Question about Canon Video Cameras
I have a Canon Vixia HF20. When I connect it to
I have a Canon Vixia HF20. When I connect it to the Canon DW 100 Burner I get the following erro on the Camcorder ''Operation Canceled. Thus the files on the camcorder do not write to the burner
    Genius:
  • 1,689 Answers
Hi robert,
thank you for using fixya.
usually this error is caused by a CD containing data that the burner cannot overwrite, or the communication between to Vixia and the burner was interrupted by an operation on either machine.
set the camera to burn data and overwrite the contents of the CD wether or not it contains any files.
http://www.canon.co.uk/Support/Consumer_Products/products/camcorders/Digital/HDV_series/HF11.aspx?faqtcmuri=tcm:14-605003&page=1&type=faq
for the manual:
http://gdlp01.c-wss.com/gds/4/0300001964/02/hf20-200-nim01-en.pdf
hope this has been helpful.
regards,
voodoo
Posted on Aug 02, 2009
My computer do not recognize my canon vixia hf20 double click on my computer icon : computer do not recognize the camcorder canon vixia hf20
Be sure that you have installed he driver correctly ..and the cable is well plugged...,another thing to check is the camera's display and see if it asks for a connection confirmation in the moment you plug it in ...if it does..choose PC connect ..and after that will work ..
also check into the device manager and see if the camera is present there ..even if it appears in yellow with an ask sign on it ...this meaning that the driver is not installed or damaged or not the proper one..
http://software.canon-europe.com/products/0010719.asp
select the operation system ..download ..reinstall and go for it ...but first check what I suggested..
Dec 24, 2010 | Canon VIXIA HF20 High Definition Camcorder
I am thinking of buying a Connon VIXIA- HF-MA300. Will the DW-100 burn directly from the camera ?
Connect the camera to your PC.
Connect the Canon burner to your PC.
Use free software (see: http://www.MajorGeeks.com and search for "AShampoo Burning 6")
to read the files from your camera, and burn them to a blank CD/DVD disk.
Dec 12, 2010 | Canon DW 100 DVD-RW Burner
Where is the serial number of my Canon Vixia HF200 Handycam? I'm not able to find it anywhere, the number mentioned under the battery is not accepted
I have Canon Vixia HF20 A and I when installing the Pixela Application that comes with it, I used the numbers under the battery. You'll need to concatenate all three numbers together as in my case for it to be correct... e.g 111122223333, 1s represent line 1, 2s line 2 and 3s line 3.
Apr 09, 2010 | Canon VIXIA HF20 High Definition Camcorder
Canon DVD burner DW-100 and HG10 burn issue
You can not have any MXP Files in your play list or in memory. The DW-100 Can not burn these files. Once you delete/remove the MXP Scenes from the the Camera the Burner will work fine.
Dec 13, 2009 | Canon DW 100 DVD-RW Burner
Did not burn dvd
The DW-100 burns files in the same format as they were originally recorded by your camcorder. The Canon Vixia HG-21 records in AVCHD--a high-definition format--which is completely different from standard-definition DVD and which is not compatible with regular DVD players (even though the disc itself is a standard DVD-R). As it states in the manual for the camcorder, "High-definition (AVCHD) discs created using the optional DW-100 DVD Burner can be played back only with AVCHD-compatible DVD players."
The DW-100 is really more for archiving your files in their native format than for creating standard DVDs that can be played on regular DVD players. Regular (standard-definition) DVD players can't play AVCHD, although many Blu-Ray players can. Unless you use a Blu-Ray player that supports AVCHD playback, there are two solutions to your problem:
1. If you want to keep your recordings high-def, you can view them by playing them back with the DW-100, which must be connected to your camcorder via the USB cable, then from your camcorder to your TV via an HDMI cable.
2. If you want to have standard DVDs that you can play on any DVD player, either import the files to your computer and convert them to standard-definition using video-editing software, then burn them to DVD with your computer's DVD burner, or connect the analog output (component=better, composite=good) to a stand-alone DVD recorder (i.e. not the DW-100).
I've used the route of Vixia HF-10 camcorder > composite output > Panasonic DMR-ES25S DVD recorder (about $65 used on eBay) with pretty good results when I've wanted to give videos to relatives who don't have Blu-Ray players. You just have to make sure to set the camcorder 's analog (composite) output to 480i so that it formats the picture in the right aspect ratio, or else the 16:9 image will be squeezed to 4:3 instead of letterboxed.
Hope this helps. Good luck.
Mar 19, 2009 | Canon DW 100 DVD-RW Burner
I recorded my movies on the dw 100 but now i can't grt them to play on my dvd player
The DW-100 records discs based on the format they were originally recorded.
If your camera is recording HiDef videos than the discs this unit creates will be viewable on a Blu-ray disc player.
If your camera is recording in Standard Definition (ie. NOT HD) then I believe that the discs will work in regular or upconverting DVD players.
My Canon camcorder does not record in Standard Def so can't quite vouch for that last comment though.
Jan 06, 2009 | Canon DW 100 DVD-RW Burner
Video Cameras Logo
65 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
