Question about Haier Heating & Cooling
Fan is working , bur mo cold air
Fan is working , but no cold air
    Novelist:
  • 166 Answers
If your house is not getting cold enough when your A/C is turned on, It is time for a good cleaning. There are a variety of factors that may cause your A/C to not cool your house. With that said, here is a diagnostic article that provides the most probable causes of your A/C's failure to cool your house, and from there you can read it and then, step by step, rule out each possible cause listed in the article:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Does_Not_Cool.htm
Of course, a low level of Freon/refrigerant may be the problem, but there may be other problem causes as well, as noted in the article---it may just be that debris is obstructing your AC as well. Read the article, and, actually, your best bet may be to take advantage--towards the END of the above-linked article--of the text-link for Free four (4) quotes from local AC contractors in your area, and "pick the brain"--seek the advice--of these local technicians who offer you a free quote to discern what could be the problem. Also, since you may need a Freon/refrigerant recharge, you'll ultimately need this AC contractor to do it for you, since federal law prohibits the selling of Freon/refrigerant to anyone other than licensed AC contractors/technicians.
Posted on Aug 09, 2009
It is silent over night bur as soon as the door is opened in the morning the motor kicks in and it starts buzzing. this goes on all day.
NOT SURE THIS IS UR PROBLEM BUT THOUGHT ID SEND IT
Fridge FAN CONTINUALLY STAYS ON OR SHUTS OFF WHEN DOOR IS OPENED:
NORMALLY WHEN THIS HAPPENS U EITHER HAVE A DOOR CONTINUALLY OPEN ISSUE OR A BAD DOOR SEAL LETTING AIR IN AND CAUSING FAN TO OVERWORK ITSELF. ANOTHER CAUSE CAN BE DIRTY COILS AND CONDENSER AND LASTLY NOT TO COMMON IS A SHORT IN THE FAN SYSTEM ITSELF. A MORE PROBABLE CAUSE COULD BE BAD THERMISTORS OR EVEN COLD CONTROL THERMOSTAT ( WHEN THE THERMISTORS OR THERMOSTAT DO NOT GET/GIVE A PROPER READING, THEY CAN CAUSE THE FAN TO CONTINUE TO OPERATE AS THEY FAIL TO RECOGNIZE OR REGULATE THE PROPER TEMPERATURE
Apr 09, 2015 | Refrigerators
Should the fan operate all the time in my refrigerator
Most of the time it runs only when the compressor is running. In other words compressor and fans will run together when the fridge thermostat ask for cold and stops together when thermostat is satisfied. In newer fridges some time inside fan (evaporator fan) might PERIODICALLY run without compressor to circulate little cool air to fridge compartment from freezer compartment.
Sep 30, 2014 | Whirlpool Refrigerators
PTAC unit fans working but not circulating cold air
switch off the unit, manually open the vents and check how dirty the fan blades are. Clean if required. if clean check gas level ,the fan speed is deturminded by the gas
Jul 14, 2013 | Heating & Cooling
Refrigerator side warm bur appears freezer still
the freezer feeds cold air to the fridge side,there's an evaperator fan that just blows the cold air from the freezer to the refrigerator side and then it returns to the freezer through the air ducts.check this,when you open the freezer door do you hear the fan blowing in there?if you don't you have a bad evap fan motor,if you hear it,remove the second draw from the bottom in the freezer side and touch the back wall,if there's ice or like snow on the back wall you have a defrost problem.if this is it send me the model number and i can look up the parts in your machine and i can help you,also look to see if there's droplets and ice on the food and shelves in the freezer,somebody could have left the door open and the air ducts frooze up and the air can't blow from one side to the other,let me know what you find and i'll help you out
Jul 16, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Air cinditioning blowing from cold to hot air
need to check ac fan or fans ,are they working? if not check fuses and fan relays,,,,,and fans (hot wire the fan to see if it/they work
Jul 05, 2009 | 2000 Acura TL
Fan running slow
you sound like you have it
May 27, 2009 | Dometic Rooftop RV Air Conditioner
Cant get the tension rite on m sergery juki mo-3614
always remember to keep the tension the same and try to fix all other things Try to clean the machine I use canned air it is the best thing going. then check the needle is it bent or is the end burred well replace it any way. and each fix try the machine. only change the tension as a last resort and always note the positions and put back to that and if you take the machine in to be fixed leave the bunched up fabric and thread as it is this will give the repair person something to look at.
Feb 25, 2009 | Juki MO-644D Mechanical Sewing Machine
Fridge not cold
HI thanks for your question. check to see if the fan motor is running in the freezer. that could be the problem. thanks the appliance doc. please rate my answer. thanks
Oct 08, 2008 | Frigidaire FRT18B4A Top Freezer...
Fridge freezer
  • Check the temperature setting
  • Assure that there is enough room for air flow in the refrigerator or freezer
  • Check for air flow restrictions in vents
  • Test the temperature control
  • Clean the condensor coils
  • Check the door seals
  • Test the door switch
  • Test defrost heater
  • Test defrost timer
  • Test evaporator fan
  • Check for a clogged drain tube
  • Check for refrigerant leak
Sep 23, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Heating & Cooling Logo
81 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Edd
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
