Computers & Internet Logo
G
Gary MIddleton Posted on Jun 23, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
=IFC5=0,,0.3+0.028*B5 - Computers & Internet
Brett Duxbury
Level 3:
  • Computers & ... Master 4,352 Answers
  • Posted on Jun 23, 2018
Brett Duxbury
Level 3:
Answers
4352
Questions
0
Helped
1118869
Points
13423
Gary
excel ?
assuming excel formula not sure what you are using formula with?
=if(condition,true,false)
=if(c5=0,0,0.3+(0.028*b5))
1helpful
Bostitch B5 stapler. How do I replace the blade that pushes the staples???????????
This stapler is an antique first made in 1936. It should be fixable as stuff was made better in those days. From memory, the pusher clips into the top of the handle part.
https://www.google.com/search?q=Bostitch+B5
Repair
https://www.google.com/search?q=bostitch+b5+repair+manual
2answers
2001 Audi A4 Quattro 1.8. Guys, I have looked for this question even here and I can not get a clear and transparent answer.
You make it sound like it's our fault you can't find it :>D
The start of production of the Audi A4 B5 is 1994. With minor changes, it was produced until 2001. At first, only the sedan version was available, the station wagon (Avant) appeared a year later. This material provides information on relay circuits and fuses Audi A4 b5 1994, 1995, 1996, 1997, 1998, 1999, 2000, with an assignment of their elements and locations.
Can't get much clearer than this. Relay 4 is one plus 'Additional Relays 23 and 24. Plus fuse 23 and 24.
Fuse box diagram Audi A4 B5 and relay with assignment ...
https://fuseandrelay.com > audi > a4-b5
This material provides information on relay circuits and fuses Audi A4 b5 1994, 1995, 1996, 1997, 1998, 1999, 2000, with an assignment of their elements and ...
Passenger compartment · ‎Main fuse box · ‎Relay box · ‎Engine compartment
Countif formulas
Are you trying to find how many don't have a letter? If so you might try "COUNTA" instead of "COUNTIF". You could also try looking at the format of the cell your formula is in and change it to general or number.
Need fast service manual for Audi B5
I downloaded the manual for my B5 from this site : Service Manual PDF Audi A4 B5 1994 2001 pdf download
and I'm very satisfied about it! Very easy to use and also you will get it instant.
3answers
Codes
0= 98 BO BA 52 D3 21 08 B4
1= D2 EA 29 B7 B5 52 E9 AD
29TH NOV GOOD LUCK
1helpful
4answers
New codes
telepest codes 29TH NOVEMBER 2008
00=98 B0 BA 52 D3 21 08 B4
01=D2 EA 29 B7 B5 52 E9 AD
Blank cell help
You can use an IF statement:
IF(logical_test,value_if_true,value_if_false)
In your case, this would be:
=IF(B6<>"",SUM((B6+D6)-(B5+C6)),"")
This works as follows:
IF(B6<>"", : If B6 is not equal to nothing, ie. it equals something
SUM((B6+D6)-(B5+C6)), : Set the value as per the equation
"") : Otherwise set the value to nothing.
Of course, this only checks that there is a value in B6. Depending on that value (and that of the other cells) you could still get a negative result. The way to avoid this would be to use the following:
=IF((SUM((B6+D6)-(B5+C6))>0),SUM((B6+D6)-(B5+C6)),"")
A bit long winded, but basically it checks the result of the sum is greater than 0. If it is it displays it, if not it leaves the cell blank.
Hope this helps,
Matt
=if
=IF(C5>B5,0,B5*2)
this means if it is true that C5>B5 then the cell = 0,
but if it is not true, means C5< or = B5, the cell will be B5*2
You can change the numbers as you need.
To use function easily, you can click "Insert" --> function --> then choose in the "select a function" -> OK.
Then follow the instructions. Very clear to follow
Using if and then to add values to a cell
Try using the SUMIF function for one condition or multiple conditions. Use the SUMIF worksheet function to create a total value for one range based on a value in another range. For example, for every cell in the rage B5:B25 that contains the value "Northwind", the following formula calculates the total for the corresponding cells in the range F5:F25. Formula:
=sumif(B5:B25,"Northwind",F5:F25)
Here are SUMIF functions for multiple conditions.
=sum(if((B5:B25="Northwind")*(C5:C25="Western"),F5:F25))
=sum(if((B5:B25="Northwind")+(C5:C25="Western"),F5:F25))
=sum(if(B5:B25="Northwind",IF(C5:C25="Western"),1,0)))
Also check your help for SUMIF functions.
If this helps you, Please rate me. Thanks, Patty
Grand Canyon Tech
Grand Canyon Tech
