SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
SOURCE: '98 S-10 heater blowing cold air - not hot air
will the air flow switch from floor to the mid to defrost? if so then we have a problem with the tempature door actuator. easy to replace just in tight place. Keep me posted for more help or if this was any help thanks
SOURCE: flymo quicksilver 46s keeps cutting out
make sure button not cracked also fuel filter sits in bottom of tank get you a peice of coat hanger and fish it out just pulls off the end clean it good and also double check your carb sometime you can lose a gasket and it will cause similar issues? let me know if any of this helps ? can also tell you how to adjust high speed side of carb if all else fails?
Testimonial: "that was very usefull thank you"
SOURCE: heater fan works, anti freeze full. heater does
it sounds like the thermastat needs replacing .it might be worn .so it is not closing .check the heater hoses .if they both are hot the heater core is blocked
Testimonial: "thank you makes sense"
