Question about Brother MFC-8860DN Printer
It say " no tray " >>> whats up ?? - Brother MFC-8860DN Printer
    President:
  • 2,306 Answers
That error means you need a new engine board, the board itself is over $300.00 and you need to have a diagnostic program to program after installation.
Posted on Sep 10, 2009
HP LASERJET 3015X wont print from top drawer
Most common issue here is that either the switch that tells the tray is installed is broken or the shaft that turns the pickup wheel has broken. Pull out tray and try turning the rubber wheel in the center top of the cavity. If it turns freely then the shaft has broken.
Aug 25, 2016 | HP Office Equipment & Supplies
I can't get it to print from the top tray
Make sure that Tray 1 is checked under installed options. To check it, go to Printers & Faxes, right click on the Lexmark icon > Properties > Configuration or Options > Make sure that Tray 1 is checked.
Also, when you click on File > Print, go to Preferences or Properties and make sure that the source is Tray 1.
Oct 22, 2012 | Lexmark T652DN MONO LASER PRINTER...
I have a HP 4000n printer and want it to print from tray 3 when tray 2 is empty. It doesn't do that now.
I don't have a 4000n, but I do have a 4200n that should be relatively similar. On the 4200n you can change this behavior by going to the menu, then Configure Device->System Setup->Tray Behavior->Use Requested Tray, then setting that value to First. My guess is you have that setting on your 4000n set to Exclusively, which will then prevent the job from going to a different tray. It also requires that you have the same type and size of paper registered in both trays if you want the job to automatically switch over.
If that menu path is different on your 4000n you just need to dig around in that menu to find the tray behavior setting.
Jun 09, 2011 | HP LaserJet 4000n Printer
What is a mp tray
MP tray: Manual Paper tray
Where: go into printer properties-> Paper Source
change from Auto to MP tray, you will see where it is.
Gudluk
Jun 07, 2010 | Brother MFC8890DW AllInOne Laser Printer
XP Home W/ No Network System Tray Icon
Go to Control Panel >> Network Connection >> Right Click - Properties >> there's 2 check box, and check for " Show icon in notification area when connected.
Dec 29, 2009 | Sony VAIO Notebook
Problems with bypass tray taking too many peice of paper then jamming
The tray is overfilled > Remove excess media from the tray.
The paper exceeds the maximum stack-height indicator mark in the tray (trays 2 or 3) > Open the tray and verify that the media stack is below the maximum stack-height mark.
The paper is sticking together > Remove the media, flex it, rotate it 180 degrees, or flip it over, and then reload it into the tray.
NOTE: Do not fan paper. Fanning can create static
electricity, which can cause paper to stick together.
Dec 08, 2009 | HP LaserJet CP3505n Printer
Hp 4250 manuall feed heavy paper message
You'll have to set up the paper settings within the copier to reflect heavy paper for the bypass tray. You'll need to make this a default setting. Then when you print out with heavy paper via the print drivers it should pick up automatically at the printer.
Aug 28, 2009 | HP LaserJet 4250n Printer
Tray 2 Printing
Couple of things for you to check out.
1. Is that you've enabled the second tray for the printer. This is normally automatic but to check go to:
START > Printers > L7780 > Properties
- Click the "Device Settings" tab
... then sort out the different setting so they are all correct such as paper size and of course "Tray 2: Installed"
2. The other more common issue is simply that the printer isn't sitting properly on top of Tray 2 and as a result it's not engaging the cog wheel properly to pick up paper.
This is one of those trial and error things where you pick up the printer and re-slot it down onto Tray 2 until it works properly.
Hope that helps...
May 12, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Need master reset code for vdo dayton sat nav
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Apr 17, 2009 | VDO Dayton MS5000 GPS Receiver
Brother MFC-8860DN Printer Logo
66 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
