Question about Samsung DVD-VR375 DVD Recorder/VCR
Dubbing from vcr to dvd
Im trying to record some old home video's to dvd but just as it starts recording, it stops straight away and comes up saying 'check the tv system' Im not sure as to what that means and why? Everything else up to that point has worked just fine. Can someone shed any light on this?
    Scholar:
  • 88 Answers
Bets solution is run av cables and not RF male to female.. AV out of VCR to AV in on DVD rec. Check in menu or at back of vcr for sountsetting like BG,I, DK etc and check also on DVD rec that its the same
Posted on Aug 12, 2009
How do you record dvd to vhs and from vhs to dvd
For VHS to DVD, put the tape to dub in the VHS slot and a blank DVD in the DVD tray. Make sure the DVD is compatible with the DVD recorder (see the recommended disc list) and is unfinalized if you are using a R/W disc. Close the tray. Set the unit to VCR mode with the DVD/VCR button. Advance the tape to the place that you want the recording to start. Then press the Dubbing button (either on the remote or the unit itself). Select the recording mode (SP, LP etc), highlight Dubbing then press Enter or Dubbing. Press Stop to interrupt the recording.
For DVD to VHS, put a blank tape in the VCR (make sure the protection tab has not been broken off) and the DVD to duplicate in the DVD tray and close the tray. Put the unit in DVD mode by pressing the DVD/VCR button. Find the point at which you want to start recording the DVD. Again press Dubbing and set up the recording mode and highlight Dubbing and press Enter or Dubbing.
Note that copyprotected content can not be recorded.
The manual for this recorder is on the right side of the page here: http://www.lg.com/us/tv-audio-video/video/LG-dvd-recorder-RC897T.jsp . See page 48 for the screen captures of setting the recording mode part of the dubbing procedure.
I hope this helps.
Mar 19, 2011 | LG RC897T DVD Recorder/VCR Combo
How do I transfer a video from vcr to dvd on magnavok dvd/vcr recorder ?
Use the Dub video feature. This will work if the source is not copy protected. Make sure you have a writable (or rewritable) DVD with sufficient space available in the DVD tray (closed) and put your tape to dub in the VCR.
Press Setup on the remote and navigate down (up/down arrows) to Recording and press OK. Then select Dubbing Mode in the next menu level and press OK. When the Option menu opens, highlight VCR to DVD and press OK. Press Setup to exit this menu. Choose a recording mode using REC MODE on the remote. Press Play and then Pause when you reach the point where you want to start the recording (press quickly if you want to dub the whole tape; you will lose a few seconds while the dubbing starts so include 5 seconds extra if starting later in the tape). Then press Dubbing on the remote. The duplication will start. Press Stop when you reach the end of the section to record.
I hope this helps.
(only the Setup and Rec Mode buttons do not have a matching button on the front of the unit. The later steps (setting up the start point, starting the Dub and stopping it) can be done with the remote or the buttons on the unit.)
Oct 27, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Using a Sylvania DVR90VF, how can I record from a VHS tape to a DVD?
OK here's what the user manual has to say on it!
PS If you need the user manual I will E-Mail on request.
Prepare for the recording on the DVDRW/ R disc or the videotape. Make sure:• Insert a recordable disc and a videotape with a record tab.
Note for recording to a disc:
• Make sure that the disc is recordable.
Hit [SETUP].
Easy Setting Menu or Advanced Setting Menu will appear. If Advanced Setting Menu is displayed,
proceed to step 3.
Using [
K / L], select “Advanced Setting Menu”.
Hit [ENTER].
Using [
K / L], select “Recording”. Hit [ENTER].
Recording menu will appear.
Using [
K / L], select “Dubbing Mode”. Hit
[ENTER].
Option window will appear.
Recording
Auto Chapter 10 minutes
Timer Programming
DVD-RW Recording Format Video mode
Auto Finalize
Dubbing Mode VCR DVD
VCR DVD
Recording
Timer Programming
Auto Finalize
DVD
VCR
DVD-RW DVD-R
VR
DVD-RW
Video
Note
For VCR to DVD duplication:
• After starting VCR to DVD duplication, the picture may be distorted because of the auto tracking function. This is not a malfunction.
5
Using [
K / L], select “VCR DVD”. Hit [ENTER].
6
Hit [SETUP] to exit.
Make sure to select a recording speed using [REC SPEED].
7
Hit [PLAY
B].Then hit [PAUSE F] at the point you
wish to start recording.
• Since it takes about a few seconds before the actual dubbing begins, please allow extra 5 seconds
when selecting the starting point.
8
Hit [DUBBING].
VCR to DVD duplication will start.
9
Hit [STOP
C] to stop the
recording.
When you turn off the unit after setting the Dubbing Mode to DVD VCR, the setting will be set to VCR DVD automatically.
• Dubbing Mode is available only if the videotape or disc is not copy protected.
• You cannot change the output mode during VCR to DVD or DVD to VCR duplication.
• The playback sound mode is followed by the setting of VCR playback sound mode on page 77. Set the playback sound mode to which you wish to record to the DVD.
May 12, 2010 | Televison & Video
Magnavox ZV450MW8A DVD/VCR Recorder Dubbing.
I bought a ;magnavox dvd disc and cassette recorder combo.
I am having trouble with setup items? I get nothing on the screen to select from?
Oct 24, 2009 | Televison & Video
I have a Magnavox ZV427MG9. I follow all directions in manual for dubbing VHS home movies to DVD but when I try to play the DVD back there's nothing on them.What am I doing wrong?
Depending on the procedure you may be pressing the record button instead of the D.Dubbing or Dubbing button. When recording from VHS to DVD you must first, load the blank DVD and VHS home movies, then play the VHS movies, then PAUSE the VHS movie when you want to START recording... then the only the you have to do is pressing the D.Dubbing button or the Dubbing button. If your VHS tapes starts to play after the Dubbing button is pressed you have been successful in Dubbing.
Aug 13, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
Apr 16, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
VHS to DVD - D-VR4XSU
have u tried the seting on the vcr, you know how u can change the lenght of recording on the vhs
Mar 29, 2008 | Philips Magnavox DVD/VCR Dual Player
No Instruction Manual
1. Insert a blank DVD disc in the DVD deck and
close the disc tray.
2. Insert the VHS video tape you wish to copy into
the VCR deck.
3. Find the place on the VHS tape from which you
want to start dubbing using the PLAY, FF, REW
and PAUSE functions. For best results, pause
playback at the point from which you want to
record.
4. Press the DUBBING button on the Remote
Control or DUB on the front panel.
The Dubbing menu appears.
5. Use the arrow keys to select the desired Record
Mode: EP, LP, SP or XP.
6. Select [Dubbing] then press ENTER or DUBBING
to start copying.
7. To stop dubbing at any other time, press STOP (x).
Dubbing will stop automatically when the VHS tape ends.
Mar 01, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Samsung DVD-VR375 DVD Recorder/VCR Logo
222 people viewed this question
Jerry Greenberg
Jerry Greenberg
