Question about IBM ThinkPad 600E 2645 Notebook
Wont pwr up
Wont power up even with the cord in
no lights
  • 52 Answers
Remove your battery, optical drive and reseat your memory. If you still have no power it sounds like either the ac-adapter or the dc jack (plug).
Try another ac-adapter if you can and see what happens. If there is still no power, I would say your DC jack needs to be serviced or replaced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/robert_33deecd2f8e91168
Posted on Aug 02, 2009
2 Suggested Answers
SOURCE: will not power on even with pwr cord attached
my computer does not want to turn on
Posted on Jul 29, 2009
Canon pixma mg5220 will not turn on
When you have sparks it toasts the chips even a good teck will ground themselves before opening a peice of equipment like that. I'm sorry to say but I doubt very seriously if either piece of equipment will work. I would also get rid of the surge protecter and have that outlet looked at.
Oct 14, 2015 | Canon PIXMA Office Equipment & Supplies
Tip
If your computer has a black screen and not booting to desktop
Normally if the computer has the black display then follow these steps:
1) disconnect the pwr cord form the back of the computer //
2) disconnect the printer and the internet cord//
3)hold the pwr button for 1 min and then release// this is called "pwr drain" when the pwr cord is disconnected//
4)connect the pwr cord and restart the computer and see if it boots or not.
5)if not then disconnect the pwr cord again and open the side pannel of the computer//
6)on the mother board you will find the RAM (MEMORY CARD) which will be approx 6 inch long", take out the card/s and plug the pwr cord and restart the computer//
7) if you get the beep sound then the mother board is ok and if you do not get the beep sound then the problem could be mother board//
8)if getting the beep sound then fix the RAM CARD properly and restsrt the computer// it shoul boot//
note** during all this process make sure that the pwr cord is pulled out when you put your hand inside the computer or else you can get power shock..
on Jun 10, 2010 | Computers & Internet
HP Pavilion Dv6000z will not turn on
Florida Bob,
Battery is part of the power/charging circuit. As you have found it needs to be in place; kaput or not.
Believe your problem to be Power MOSFET's.
This will explain why,
http://www.fixya.com/support/t15330613-hp_pavilion_dv8_not_starting_up
(The Mayohardware article)
Now you may know what is wrong, and where to get replacement parts, and how to replace.
This is the HP Support link to the free Service Manual,
Main Support page for the HP Pavilion dv6000z Notebook PC,
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3224052
Manuals download page,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=3224052&
In the list you want the blue -
HP Pavilion dv6000 Notebook PC - Maintenance and Service Guide
USE an ESD wrist strap.
Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
SOME screws look VERY similar to other screws.
Advise DO NOT mix them up.
http://www.ebay.com/itm/65W-CHARGER-AC-ADAPTER-FOR-HP-Pavilion-dv1000-dv2000-dv5000-dv6000-146594-001-/221082152535?pt=Laptop_Adapters_Chargers&hash=item337985ee57
18.5 Volts (DC)
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 09, 2012 | HP Pavilion dv6000z Notebook
Hi my acer notebook does not want to switch on i previously had problems with the charger where it only worked in certain positions.it wont even switch on normally it would switch on the harddrive symbol...
Remove the Power Cord and battery. Press and hold the Power Button for 20 seconds. Now put the power cord back in and Press the Power Button. Did you see any lights or hear any fans running? If not, your power cord is probably bad.
Mar 04, 2018 | Acer eMachines eM2501162 Netbook
Compaq presario sr2020nx will not turn on
Just check the power suply behind computer case , or check your cable power.
May 24, 2010 | HP Compaq Presario SR2020NX PC Desktop
The battery light on the tower stays on.
pull out the pwr cord and press the pwr button for one min and then release. this process is called as power drain. replug the pwr cord at the back of the computer and check. if its works then good or else replace the SMPS the power unit inside the computer. for sure it has gone bad. power unit is easily available in nearby retail outlets.
May 12, 2010 | HP Pavilion 520c PC Desktop
No power, no cooling, no light
check your outlet with a lamp to see if you have outlet pwr,then chk pwr cord, normally not cord(chk the easy things first!!!!)
Jul 19, 2009 | Emerson (025806803716) Wine Cooler
System wont power on unless mb power connector on mb is reset
by mb pwr connector do you mean the swich on the pc case that you press to turn it on or do you mean the large block connector form the power supply ?
If you mean the case switch then you have a faulty one that is sendinga constant signal and locking up the power supply
Jul 17, 2009 | HP Media Center m7060n PC Desktop
No power. Replaced pwr. cord.
Check that the power cord has been properly attached and that no damage has occurred. Also try another outlet on a different circuit.
Jan 29, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
102 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
