Question about Frigidaire Side by Side 26.0 Cubic Foot Total Capacity Refrigerator
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
Frigidaire Fridge Model # FRS26HF7BB0. Fridge is making a low buzzing noise every few minutes for a few (15?) seconds. Freezer is losing coldness - temp inside freezer is reading 30 degrees. Vacuumed the coils and grill and turned the coldness up on the freezer about an hour ago. Still buzzing/temp still reading 30 degrees. We had a thunderstorm a few days ago and the pwer was going on-off on-off on-off for at least 20 minutes. Not sure if that is related. PLEASE Help!
  • Mark Crane Dec 10, 2009
    My Amana is doing the same thing, a few days after I cut power to the house to fix another problem.Post Solution
  • 1314 Answers
SOURCE: Buzzing and low temps
bad reley or bad compressor proably the ladder if it has an indian on it
Posted on Feb 16, 2008
Krazytech
  • 725 Answers
sound like a compresser relay/overload ,uplug the refigerator remove back cover, remove relay that is on the compressor and check it by shaking it , it should not rattle. if it does replace it..
Posted on Aug 10, 2008
22yooper
  • 828 Answers
SOURCE: frigidaire humming freezer not cold enough
For the 25 year old freezer: a replacement compressor of the same BTU rating can be obtained and used as a replacement BUT at 25 years old I DO Not recommend the expense of a compressor replacement.
To the owner of the six year old freezer. The buzzing noise is more than likely the compressor cycling on its overload protector. This is an indication that the compressor has failed. In this case also I do not recommend replacing the compressor. If it was in warranty the manufacturer would bear the cost. Replacement compressor come with a one year warranty.
Posted on Sep 15, 2008
Techsim
  • 59 Answers
SOURCE: Freezer losing temp... intermittent buzzing sound
Either the start device for the compressor is bad or the compressor has died. The easiest way to tell is to replace the start device. It cost around 30-40 bucks and the part number for it is 218721119. In most of these cases its just a bad start device. The start device is located on the side of the compressor in the bottom back of the unit. It will have a capacitor attached to it that you will want to keep and stick on the new one. If you need anymore help just let me know. Good Luck!
Posted on Nov 02, 2008
  • 358 Answers
SOURCE: HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Posted on Aug 02, 2009
Why wont my fridge get cold?
What is the model number of your unit?
Nov 21, 2012 | Refrigerators
Aug 02, 2009 | Frigidaire Freezers
Buzzing compressor
replace the compressor start / run relay
Jul 01, 2009 | Frigidaire FRS26H5AS Side by Side...
Fridge not blowing cold, Buzzing inside black ball "compressor"
The black ball you are reffering to is the compressor.It is trying to start..that is the buzzing.The start,and overload relay is probably bad..hopefully.Because if it isn't the compressor may be bad.Where your wires plug into the compressor...this is the relay.it should come off fairly easy.It is much cheaper to replace this part..than buying a new fridge.For instance i buy them for g.e. refrigerators all the time from an appliance repair shop at cost,and they are less than 4 dollars for me.So I assume they aren't too expensive retail.
May 17, 2009 | Frigidaire FRS23R4A Side by Side...
Nov 02, 2008 | Frigidaire FRS26RLECS Side by Side...
Frigidaire side by side fridge
Power to compressor must be off (about 5 minutes) before a restart should be tried. Some of these relays are thermal and must cool down before power is reapplied.
Sep 04, 2008 | Frigidaire FRS26R4A Side by Side...
Aug 10, 2008 | Frigidaire FRS26R4A Side by Side...
Feb 15, 2008 | Frigidaire FRS23R4A Side by Side...
Frigidaire Side by Side 26.0 Cubic Foot Total Capacity Refrigerator Logo
167 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
