Question about Nokia 6680 Handheld
My phone i have a nokia 6680, when i receive a file is automaticall saves to my phone memory how do i change this so it saves automatically to my memory card ? Please help. Thanks x
  • 270 Answers
Re: my phone
Go to messge menu . select options >settings> other settngs >meory in use , select it and select the option to memory card . if meory card is selected u can see it in message icon a mmc picture can be seen with a message icon
Posted on Dec 05, 2007
0 characters
3 Points
How to reprogram nokia 6680 how to fix blutooth of nokia 6680 how to remove virus of nokia 6680
You can able to format your mobile phone by simply typing *#7370# and a question will appear then confirm it, then next step type your lock code, your phone will restart and fully reformatted. (Note: BEFORE DOING THIS YOU MUST BACKUP ALL YOUR FILE SAVED ON YOU PHONE MEMORY, AND I SUGGEST YOU MUST REMOVE YOUR MMC BEFORE DOING THIS)
Aug 09, 2011 | Nokia 6680 Handheld
Low memory of n82
Hi, Just move any file from phone memory to Memory card. etc..mp3, video or image, Make sure if you install any software, make memory as root of directory, also delete any massage you received through Bluetooth. Or you can set whenever file received by Bluetooth straight to card memory to save phone memory space.
Jul 27, 2011 | Nokia N82 Handheld
Sir i m use nikia 6680 phone. this set is problam sim card not valid. plz soloustion.
i have a problem..i bought a 1gb rsmmc,sometimes it shows..memory card not inserted..when it is.and when i look for my sez..database corrupted,some files have been lost..pls help me
Feb 19, 2011 | Nokia 6680 Handheld
When i receive any file via bluetooth,it is saved as a message. As the phone memory is very less,i can't receive large files. how can i receive any file directly in memory card
You cannot directly download to the memory card.This options is not there in this mobile.
Download the below software this will start saving your messages to the memory card.So when you receive some file you wont get out of memory message
After you downloaded it, you'll find that you save fila named MsvDriveE.jpg. Don't worry! You just downloaded the right file. Rename the extention *.jpg, and change it to *.sis. Then you'll get MsvDriveE.sis then install it to your phones.
Thank you
Oct 05, 2010 | Nokia 3230
Transfer files into memory card
Please follow the below steps:
Open Messaging -> Options -> Settings -> Others -> Memory In Use.
Then change memory in use to memory card and files that you received will be save in the memory card
May 29, 2009 | Nokia 3230
for that you need to open message and then go to options nad over there you will find message setting
you have to change all incoming message come to you memory card not to your phone memory
May 25, 2009 | Nokia 3230
Sending MMS automatically problem
I think your mobile is infected by virus.
To solve this problum you have to format your mobile.
To format Cellular Phone Steps are shown below
  1. You can remove the mmc but keep the sim card and restart your phone.
  2. Then press the keys *#7370#.
  3. The phone would ask a confirmation.
  4. Select yes.
  5. Then it will ask for a code.
  6. Type the phone lock code (the default code is 12345).
  7. There you are! your phone will restart with all the phone memory formatted.
  • Also remember that you can reset your phone but not loose any of your personal files (I.E restore the settings that came when you bought the phone while keeping contacts etc) by following the above procedure but using the code *#7780#
  • Don't apply these steps if you are not sure what you are doing.
  • Make sure you have enough battery power before beginning this procedure.
  • Formatting will erase all your contacts/messages, so make a backup of your phone before formatting.
  • If have MMC-card make a backup on mmcstore file !
Jan 25, 2009 | Nokia 6680 Handheld
Unfortunately the message file got corrupted. You need to hard format the phone but of course you need to back up every important file on the phone memory cuz it will restore yur phone to factory defaults.
Make sure you have a full battery. Remove the memory card and sim as well. Turn off the unit. Hold down asterisk (*) sign, the number 3, and the green call button at the same time then power it on. The screen will flash and you will see a progress bar. It will format itself automatically.
Hope this helps.
Sep 18, 2008 | Nokia 6680 Handheld
Reprogram my nokia 6680
Full phone formatting on a 6680!
If you encounter situation like below on your 6680,
1. Blank screen phone unable to reboot.
2. Phone only able to boot-up to "Nokia" word screen.
3. Install some program but not able to uninstall it after that.
4. Error messages such as "Child Installer" keeps popping-up.
Do a Full phone formatting on your 6680! as steps below,
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your 6680 phone.
4. Press and hold 3 keys;
Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the 6680 phone.
Remember, do not let go all of the keys and hold keys until you see a Nokia turns to white and blink' and nokia logo!
5. After a few minutes when the Full phone formatting completed, your 6680 will back to original system and factory settting.
All apps installed & not of the phones' default will be lost. If you did a backup on your mmc, you can restore it back to the C drive again.
Thank you for rating this Tip.
Dec 26, 2007 | Nokia 6680 Handheld
Receiving directly to memory card
if you want to recieve data on your phone above the free memory space, first try to transfer your files that was saved on your phone memory to memory card. or on safer way if you want to download data use mmc reader for downloading.
Mar 03, 2007 | Nokia 3230
Nokia 6680 Handheld Logo
Top Nokia PDAs Experts
Are you a Nokia PDA Expert? Answer questions, earn points and help others
