Fan is working but not cold air - Heating & Cooling
  • Vlad rOYF Aug 02, 2009
    Actually i did not hear that compressor come on,
    but fan is working
  • Ned C Cook
    Ned C Cook May 11, 2010
    Can you hear the compressor come on?
    President:
  • 3,433 Answers
If the unit is cooling, see if you have any drainage outside. It has no choice but to dehumidify if it's cooling. The drainage amount is the give away. Make sure the fresh air vent is closed.K?One more thing, Is there any frost on the evaporator? the coils inside the house
Posted on Aug 03, 2009
  • Ned C Cook
    Ned C Cook Aug 03, 2009
    If the compressor does not come on, you have no cooling , so you are correct, it is not dehumidifying.. Is this unit 110v or a 220 v unit? If 220v then there are two circuit breakers in the house breaker panel. Each breaker protects one 110 circuit and you need two 110 to get your 220. A 220 outlet is different than a 110v outlet. The slots in the outlet are different. Easy to tell. If it is 220v you will need to ensure both breakers are not tripped. Usually they are side by side and though seperate they work together, but not always. So if you must, turn them all off and then back on..Feel for a soft breaker,one that doesn't snap onn and off. It may have to be replaced. Let's try that, good luck.
My air is not all that cold and when I am stop at a red light it blows warm air it has plenty of Freon in it. What could it be?
If the air is cold when the vehicle is moving and goes warm when stopped,the fan at the rad/condenser may not be working,or working but not running fast enough.Sometimes there may be a second fan that comes on also.If the fan/fans are running and you can get cold air at a stop by increasing rpm then the system may be low on refrigerant.
Jul 09, 2017 | Cars & Trucks
PTAC unit fans working but not circulating cold air
switch off the unit, manually open the vents and check how dirty the fan blades are. Clean if required. if clean check gas level ,the fan speed is deturminded by the gas
Jul 14, 2013 | Heating & Cooling
'97 Jeep Grand Cherokee AC "Works and Stops"
Make sure your fan clutch is working. No fan, no cooling of the condenser, no heat dissipation, no cold air. Start the truck and make sure you feel air movement, a lot.
Aug 11, 2012 | Jeep Grand Cherokee Cars & Trucks
The AC unit turns on and I can cycle through the options in order to adjust the fan speed however the fan does not start in any of the three settings. The ac unit produces cold air, however the fan does...
You say the unit produces cold air ??? where are you getting the cold air from???
If your fan does not run in any speed F1, F2 F3. and a funny smell sounds like the motor is bad
Mine works in F2, F3 but not in F1
Apr 12, 2011 | Kenmore 75085 Air Conditioner
Fridge does not get very cold,compressor comes on, frezer is cold
check to fan inside unit air not transferring from freezer to fridge fan uses cold air from freezer to cool fridge check that fan is working usually can feel but may have to push button on door and hold if no fan remove cover and check for ice on blockage if none have fan serviced or replaced -if fan is working properly, same area is a damper that my be blocked or frozen good luck and thank u for using fixya
Oct 14, 2009 | GE Refrigerators
Fan is keeps jamming on out side unit machine runs but no cold air comes out
If the outside fan doesn't work , the compressor will shut off on overload and you won't get any cold air , so try to replace the fan capacitor and if still doesn't work , you have to change the fan motor.
Oct 11, 2009 | Carrier BCA101R Air Conditioner
Air cinditioning blowing from cold to hot air
need to check ac fan or fans ,are they working? if not check fuses and fan relays,,,,,and fans (hot wire the fan to see if it/they work
Jul 05, 2009 | 2000 Acura TL
Aircondioniong not working, no fan or cold air
Hi, this sounds like the heater resistor has failed and will require replacing, if the only thing that is not working is the blower motor this would normally be the cause, regards mark.
Apr 20, 2009 | 2004 BMW 5 Series
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Open Questions:
vulcan bonaire comfort control External natural gas electronic ignition 2004. ISSUE: Fan blowing only cool air continuously. Forced to kill power to stop it. model is one of the following. MB514E,20E or 30E. Going by mech drawing parts list. i can confirm what type of sensors i have cleaned with very fine sandpaper. flame sensor PN 5441603SP and IGNITER ELECTRODE PN 5441602SP The fault code i see is described as the following. There are x4 LED's. Sequence Left to Right. LEGEND: 1 Flame Sensor 2 Pressure switch 3 OverTemp 4 Diag. R Red G Green S Solid Colour B Blinking LED Behaviour. In order 2RS & 4GS Until i hear ignition. 2RS & 3RB Duration: split second 2RB,3RS & 4GB Duration: split second 3RS & 4GB Duration: Until it has completed blinking x4 times. 3RS Duration 4 seconds Repeat last two mentioned behaviour. in my own opinion, as a safety feature, the unit thinks that it has overheated or is about to. so kills the gas and force feeding cool air to heating components to save it from frying. Does this mean i have fault 04 if so does this mean i may have a faulty igniter or flame sensor or maybe a faulty as described in the mech drawing SWITCH OVER TEMPERATURE 120 degrees celsius. Am i correct here? Is this the over temperature cut out switch? if no one can really pinpoint which part requires replacement, can you at least, in sequence advise which parts to purchase? so then ill just try my luck. i wonder how to properly test if flame sensor, igniter, over temp etc is faulty with a multimeter. do i just perform a continuity test. I wonder what other parts can i test related to this fault im getting.
Jul 22, 2018 | Vulcan Heating & Cooling
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
