator not staying cold
Hello, I have a GE Profile model number tcx18pacbrww (freezer on bottom) which is having some issues. The freezer gets ice buildup on the bottom that starts to melt a little and leak out the door onto the floor. Now the refrigerator is not staying as cold as it should. This same problem occurred last year and the repair person replaced the fan. This solved the issue for a while but the same thing appears to be happening again. Would it possibly help to remove all the food from the fridge and freezer, unplug it and let it completely defrost for a day before plugging it back in? Anything else we can try?
    Problem Solver:
  • 12 Answers
If you unplug for a couple of days it will just happen again.
I sounds to me that either the defrost heater has burned out or the defrost timer has quit, locate the timer and see if you can advance it to defrost manually.
The defrost timer is quite easy to replace but the heater requires a lot more skill
Posted on Aug 02, 2009
Tdc18paaaww leaking ice buildup
Is this auto-defrost model? Usually, heating element that defrosts the ice in back of freezer can go bad. How old is the model?
Dec 29, 2013 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
I have a GE Profile freezer on the bottom refrigerator model #PDS18SBMARBS. A fan was runnining on the inside of the fridge seemed to be between the fridge and freezer. It was very loud and now does not...
Could be a bad fan motor. A bad defrost part or a bad control board.
Check for ice buildup on the back wall of the freezer. If so you have bad defrost parts or a bad control board.
Enter your model number at www.appliancepartspros.com to find the exploded view to dis-assemble the freezer. You can also order parts from them.
Aug 20, 2011 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
Jul 11, 2011 | GE Refrigerators
Freezer works fine, but fridge isn't keeping as cold as it once was
Look inside rear of freezer and if you see frost buildup the problem is most likely the defrost heater. Your model number will not pull up so something is not correct in the number. Check out the model locator=> Side-By-Side
  • Top Freezer
  • Bottom Freezer
  • If you still would like to ask questions you may here on Fixya or HERE, I would rather leave you the correct parts once you find your model number. It is just I know if it is a Profile the defrost heater and defrost thermostats are the main reason for what is happening, Thanks, Sea Breeze
  • Feb 10, 2011 | GE Profile PCF25PGT Side by Side...
    Water on the floor, ice buildup in the freezer
    Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
    Refrigerator not Cooling or Fridge not Cooling
    How to Defrost Refrigerator Defrost Timer Problem
    Water Running in refrigerator from Freezer
    Refrigerator or Freezer not Cooling or Getting Cold
    heatman101
    Oct 23, 2010 | GE Profile PDS22MHR Bottom Freezer...
    Icemaker leaking
    Check two things.
    1: see if you have ice buildup in the water inlet tube above ice maker, if you do chance are the water valve is bad, if not,
    2: see if you have icicles hanging from bottom of ice maker, if you do you have a bad ice maker.
    Either way, will need full model number and serial number both to get you the right part numbers for parts.
    Oct 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
    GE fridge is warm and broken; the freezer is cold though.
    Air circulation problem. Evaporator fan in freezer moves some air to refrig. Either fan is not working or air passages are blocked with ice. If ice found, then a defrost component failure has occurred. Fix what you find.
    Sep 19, 2009 | GE Profile PDS20MFS Bottom Freezer...
    Fridge wont stay cold in the bottom.
    Your frost free is not defrosting properly. There should be no ice buildup in the freezer section. Frost in the freezer section stops air circulation to the refrigerator section.
    Jun 28, 2008 | GE Refrigerators
    Refrigerators Logo
    459 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
